Motorbikes
Hello Friends
My Friend is doing some serious mods on his cbz from past year. All the work has been done by himself . but we are kinda stuck this time. we want to install pulsars digital speedo in that . we have already brought the speedo . can i have a wiring diagram or any kind of help in installing the same ??? please:
Waiting........
Whats the wheel size of the CBZ?? As far as i know The sensors on the wheels are usually calibrated to a certain wheel size. So if the wheel size is different from that of a pulsar then you will get wrong readings.
The wheel size of the CBZ is 15" AFAIK.
Originally Posted by NOTORIOUS
(Post 1330028)
The wheel size of the CBZ is 15" AFAIK. |
Nopes, As far as I remember it's 18" wheels.
Pulsar digital speedometer is caliberated to 17" wheels I feel.
Its fairly simple, here are the connections you have to make. Any queries PLEASE REVERT BEFORE CONNECTING THE WIRES.
Power supply : -
White (Batt - direct)
Ground is black yellow wire.
the backlight is red ( 1st position i.e comes on when you switch on the pilot lamps.
Power of console(IGN ON) = Brown
Now the four lights : -
Indicators - LH - Grey RH - Green
Neutral Light - Light green
High Beam = Red Black
Side stand indicator - Orange with brown line.
Now the tacho function: -
RPM wire on console is black colour. on CBZ it must be brown/ blue/black please check
And the speedometer function
Blue with white line (Speedo sensor)
Red with white line(Speedo sensor 2)
The fuel gauge is a white yellow wire.
Get a CBZ wiring harness diagram to make it very easy.
arpandiv Thank You Sir But From Where I CAn Find CBZ wiring harness diagram or Pulsar's ??????
1) You dont need pulsar's wiring diagram.
2) CBZ wiring diagram must be in owner's manual or service manual.
Please dont call me sir, i am the youngest here i guess ;)
arpandiv Thanx Bhai , That wiring worked. i will soon post some pictures...
