Adding to the above SiLxNcE, since there is no separate thread, I will take the opportunity to hijack a little on my decision process. I wanted to highlight that the below details are peculiar to my needs and usage.
The parameters I deduced also based on my continuing ownership of RE thunderbird for over 14 years or so are as follows
A Bike that
- is not overweight
- is consistent quality wise. [this is very abstract and relative term that I can explain with my perspectives in detail]
- has tubeless tyres
- has dual channel ABS with good brakes
- is not built with all advanced engine configurations but still can do what I require it to do. For my use case USD forks, 6 gears, oil/liquid cooled, slipper clutch, quick shifter are all optional parameters and nice to have.
- is from a manufacturer who has decent service backup
- is easy to manoeuvre without requiring much acquaintance and makes me feel comfortable (for instance, I added a center stand for FZs25 just to get the chain clean and lube easily
) - can hold the pillion rider for few kms if not longer journey
- can rapidly respond to my input (yeah i am little crazy)
- is cost effective (i don't want to use the term VFM as it is very relative for each individual)
- is not RE (I have my own reasons for this, which I can document in few lines in my ownership review when I Pen it down)
Some or most of the above parameters are derivatives of my 14 year ownership experience of RE TBTS. [I am still owning it]
I went through KTM, Bajaj, Hero, Classic legends. The combinations of above parameters strike out the options with these manufacturers.
With Japanese, I started with Honda CB300R. It was mind-blowing experience after driving a 14 year old RE
I simply loved it. One thing that wanted me to explore beyond was the cost factor, as I felt 3.22L onroad after localisation is not agreeable. I appreciate the agility of the bike, but there were other factors like fuel tank capacity, cramped space for pillion rider to stretch while being seated, etc were also adding to the reasons. CB350 was not considered because of the combination of weight, drivability in city speeds, more like a roadster.
I moved towards Yamaha. I wanted to get the MT15 given that it will tick most of the boxes. I thought the version 2.0 will get the dual channel ABS and I was little greedy to think that even they might elongate the seat little bit. Nothing of these happened and it got strike down. But I like the drive-ability and efficiency aspect of it. Certainly the cost factor is a let down.
Then I checked the FZ25. Got a TD and was convinced 80 percent of what CB300R does can be provided by FZ25. At 154kgs, the seat comfort for both rider and pillion, the 0 to 80 in quick time and solid confidence when you drive with nice brakes, the dual channel ABS, the unique new headlamp cluster (yes i liked it !) and the overall cost factor just got me to take this one. Had the CB300R would have cost a 50K less and with a little more space to stretch the leg for pillion, it would have been my choice. I mention this because certainly the budget was not the constraint but what I value out of the bike made me to move towards FZ25.
Suzuki was ruled out with the combination of parameters like our family's prior bad service experience, the cost factor (it came in after I TD FZ25), the pillion rider comfort. If none of these are a concern in one's considerations, they should consider looking the SF250 or the Gixxer 250.
Just to mention, I drive in weekdays for my commute to office (to and fro 40 to 45 kms based on the route I take). It is semi-urban as I live in outskirts of chennai. In the weekends typically I hit highways as I visit temples at remote villages. For me the speeds I prefer is 0-80 in quick time, consistently do 100kmph when required (read it as open roads) and not always. I strongly feel a two wheeler is safely driven at less than 80kmph (to get the brake in control when required) unless it is a closed environment specifically devoted for driving higher speeds.
Sorry for the long post, but I was thinking i should share my perspectives considered in my decision process.
Mod Note: Our Bajaj Pulsar N160 Review has been taken live at this link. Please continue the discussion over on the new thread. Thanks!
