![]() | #6931 | |
BHPian ![]() Join Date: Jul 2010 Location: CH01 - UK12
Thanked: 567 Times
| ![]() Quote:
Edit: Last edited by PaddleShifter : 5th February 2021 at 09:52. | |
![]() | #6932 | |
BHPian Join Date: Sep 2017 Location: Pune
Thanked: 274 Times
| ![]() Quote:
https://www.team-bhp.com/forum/car-e...cam-setup.html | |
![]() | #6933 |
Newbie ![]() Join Date: Nov 2020 Location: Surat
| ![]() Is the front glass windshield of the IDTEC different in VX model? I was looking for it on bodmoo and I found that the S/SV/V share the same part number while the VX has a different one. The VX version is also expensive. |
![]() | #6934 |
BHPian ![]() Join Date: Mar 2017 Location: Pune
Thanked: 82 Times
| ![]() If I remember correctly VX model windscreen glass had additional heat insulating material to it right from factory that is the reason it is bit of expensive then other model windscreen glass. |
![]() | #6935 |
BANNED Join Date: Sep 2018 Location: Cochin
Thanked: 1,689 Times
Infractions: 0/1 (7) | ![]() |
![]() | #6936 | |||
Distinguished - BHPian ![]() ![]() | ![]() Honda City wins ASEAN NCAP “Consistent 5-star Award”. Quote:
![]() | #6937 | |
BHPian ![]() | ![]() Quote:
I see the light on the remote, so it's definitely problem originating from the remote But it only happens right after I shut the boot. Wierd. I'll clean the board and update. Thanks Maaan do I find this hard to believe, The NVH is terrible, the panels flex and the car doesn't feel very solidly built. How is 5 star even possible?? Could it be possible that there are any structural differences between the Indian versions and the tested cars? I've seen images of a City ripped open by a tree. Didn't instill much confidence in me about its safety rating Last edited by viXit : 17th February 2021 at 22:20. | |
![]() | #6938 |
BHPian ![]() Join Date: Apr 2019 Location: MAA-BOM-DEL-THN
Thanked: 78 Times
| ![]() Call me silly but I too had a similar issue. Turned out the driver seat belt tends to entangle the boot release switch in the cabin and kept opening the boot. I had random times when the boot opened up random when braking or riding over rough patches. Hopefully your issue is resolved by the time you read this post! Had quite a tiring Sunday today. Had a small incident last week wherein a 5 L bottle emptied out in the rear seat footwell. The cabin was relative dry with no foul smell. I Still wasn’t convinced as water removed was faaar less than what was spilled! I’ve got additional rubber floor mat done as well. Successfully removed the floor mat and the rubber mat and have put them out to dry. What should I do next? - Let the mat dry, vacuum it and fix them again or - Get the carpet cleaned from a car wash place as well and then fix it. ( I don’t have dry cleaning facilities in my locality) The car does look quite different with the carpet and the centre arm rest ![]() |
![]() | #6939 |
BHPian ![]() | ![]() Put newspapers on the wet spot. Try to keep your car in direct sunlight .With this kind of hot climate in the afternoons it should dry in about 2 to 3 days |
![]() | #6940 |
BHPian Join Date: Feb 2016 Location: Mumbai
Thanked: 195 Times
| ![]() I just got my 2016 Honda city V MT i-vtec 1 Lakh kms service done at Solitaire Honda, Andheri, Mumbai. Car odo stands at 63,500 kms. The following was replaced:- Engine oil Oil Filter AC Filter Spark plugs Horn replaced under warranty Fog lamps relay replaced under warranty Weak Battery - Needs to be replaced. Honda was quoting me INR 4300/- for Amaron and the same battery costs INR 3300/- at Amaron authorised dealer and hence will get it replaced today. Total Bill including pick up/drop and taxes - INR 10,212/- I found it very reasonable for a 5 year old car. Also, I renewed the 6th year warranty and paid INR 10,312/- including taxes for it. Highly recommended. I plan to keep the car for long and will continue to pay for the extended warranty until the 10th year. Query- One observation by the the Honda A.S.S. was that the clutch is a bit on the harder side and we might have to undertake clutch work(Clutch bleeding) in the next service 6 months later. Since the car is under warranty, should I stick to Honda for clutch work or should I get it done by a renowned FNG Select Auto - Sunil Shanbag in Mumbai? If I go ahead with FNG, Will it affect the warranty? PS- It is not very hard the way Honda A.S.S. is stressing on getting work done for obvious reasons. However, I might get it done 15,000 kms from now. |
![]() | #6941 | |
BHPian Join Date: Mar 2007 Location: Bangalore
Thanked: 1,435 Times
| ![]() Quote:
More than 2 years and 30K KMs have passed and the odo is now at 88K KM and the clutch seems fine to me (read: no slippage), but continues to be a bit hard though. I don't think its an issue. Last edited by for_cars1 : 17th March 2021 at 10:32. | |
![]() | #6942 | |
BHPian ![]() Join Date: Jan 2021 Location: New Delhi
Thanked: 173 Times
| ![]() Quote:
![]() | #6943 | |
My confidence in the car is now very high after the crash test results! ![]() Can someone help me with this. My user manual says to use Honda Diesel Engine oil #2 But I don't know if it's synthetic or not! If someone can confirm this, I will decide whether I should use the oil from honda or buy my own oil. | |
![]() | #6944 |
BHPian ![]() | ![]() Guys, a small problem! Since last few tankfills, I've been observing that my 2014 Honda City iDTEC is giving poor FE whenever I drive and I'm getting around 14-15 Kmpl if I drive in a spirited mode in city limits when compared to 16-18 Kmpl, which I usually get in the city limits. And, I got the 1L Kms service done in the month of December when the odo reading was at 1.02L Kms at that time and the present odo reading as of today is a shade more than 1.06L Kms. The car is mostly driven in city traffic by myself and my mom, who goes to her office every day and has been occasionally driven on highways. Last edited by car_guy1998 : 23rd March 2021 at 20:10. |
![]() | #6945 | |
But one drive to the RGIA and back puts my average back at 25. ![]() Off topic, could you help with my previous post, about engine oil? | |
