![]() | #2536 | |
Senior - BHPian ![]() Join Date: May 2007 Location: Vadodara
Thanked: 2,227 Times
| ![]() Quote:
Unless you face noticeable lack of power across wider RPM range, there is nothing to worry about. | |
![]() | #2537 | |
BHPian Join Date: Feb 2008 Location: Chennai
Thanked: 541 Times
| ![]() Quote:
![]() | #2538 |
BHPian ![]() Join Date: Jan 2007 Location: Pune
Thanked: 311 Times
| ![]() Completed a holiday trip to Kerala from Pune in my 2016 Baleno Alpha petrol, and came back quite impressed with its highway manners. Quite steady and smooth at good speeds ( I was expecting the light weight to create some problems ), and a pleasure to drive, as long as you are not in a great hurry. I did miss the extra kick my i20 Diesel gives when you push it for overtaking maneuvers, but other than that no complaints. Handled bad roads with aplomb, and kids who were in the backseat were quite happy at the end of the journey. No rattles reported at the end of the 3000km drive, and I got an overall FE of around 20.5 kmpl on the display, this inspite of driving mostly in the 100-110 kph range on the highways, and negotiating slow traffic while in Kerala. Loved the free-revving engine with its sporty note when pushed. It is no scorcher, but quite peppy in real-world conditions. Its only on the six-lane stretches that I missed a bit of extra kick. Good headlights were a boon too as I did a fair bit of night driving . |
![]() | #2539 | |
BHPian ![]() Join Date: May 2013 Location: Chennai
Thanked: 581 Times
| ![]() Quote:
Quoting my post I had been to MSM yesterday to get the A/C issue diagnosed. Yes, they acknowledge that something is amiss with the A/C. The moment I switch on the A/C, I hear a faint not so pleasing sound from the left most vent. The sound is something similar like 'hoosh-hoosh'. Also, when the car is driven over bad roads, we can hear a loose bolt/screw noise from the same left most A/C vent. The SA at MSM says that the entire dashboard needs to be removed to check the root cause and he's isn't too comfortable doing this as the car is just 18 months old. I'm still not sure as to how this issue suddenly came up ![]() Yes, the roads between Bangalore-Mysore are not great, but could dropping the car over couple of potholes create this issue? BHPians - Need your inputs/analysis | |
![]() | #2540 |
Senior - BHPian ![]() Join Date: Sep 2009 Location: Bengaluru
Thanked: 1,779 Times
| ![]() You car is under warranty and it's their responsibility to find the root cause and fix it regardless of how comfortable he is. If they are not comfortable, give it to a better service center. With Maruti, you are never short of choice with regards to competent service centers. |
![]() | #2541 | |
Thanked: 581 Times
| ![]() Quote:
![]() | #2542 |
![]() | #2543 |
BHPian Join Date: Jan 2016 Location: Bangalore
Thanked: 70 Times
| ![]() Completed 2nd year 20K paid service yesterday. Even though my car has run only ~8K, followed the service as per the schedule for warranty purposes. Avoided wheel balancing and alignment, probably will get it done outside. There used to be a jerk when clutch is depressed in 1st and 2nd gears, now that is completely disappeared(after a run of 6-7K Kms). Only a small annoying issue remaining is the rattle from rear parcel shelf when going over uneven roads. Total cost was Rs 5.8K and in that ~2.9K was labour part itself. |
![]() | #2544 |
Senior - BHPian ![]() | ![]() I have noticed the same today. I am sure it was not there before. Planning to get it checked in few days at service centre. |
![]() | #2545 |
BHPian ![]() Join Date: Apr 2006 Location: Chennai
Thanked: 155 Times
| ![]() Have you checked if turning the circulation mode on or off fixes the issue ? Last edited by Eddy : 7th January 2018 at 20:12. Reason: u=you |
![]() | #2546 |
Senior - BHPian ![]() | ![]() No it doesn't. The sound is always there from left most vent. I thought AC blower initially, but no sound if I completely close the left vent. I will try to record the sound and post it. Last edited by Dr.Naren : 7th January 2018 at 21:29. |
![]() | #2547 | |
Thanked: 155 Times
| ![]() Quote:
I can think of 2 possiblities - HVAC air flap motor getting struck in weird position- which you ruled out. -some packing material has become loose or some external object in vent airflow path. Last edited by Aditya : 9th January 2018 at 08:38. Reason: u -> you. Please avoid use of SMS lingo in your posts | |
![]() | #2548 |
Newbie Join Date: Jul 2007 Location: chennai
Thanked: 18 Times
| ![]() Got our silver alpha CVT towards the end of December. Been on a 1200km trip this weekend and the car performed absolutely well. Everyone liked the car at home Likes -Smooth drive, easily can cruise at 120 for a long time -The headlamps are brilliant - the mid showed 23kmpl on my return from trichy to Chennai cruising at 90 - android auto integration - free revving engine - performed well over bad roads between Madurai and rajapalayam Dislikes - you don't really hear the engine note till 3500. - the sport mode does nothing except holding the rpm at 4k -the egress for elderly is a bit difficult -the missing low end torque - rubber bad effect at low gears especially, but livable for a city The car though holds stable at 160, but brakes does not inspire confidence to take it beyond 120. If you are sedate driver who would be happy to cruise all day under 120. Unlike many comments I received, the car remained rock solid and planted with higher speeds. Overall happy with her so far. Planning to put a ownership report sometime soon. |
![]() | #2549 | |
Senior - BHPian ![]() | ![]() Quote:
![]() audioholic has explained this and posted about DIY cleaning in Wagon R here http://www.team-bhp.com/forum/diy-do...on-blower.html | |
![]() | #2550 | |
Thanked: 581 Times
| ![]() Quote:
So, do you mean to say that cleaning the blower will solve the problem? Also, is the blower in Baleno located in the same position as mentioned in audioholic's DIY thread? | |
