What you'll like:
• Rear-wheel drive, 540 kilos & 70 BHP (
130 BHP / tonne)
• Brilliant suspension setup lets you charge across extremely rough trails
• Tried, tested and continually developed for more than a decade in Motorsports
• Most parts are available easily in the market, while custom parts are priced reasonably & stocked here in India
What you won't:
• Hard to get in & out of. Lacking essentials such as basic seat adjustment, headlights, brake lights etc.
• Priced @ Rs. 11.83 lakhs ex-GJ (VAT is extra, no registration charges though)
• CVT causes a noticeable delay in acceleration. Also, stubborn chirping sound when decelerating
• Not (yet) road legal in India, thereby limiting the usability for most potential buyers
The Cyclone is built on the same chassis as Rage’s existing Comet and Hurricane models. It's a fairly compact vehicle, though the flared out bodywork does a good job of giving it more of a “trophy truck” look from the front. From the side, you’ll see that it's more of a small buggy, with a relatively short wheelbase and an almost square footprint. This makes the Cyclone very versatile on narrow trails. The wide bodywork and fenders help keep bushes and stones from hitting you in the face.
Getting into the buggy is a bit of an acrobatic exercise for most people, as you have to step through the frame and into the bucket seats. Once seated, you need to strap yourself down tight in the 4-point harness. It’s a lot more convenient than a 5-point harness, as there are only 2 sides that need to be connected together (vs 5 individual straps). You’re cocooned in metal tubes, there’s no windshield in front of you, and all-round visibility is excellent.
Power comes from the Maruti-Suzuki K10 engine (A-Star configuration with a waterproof ECU). Fire it up, and the 3-cylinder 1.0L motor comes to life in a much louder fashion than you’d expect. Although the engine block is completely stock, the exhaust is an after-market stainless steel unit that adds to the drama of the whole Rage Cyclone experience. The engine is mated to a CVT transmission. It might not be the ideal choice for hardcore enthusiasts, but it does allow you to concentrate entirely on throttle, steering and weight transfer...important when driving on dirt.
For our first run, Neville Poonawalla (
remember his tricked out white Mustang from the Speedrun days?) was going to show me what the vehicle is capable of. He is the owner of 'Rage Motorsports Performance' in India, and has clearly spent a lot of time developing & obsessing over every single nut and bolt of the vehicle. In addition to that, he is also very familiar with the testing trail; Neville made full use of that when demo'ing the buggy. If you want to see what I mean, watch the video in the post above.
Next thing I know, we’re going 80 kph down a narrow path with 12-foot tall cacti on either side - drifting sideways at times!
The first thing I noticed (
especially as someone with a bad back) is that the suspension is truly spectacular! There is 12.5” of travel at the front and 13.5” at the rear for the double-wishbone suspension all-around. In addition to that, the fairly large tyres run on small-ish 14” wheels at only 10 psi of pressure. This adds an additional layer of cushioning to the ride. Despite hitting the broken dirt trail with no mercy, the suspension didn’t bottom out even once. It didn’t make a single sound of complaint either. Right at the very start of the drive, we drove onto a 2-foot wall with just one side of the vehicle, and then drove off it. It was an incredibly cushy landing.
Without the helmet on, the engine is very loud, especially since the CVT tranny means that it will usually be running high in the RPM range. As you let off the accelerator, you hear a loud chirp from the CVT's rubber belt. The aluminum radiator and its twin fans are right behind your head, but the fans rarely come on when the Cyclone is in motion. They only whirr up when the car has been idling at a standstill for a while. The helmet does a good job of reducing the noise levels, and it is an essential part of the safety kit when traveling in a car with a roll-cage (
protects your skull from hitting the metal tubes).
Below 20 kph is the only time when the ride has a bumpy edge, but once you speed up, the suspension flattens everything out. It's incredibly easy to touch speeds of 70 - 100 kph down an uneven dirt track on which a regular road car wouldn't dare go above 15 kph.
70 BHP isn’t a lot of power by today’s standards. However, combine it with a 540 kg dry weight, versatile chassis and an experienced driver, it’s more than capable of delivering thrills by the gallon. Acceleration itself isn’t blistering (unlike some of the other higher-powered sequential-shift Rage models), yet we've been told the Cyclone should manage the 0-100 kph sprint in around 10-11 seconds. Braking too, is at the mercy of traction and on most dirt surfaces; and there won’t be much of that. There is no ABS, no ESP, no power steering - heck, no windshield either. You got to stay well within your limits, especially on dirt where technique and weight transfer govern your driving abilities. For novice drivers on the dirt, it will be a fun learning process. For others, the Cyclone’s true capabilities are just brilliant. If you are considering this vehicle, be sure to experience it in the hands of a seasoned driver.
This paints a better picture of exactly how compact the buggy is. The front view makes it look a lot bigger than it actually is:
The magical suspension doing its work through some ruts. Minimal body roll, maximum articulation:
Carrying huge speeds down a dirt road is a breeze:
In its natural habitat:
Getting some tail-out action is super easy, thanks to the RWD set-up, limited-slip differential and low traction surface:
