Old 2nd August 2020, 17:35   #12061
Thanked: 592 Times
Default Re: Ford EcoSport : Official Review
Originally Posted by Danny121 View Post
Mine is November 2019 Titanium Diesel Manual and to answer you honestly after driving 7000kms I would say the clutch is a bit hard in high density city traffic due to frequent shift and otherwise once you touch the highways then the driving pleasure takes over and you will refuse to stop. I'm still thoroughly enjoying the ownership after coming from owning and driving petrol vehicles and my experience of doing few long distance trips.
Thank you for your valuable insight. I think he will fine with a little heavy clutch, as long as it's not super heavy and makes him go for left knee replacement in a few years time.
Col Mehta is offline
Old 7th August 2020, 11:22   #12062
Thanked: 94 Times
Found this on youtube. I know that EcoSport has an impressive water wading capacity, but doing something like this is plain stupid. At one point I think the car was almost floating.
carriage.retorq is offline
Old 7th August 2020, 11:43   #12063
Thanked: 8,794 Times
Originally Posted by carriage.retorq View Post
Found this on Youtube. I know that EcoSport has an impressive water wading capacity, but doing something like this is plain stupid. At one point I think the car was almost floating.
This idiot has really good luck; it wouldn't have been surprising if the car stalled and had a hydro-lock. The water seems to have been on the hood level so good chance it only very narrowly missed the air intake.
libranof1987 is offline
Old 7th August 2020, 11:50   #12064
arindambasu13's Avatar
Thanked: 1,827 Times
Originally Posted by Col Mehta View Post
My son is considering buying diesel Ecosports S variant. Our only area of concern is the hard clutch issue being reported by some owners. So need existing owners' insight if this issue is big/serious enough for him to not consider this? For easy reference, he has been driving petrol Grand i10 manual and petrol VW Vento manual for last 5 years.
Thank you!
From my personal experience, the hard and heavy clutch issue is very much still present. Yes, of course in a new car, the clutch will seem light and easy to operate, but as you pile on the kilometers, the clutch will definitely get hard. To re-confirm this fact, I did test drives on three different vehicles around a year back, with 11,000 kms, 9000 kms and 14,000 kms (approximate numbers, from my recollection) on the clock respectively, and all three had hard/heavy clutches which were not easy on my left knee.
I have driven petrol cars all my driving life, and thus for me, the heaviness of the clutch was a deal breaker, especially in Bangalore city traffic conditions. If your running is in sparse traffic, or highways, then it might be easier to live with. I rejected the Ecosport both for the hard clutch as well as the bouncy suspension. Otherwise, the car ticked most boxes for me.
arindambasu13 is offline   (2) Thanks
Old 9th August 2020, 19:51   #12065
Dr.Abhi's Avatar
Thanked: 246 Times
Such type of heroism can be fatal. The depth of the water is not known and we have seen underbidges where even buses drown like toys. Thank God these guys are alive.
Last edited by Sheel : 9th August 2020 at 20:47. Reason: Please remove video's URL while quoting a post. Thank You!
Dr.Abhi is online now   (1) Thanks
Old 10th August 2020, 11:54   #12066
hemant.kamat's Avatar
Thanked: 152 Times
Today, after 5.5 years, my ES's original battery finally gave up the ghost. I've just replaced it with an Amaron 45Ah, but now my AC's climate control button is not working properly - it turns the fan ON and resets the air flow to re-circulation mode, but does not turn ON the AC. I tried from 24C to LO, the fan blower speed increases with lower temperature setting, but AC doesn't switch ON. However, switching the AC button ON/OFF manually works.
Climate control button was working fine before the battery swap.
Has anyone else faced a similar issue? Is my new battery at fault, or did some AC component/sensor break during the battery swap?
hemant.kamat is offline
Old 12th August 2020, 09:33   #12067
While running errands in the city last week, the a/c stopped cooling mid-way and soon, I got the engine overheating symbol on the dash. Stopped the car and checked the engine bay; there was enough coolant but the fan wasn't coming on.
I have 5th year Warranty so the fan was replaced without charge (cost is 7.5k). Surprising that the fan conked off at four years/38k kms.
Old 12th August 2020, 16:38   #12068
RGK
RGK's Avatar
Thanked: 340 Times
I gave my car for 60k service at Suryabala Ford, CBE. The advisor had informed that the radiator fan is giving more noise as the bearing is weak.
There is no child spare available and need to change the entire fan assembly which is 7.7k. Understood that the electrical motor (attached to the fan leaf) is supplied by Indrad and exploring if it is available as an individual spare.
RGK is offline   (1) Thanks
Old 12th August 2020, 16:54   #12069
My post directly below yours highlights this. Apparently, the bearing being weak = making a noise = having play are the first signs of imminent failure. I'd suggest get it replaced asap. Failure means engine overheating and possible subsequent damage.
If your car is anywhere less than five years old, you may want to buy warranty and then claim the replacement under it.
Old 12th August 2020, 17:41   #12070
fiat_tarun's Avatar
Thanked: 1,530 Times
Hello everyone,
Thank you!
I've been driving a 2018 diesel S and after 2yrs & 25k km the clutch feels the same as when it was new. It is not super light but not hard either. I would say if you have driven diesels earlier, it's not a deal breaker.
How did he find it during the test drive ?
fiat_tarun is offline   (1) Thanks
Old 12th August 2020, 17:43   #12071
Fordlover88's Avatar
Thanked: 731 Times
Similar thing happened with me as well. And the radiator fan was culprit. Mine was also replaced under 4th year extended warranty. It lasted 3 and half years/ 53k kms. Going by the recent posts, it seems radiator fan premature failure is a common sight in ecosport.
Fordlover88 is offline
Old 13th August 2020, 23:55   #12072
Thanked: 592 Times
Thank you for sharing your feedback.
My son ABSOLUTELY loves the S variant. He didn't find the clutch too heavy during TD but yes, he did express his concerns over it. One of his colleagues owns the same car and he often complains of knee pain after driving it in traffic. My son wants diesel but there is no diesel AT in his budget (Upto 14 lacs OTR). AMTs aren't going to be considered. Kia might get his business as long as they price it right. If not, diesel Ecosport S is for him.
Old 14th August 2020, 10:26   #12073
paragsachania's Avatar
Thanked: 20,557 Times
First isolate if it's the fan itself or the system that triggers the fan to function that is at fault.
Powering the fan directly via battery terminals will confirm if fan itself is working or not. If working, then you need to check the related fuses and relays.
Fans are too simple electrical devices to conk off just like that.
paragsachania is offline   (2) Thanks
Old 14th August 2020, 10:35   #12074
At a friend's (BHPian) garage, did a detailed analysis: checking the fuse, powering the fan directly via the battery, and ensuring the fan terminals were receiving power. Once it was clear the fan had conked off, got it replaced at A.S.S. since it was covered under warranty.
libranof1987 is offline   (1) Thanks
Old 14th August 2020, 10:56   #12075
Thanks but since you had not mentioned about this diagnosis and troubleshooting in your post earlier and it seemed to me that you replaced the fan directly. Hence, I obviously pitched in.
Needless to say, the fan conked off with just 38K on the Odo.
Copyright 2000 - 2021, Team-BHP.com
