Engine rebuild complete with a few hiccups
Its been quite awhile since the last update and felt very lazy, caught up with work scenes and mustering the physical and mental strength to write this, so here is the update and enjoy.
After 11 years and 37 thousand kilometres Tali gets a brand-new heart, total time taken including ordering parts, delays and testing it took around 4 months to complete. Post the rebuild and almost 1000 kilometres, the engine feels more smoother, responsive and there is minimal strain while taking a pillion.
Fresh new engine
All the fresh parts been laid out.
After seven months of waiting while being in another country i got to finally meet her, the best feeling, best thing is the day i landed in Mumbai, i was working on the 16th, went home freshened up a bit, checked all my stuff was in place, went to the airport super tired, barely got sleep in the flight, rested up for about 2 hours.
When i came to know that the fork seals gave up, i wasn't bothered that much.
Gen1 RC and Duke in one frame with a Daytona peaking from the back.
A sexy Ducati in a full spec attire, the scary part was the winglets, the scare while moving around it.
The remains of the previous engine
Final checks
On the topic of the slipper clutch conversion, the difference which was felt was, during aggressive downshifts, the rear does not unsettle itself, I do miss that feeling, but i want the engine to be more reliable, so best of both worlds. The clutch pull during the first 300 kms felt a bit hard and during downshifts from 6th to 2nd gear there was a some clunky noise either from the clutch wire or the main clutch side, but after doing a ride to Igatpuri that noise disappeared and the clutch pull became lighter, with that I feel the response time is quicker, could be a placebo effect never know.
The culprit for the fuel leak.
Old vs new output shaft
So 90% of the engine is new except for the gearbox, all the parts which went into this build are from the BS6 engine. The break in period was 1000 kms and running Silkolene 10W50 and keeping it under 7000 R.P.Ms, it sure wasn’t an easy task, but for a good engine health for the future kept it under control 90% of the time, the bike felt responsive even under 7k and addictive.
Replaced the O2 sensor to see if it solved the random stalling at low R.P.Ms and neutral, which it didn't solve.
Due to time constraints and the bike being idle and sitting in the rains the, fork seals gave up and there might be some damage in the fork pipes, which were still leaking even after fork seals. Even the brake rebuild took a back seat as the brakes were still functioning good with no problem, but I did switch to EBC brake pads, now the brake squeal from the KTM sintered brake pads is not there, just a slight scrapping sound, still miss that squealing sound from the previous brake pads. The swingarm did get refurbished. During the first few days the engine light was flashing and disappeared, then there was a fuel leak from the filter area, which I realised later on, the culprit was a rusty old clip which took half a day and 5 shops to source it. The issue which still hasn’t gotten resolved because of time constraints is the idle issue at neutral and 1st,2nd gear at low R.P.Ms where the bike just shuts off randomly, which was kind of irritating as I was on a vacation in India and cancelled alot of my riding plans. Now since im back to work overseas and the bike has gone back to her sasural, the forks and the idle problem will be diagnosed properly with a good amount of time, so next time I come there will more riding and less to no downtime, and mostly there will a nice upgrade.
Came across this Fireblade Akra exhaust lying around and it was super light as you can see in the pic.
Some random clicks.
The gorgeous art piece of the bike especially in this angle, the art piece doesn't need any introductions.
In the end i am satisfied and happy with engine rebuild.
, now i have to hunt for a 2014 spec wiring harness, some say its discontinued and some say its available, i do not want to change my ECU for it, this will be a problem for me to deal with on my next trip to India. Got the HSRP number plate installed on the bike.
Cheers,
Dhruv Shetty.
