Old 17th September 2015, 23:54   #4216
bigblackshark's Avatar
Thanked: 74 Times
re: 4th-gen Honda City : Official Review
Yes apparently there is a new price list effective September i believe as mentioned to me by the SA if only I had booked in June itself would have saved a bit!
bigblackshark is offline
Old 18th September 2015, 11:10   #4217
adarsh76's Avatar
Thanked: 231 Times
Originally Posted by adarsh76 View Post
Honda's service is nowhere near Hyundai's service. But personally for me, there has been no threaten on tyre upsize. However, they told it might void warranty. K&N filters - I haven't asked so far yet.
I checked with Honda Service today and they've given me go ahead to install K&N filters. As per them, it won't avoid warranty and there would be an increase in performance and virtually without any drop in FE for City Petrol engines. Quite a number of 3rd gen City has this installed.
I'm planning to install if this is available in India before November last week when the service is due.
adarsh76 is offline
Old 18th September 2015, 11:17   #4218
Saanil's Avatar
Thanked: 396 Times
Hi Guys, Need help with some questions on the Automatic variant of Honda City:
1. What is the recommended tire pressure for the car? I was not able to find the values in the owner's manual.
2. Now while driving the car, the gear slot should be in D mode or the S mode. What is the use of the N mode? Should we be shifting to N mode while waiting at traffic signals? If some one can please guide me as to when the N mode should be used, it would be greatly appreciated!
P.S: The car has been driven for about 100kms and the fuel efficiency is around 10kmpl (mostly driven in the city with AC on all the time).
Saanil is online now
Old 19th September 2015, 00:48   #4219
outdoorlover's Avatar
Thanked: 411 Times
Saanil, I've been driving automatics for the past 14 years and would like to answer your queries :
1. You'll find the recommended tire pressures on a sticker on the pillar when you open your driver's side door.
2. You use D for a standard drive and S (sports mode) for a "spirited" drive but lose out a bit on FE. N is for neutral and you use it if your vehicle were to be ever towed. Some folks in India, I've noticed talk about stopping at traffic on N but the is neither required nor recommended.
Hope this helps!
outdoorlover is offline
Old 19th September 2015, 01:18   #4220
CrAzY dRiVeR's Avatar
Thanked: 74,174 Times
Hope this helps!
Energy has to be dissipated somewhere!
When you put the transmission to neutral, the engine just idles away, and is only trying to run by itself without a load. When you put it in gear, you are loading the engine, the transmission and the brakes which work to oppose the other two!
Agreed that the effects are negligible, but isn't it better to just make one small shift to N, specially for those long signals stops? I usually shift to N at signals that have counters in place telling you beforehand when D would be required.
You can get articles on both views online. I found the below one sensible enough-
http://www.topgear.com.ph/features/c...uck-in-traffic
CrAzY dRiVeR is offline   (2) Thanks
Old 20th September 2015, 02:33   #4221
Thanked: 74 Times
So the honda recall issue for faulty airbags that is going on, does it affect the new cars also which are gonna be delivered. I hope we don't get cars with non working airbags. As a few posts back there was a case of an accident where the airbags did not deploy.
Old 20th September 2015, 03:00   #4222
Thanked: 21,425 Times
The news of recall clearly has the period of dates of the affected cars. So nothing to worry on the current manufacturing lot.
As seen in the case of accident, the sensors weren't activated or the accident didn't happen the way it should have to deploy the Airbags. Strange reply from Honda but may be that's how it is.
a4anurag is offline
Old 20th September 2015, 11:01   #4223
anilagdr's Avatar
Thanked: 67 Times
I was interested in installing an ORVM autofold module in my 2014 idtec city and found the following product. Can anyone enlighten me on this or a similar product?
http://www.autolab.com.my/index.php?...roduct_id=1331
4th-gen Honda City : Official Review-autofold.jpg
anilagdr is offline
Old 21st September 2015, 11:44   #4224
Vitalstatistiks's Avatar
Thanked: 725 Times
Originally Posted by Vitalstatistiks View Post
Excellent advice. I will follow up with service centre fellows. Fingers crossed, this works. Will keep the group posted.
Quick follow up. It turned out to be a fairly minor issue. A loose wire not fixed properly behind the steering wheel assembly. 2 minutes, and there's no more "rattling".
One month of ownership and first service later, with 850 kms behind me at 12.5 km/l on the CVT, I am beginning to realise why this car sells in the numbers that it does.
Vitalstatistiks is offline
Old 21st September 2015, 13:40   #4225
adarsh76's Avatar
Thanked: 231 Times
Take to a good highway and there would be a big smile on your face. On 2 lane highways in Kerala the MID displayed up to 20.5 kms/l. The cruise control on open roads is another fun factor
adarsh76 is offline
Old 22nd September 2015, 22:59   #4226
Thanked: 12 Times
I must have missed the manufacturing date ranges for this recall. Can anyone help with this info? Mine is a Nov 2014 made iVTec (V MT). Thanks.
OwnersPride is offline
Old 22nd September 2015, 23:15   #4227
Hey, check the below link.
https://hondacarindia.com/PUD5VG/Mul...erInquiry.aspx
You'll have your City's VIN with you, Right? Just put it in that and Check. If it is listed for the recall then go to your HASS and get it done.
a4anurag is offline
Old 23rd September 2015, 07:42   #4228
kalyan_hyd's Avatar
Thanked: 882 Times
1. Your City's VIN would be part of your RC card/ paper documented as Chassis number, its a 17 letters in length.
2. The link shared will inform you if your car is effected, and if so, the free replacement of the effected part will happen after Oct 12th, 2015. Honda is probably in the mode of transporting the required part from their manufacturing facility all over India.
kalyan_hyd is offline
Old 23rd September 2015, 16:52   #4229
vsrivatsa's Avatar
Thanked: 4,034 Times
Thanks for the update. Can you post the price of this Filter for the IVTEC?
Also check with the K&N Dealer if there is a plan to release a filter for the IDTEC?
vsrivatsa is offline
Old 23rd September 2015, 20:28   #4230
Thanked: 411 Times
The last that I checked, the K&N filter costed was about 6k I think online.
