Here is a short Stomp Grip application narration with pictures. Excuse the picture quality, I always tend to forget having my camera around for this kind of stuff.
Even though I'm very skeptical about hitting the track, I was hoping the stomp grip would assist even through the weekend and bumpy city rides. Yet hafta' have a proper post application experience though as I haven' ridden over a couple of kilometers since then.
My cousin had messed up the grips for his Hayabusa while applying it, and the result was indeed a very bubbly tank looking like it was packed in some flimsy plastic.
Hence, I was very hesitant at first to apply the same (had it tucked away for a few weeks), till I came across the instruction leaflet, and I was almost sure my cousin had not followed the same.
So took the plunge.
The hardware, a bottle of clean water, dish washing detergent, sponge and the stomp grips. Decided on the dish washing detergent as the automobile shampoo stuff does not get rid of surface wax which needs to go for a bubble free application.
Both sides of a dusty tank of a bike just back from a weekend ride. The picture quality doesn't really help in judging just how not so clean the tank was.
Shampooing the tank in the area of the grip application, did that two rounds over, and did not repeat a third time as my palm was aching from the hard scrubbing in the first two rounds.
Both sides of the tank, all cleaned up and shining in the Sun.
The instruction leaflet and other online reviews suggest having the grip and the tank at high temperature for optimum application. Using a blow dryer is recommended.
Hence, I let the grips be on the rood of my car while I shampooed the tank, by now the temperature on those could be termed warm, but nothing close to being hot.
Blow drying the grips.
Blow drying the tank.
Ideally one is supposed to blow dry for a short while to bring the grip and the tank to a reasonably high temperature.
Once this is done position the grip onto the tank, and see where you’d ideally have it to get maximum grip. This is easier when the grip is a size cut for your motorcycle, the universal ones take some more focus at time of positioning. Its always a good thing to use a marking in this step, something I figured much later.
Once the marking is done, its showdown time, begin peeling off at the narrow end, and only an inch at a time, this because the adhesive is super sticky at those high temperature, and you wouldn’t want any wrinkles on the surface.
While applying, start pressing between the bead heads on the surface to keep out bubbles, this is the most tedious task in the application, and exactly where you could do with extra set of hands (exact words from what I read on another blog). Fortunately for me I had known about this, so kept one of the security guards around to help.
Left side grip applied and done with.
Right side grip applied and sort of slightly messed up. Notice the few mm I’ve gone wide on the broader end. This could have developed bubbles in future, hence had it trimmed while I was at the garage last weekend. Didn’t want to take a chances scraping paint off while trimming the grip myself.
Another shot of both the sides all applied and done with.
A few poser shots.
