Hey everyone. My schedule has been super packed and probably will be for the foreseeable future. So I'll try to put in some periodic bi-monthly updates here. I haven't done as much riding as I expected off late due to health problems and an insurance claim for a damaged rim that took about 3 weeks to replace. So I hit a somewhat deep pothole at a speed that wasn't exactly ideal. I initially thought I had definitely hit the catcon based on how loud the "thud" was. But when I stopped to check at the next signal, there was absolutely nothing, not even a scratch on the lowest part of the fairing. Seeing this, I thanked my luck and dismissed it. About a week later when I came to check the bike in the middle of my viral fever, I noticed that there was indeed a very visible blemish on the rear rim.
The insurance guys initially refused because the rim damage is apparently not covered in my package. My condition was so bad at that time, that I didn't even feel like arguing with him and just thought I'd go ahead and pay the 11k with labour that Aprilia was charging, out of pocket. Luckily the insurance agent himself called back and said that we'll make an exception in this case. This whole process took about 22 days. Then I had to again take the wheel for balancing separately because I found that they don't give balanced rims from the factory for replacements. The guy at the wheel shop was really worried that I was adding 75g of wheel weights but I confirmed from the showroom that up to 96g is allowed before they declare the rim as defective.
I was very intrigued by how they've shaped the swingarm in order for it to stay clear of the catcon.
Additionally, I also completed my 2nd service a little earlier (at 4896km) as I have a proper long ride planned for the last week of december. I thought it best if I give it for servicing at least 3 weeks in advance to be on the safer side. The one recurring problem that I had since about 3800km was really squeaky and messed up front brakes. I kept attributing it to dust and debris going into the callipers but alarmingly I found out during the service that the brakes were almost entirely gone. While I have an aggressive riding style, the service manager still insisted that ideally, 6000km is what you should aim for unless you are taking the bike to the track daily. The rear pads had about 1000km more but I changed them as well since I have a 1900km trip planned next.
Total service cost was the same 4000ish as before with another 5000 for both the pads (4600-400 cost split)
I did mention what has been going well with the bike before so here are a few negatives that really stood out to me:
1.
The infamous left-lean issue: Yup this is a thing. If you leave the handlebars, the bike does veer to the left when you let the handlebars go unless you apply a tiny amount of counterweight to the right. I am not able to understand why this happens as I have checked the wheel balancing and cone-set condition multiple times. This only happens when the RPM drops below a certain level and it's pretty much there on all bikes. I did get used to applying a slight counterweight to the right side and I honestly don't feel the bike has any handling issues because it is exceptionally good at turning. I'm not sure what to make of this, a lot of other owners are not at all happy with it.
2.
Cleaning the bike: Can't really blame anyone for this. The front mudguard is pretty short and this bike hurls slush and much all the way up to the instrument console and into each tiny crevice on the way. The entire radiator area also gets covered because of this. I didn't expect this to be easy to clean but the potential it has for getting dirty is insanely high.
3.
Clutch lever vibration: This is again pretty common across all bikes. The clutch lever shakes like crazy but only in the 500 RPM range between 3500 and 4000. This is irritating because this is where you'll be mostly during relaxed commutes.
Apart from that I have been lucky enough to not be affected by the battery drain and rectifier unit defects that a lot of my friends had to go through (*touchwood*) and there's a new problem of some weird rattling noise coming from inside the head unit that another few friends are facing. We'll know the results of that soon. Here are few pictures over the past few months:
Pondicherry ride with an old classmate from college who recently moved to Chennai. We both had red R15 v2s when we were in college
Rode to Yelagiri with a couple of guys from the owner's group. RS did really well on the hills despite the braking problems. If that wasn't the case, the bike would've been a total hoot to ride.
Random selfie because we both were looking good.
Post-service shine.
Need all your best wishes and blessings for my upcoming trip. I have never ridden beyond 750km as the total distance so I am really stoked and also really scared at the same time
