Team-BHP > Motorbikes
Old 8th November 2024, 18:34   #1
Viju's Avatar
Thanked: 3,251 Times
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_2953.jpg
The Bullet as well as the Classic Reborn come with this neat looking badge, which can be replaced with a Tripper navigation display. I was not keen on adding a Tripper - as I am comfortable using Apple / Google Maps, and also did not want to add yet another digital display to the retro-themed Bullet.
I was looking around for an analogue meter to replace the badge with - even an ammeter as in the older generation Bullets. I had in fact requested Hitchcocks to make a kit, which they should be releasing soon. But it would have been a bit pointless to be honest. Hitchcocks do sell a ready-to-install Daytona Velona tachometer kit for the Bullet and Classic Reborn. But in my eyes, it is a half-hearted job from Hitchcocks - with needle and fonts completely mismatched to the original speedo on the bike, a small digital display and even a shift light - none of which suited the Bullet in my view.
While casually looking around, I came up on a few posts on the Royal Enfield Owners Forum by a user named 'nissbird' who makes tachometer kits for almost all the modern Royal Enfields. Although I am not a member of the forum, I was able to find his contact details and ordered a kit for my Bullet.
Disclaimer: I have no association with him other than this one purchase that I made, and the kit cost me GBP 155 including shipping to Japan.
I have no idea which vendor he sources the basic tachometer itself from, but he designs and builds the housings, bezels, wiring and connectors all by himself. He did share a few of his CAD designs for the different RE models upon my request. He takes care to use matching needles, fonts, bezels and even backlighting. The bezel on my tacho is made from stainless steel, and it is neatly polished.
He also provides a 6 month return warranty, but I do hope it lasts much longer than that.
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-clrc3.jpg
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-htrc5.jpg
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-mtrc5.jpg
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-smrc2.jpg
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-srrc1.jpg
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-tc4-sa.jpg
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3238.jpg
Neat packaging
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3241.jpg
Contents
The kit consisted of the actual tachometer, torx driver to remove the factory-fitted badge, USB drive with instructions and wiring diagram and a couple of plug-and-play wiring harnesses.
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3242.jpg
A closer look
Viju is offline   (25) Thanks
Old 8th November 2024, 18:51   #2
Viju's Avatar
Installation
Installation - Part 1 / 2
Caution: As always, before doing any electrical work on your bike, disconnect the negative terminal (normally black) of the battery.
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3245.jpg
Disconnect battery negative (inside the RHS 'tool box' on the Bullet / Classic)
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3256.jpg
The plug and play harness to pick up the signals from the ignition coil
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3275.jpg
Remove the seat (#6 allen key bolts x 4)
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3276.jpg
The fuel tank is fixed using just one bolt and nut (M10 / M8)
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3277.jpg
Remove the bolt and nut carefully
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3278.jpg
Cover the front portion of the tank with fluffy clothes to avoid scratches
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3279.jpg
Lift the backside of the tank gently and prop it up using a suitable object
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3280.jpg
Tank propped up to gain access
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3281.jpg
The white coupler is the one going to the ignition coil
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3282.jpg
If you are dexterous, use your fingers. But if you are like me, use a small screwdriver to gently disconnect the coupler.
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3283.jpg
After adding the new harness, bring the power line (green colour wire with the bullet connector) towards the headlight nacelle
Tie up the wiring neatly using the provided cable tie and the fuel tank and seat can be refitted.
Viju is offline   (22) Thanks
Old 8th November 2024, 19:21   #3
Viju's Avatar
Installation (Continued)
Installation - Part 2/2
Now we can move on to the installation of the actual tachometer itself.
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3246.jpg
Remove the headlamp
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3247.jpg
Gently pull out the H4 plug and keep the headlamp aside in a safe place
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3251.jpg
The torx screw to take out the badge is hidden deep behind the wiring mess
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3252.jpg
I cut the cable tie, moved aside the bunch of wiring and the torx screw was visible
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3253.jpg
Removing the speedometer (just an M10 nut) gives easy access to the torx screw
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3254.jpg
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3255.jpg
The speedo coupler itself is a press-and-remove type and is easily undone
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3257.jpg
Once the badge and bottom piece are out, you can start with the tacho installation
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3258.jpg
The 'nissbird' tacho is a press-fit type, and the lugs can be pressed in one by one starting with the white one after ensuring proper orientation
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3259.jpg
Tachometer installed
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3260.jpg
The tacho power supply connector
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3261.jpg
Fish out the matching 3 pin connector from the loom and remove the cover
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3264.jpg
Fix the two couplers, and you have power supply to the tachometer
Refit everything neatly including the battery terminal at the very end. And yes, do not forget to plug in the signal wire (bullet connector) that you brought in from the ignition coil.
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3284.jpg
Installation complete
Switch on the ignition and your tacho should do a nice sweep right when the speedo sweep ends. It's not simultaneous, but it is more like a synchronized dance.
Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter-img_3274.jpeg
The matching lighting and needle looks pretty good at night in my opinion
Cold start - sorry about the shaky video, it was a cold evening today!
I made this short video to show the tachometer in action. It is pretty cold where I am as we are approaching winter, and the video is of a cold start. The bike fired up and went straight to around 1,500 rpm and finally settle down between 900 and 1,000 rpm. After riding around 10 km, I realized that I shift up at around 2,500 rpm within the city.
Any questions are always welcome.
Ride safe and hope to see you in the next one!
Viju is offline   (74) Thanks
Old 9th November 2024, 17:06   #4
Thanked: 314,214 Times
Re: Royal Enfield Bullet 350 DIY: Installing a Tachometer / Rev Counter
Thread moved from the Assembly Line to the Motorcycle section. Thanks for sharing!
Going to our homepage tomorrow
GTO is offline   (1) Thanks
Old 10th November 2024, 11:03   #5
Sensible_Speed's Avatar
Thanked: 512 Times
That tachometer looks insanely cool! I wish Royal Enfield would give it as an option from the factory. You, sir, are a genius in my eyes. That is a very tasteful addition to your beautiful RE.
Sensible_Speed is offline   (6) Thanks
Old 10th November 2024, 13:25   #6
CrAzY dRiVeR's Avatar
Thanked: 76,222 Times
Nice mod! In fact the tacho suits the slot better than the earlier RE logo, or the Tripper display IMHO!
Royal Enfield could have provided something like this, at least on the Classic 650!
CrAzY dRiVeR is offline   (7) Thanks
Old 11th November 2024, 02:51   #7
Viju's Avatar
Thank you, Sensible_Speed! All credits to Mr. Philip Kench who design and develop these tachometers.
Fully agree, CD!
Viju is offline
Old 11th November 2024, 19:36   #8
I hope this thread reaches the design team/ top executives at RE. The whole dashboard now looks beautiful.
glvenubt11 is offline   (2) Thanks
Old 11th November 2024, 21:18   #9
Thanked: 164 Times
I'll probably end up buying this first and then the bike... Just wishing they'd matched the speedo font, then it would have blended in perfectly. Great mod and thanks for sharing the details
isiv is offline   (2) Thanks
Old 11th November 2024, 21:58   #10
Thanked: 688 Times
Beautiful and absolutely worth it DIY mod. Love the night look when it's lit up! Interesting to see that the designers at RE don't give a heed to functionality just like when they used to not ship a fuel indicator with their motorcycles.
chiefpk is online now   (1) Thanks
Old 12th November 2024, 07:27   #11
Viju's Avatar
Glad to see that so many of you feel the same way as I do.
But to be honest, RE has invested heavily into the Tripper ecosystem, and I won’t be surprised to see the next generation of the Classics and Bullets get a full-fledged digital display in the center as well, similar to the Himalayan 450 or Bear 650.
Looking at the comments in general to RE’s posts on social media, the younger generation of enthusiasts seems to prioritize digital displays, LED lighting, USD forks, matt colours and alloy wheels over a more old school motorcycling experience. The only exception to that is the constant criticism for not providing a kick start on the newer models.
Originally Posted by isiv View Post
IJust wishing they'd matched the speedo font, then it would have blended in perfectly.
I know! In fact, if I have to really nitpick, the stainless steel bezel is not polished to the exact same finish as the plastochrome OEM surround on the speedo, the fonts are not perfectly matching, the resting position of the needles are slightly misaligned, and even the colour temperature of the backlighting is slightly different.
But when you consider this was designed and made by one person who is just another enthusiast like us, these mismatches become more acceptable. Philip had made just one unit for his Classic 350 Reborn, and shared it as a DIY on the RE Owners forum, and a lot of members demanded for one as well. Even now, he makes each piece to order by hand. To do it alone and still be able to sell it at a much lower price than an established company like Hitchcocks who orders a generic Daytona tacho in bulk is quite something I guess.
Viju is offline   (5) Thanks
Old 15th November 2024, 16:11   #12
Thebugdoc's Avatar
Thanked: 497 Times
This is absolutely amazing! Is it compatible with older generation Classic 350 models, specifically the 2018 version? Could you share the total cost involved for this setup?
Thebugdoc is offline   (1) Thanks
Old 15th November 2024, 16:52   #13
Viju's Avatar
Hi Thebugdoc
Kindly check the first post for the seller’s contact details. It is a made to order product. May be Philip could make one for the older Classic 350 as well.
This particular one cost me GBP 155 including shipping from UK to Japan.
Thank you.
Viju is offline   (1) Thanks
Old 16th November 2024, 10:44   #14
Thanked: 28 Times
Re: Installation (Continued)
This is the most beautiful thing I have seen today. I am inspired by your passion for the motorcycle. Thank you for sharing this. I want to to find similar tacho and get it fitted for my classic.
Fr0nx23 is offline   (1) Thanks
Old 23rd November 2024, 09:48   #15
Thanked: 1,583 Times
Infractions: 0/1 (5)
How's the tachometer experience? Is the reading correct? And the eternal question of what are the RPMs at 80kmph and 100kmph.
Thanks in advance.
jetsetgo08 is offline
