Log In
Register
Old 23rd December 2021, 20:28   #2791
CEF_Beasts's Avatar
Thanked: 20,491 Times
Re: Toyota Innova Crysta : Official Review
Originally Posted by Wheels View Post
I could not see any edit option in MID control in GX variant. Long pressing Display button just move to next display item.
Try using this button (circled in red) near the base of the speedometer, maybe long pressing it on the L/100km unit may change it to kmpl.
Toyota Innova Crysta : Official Review-innovacrystagx.png
CEF_Beasts is online now
Old 24th December 2021, 09:45   #2792
PrideRed's Avatar
Thanked: 10,800 Times
Attachment 2248883
You have to press DISP button on steering, click multiple times which should land you at settings. There is option to toggle L/100 to KMPL. You cannot make these changes while the car is in motion as settings is disabled.
PrideRed is offline   (2) Thanks
Old 24th December 2021, 10:11   #2793
DicKy's Avatar
Thanked: 16,100 Times
Anyone knows how to
1) Change Lt/100KM to KM/Lt in MID for GX variant in OEM Touchscreen infotainment?
The DISP button on steering wheel.
Long press.
Settings.
Units.
L/100km - km/l.
3:55
DicKy is offline   (4) Thanks
Old 24th December 2021, 21:36   #2794
Thanked: 43 Times
Long press.
Settings.
Units.
L/100km - km/l.
3:55
https://Youtu.be/gljrfigsFiM
This worked. Thanks and couple of doubts:
1) When i went thro the manual, it is mentioned to touch unpainted metal part before opening fuel lid to remove static electricity to avoid fire hazard. Is that for us or to the fuel pump representative?
2) Avg. fuel consumption - Is it based on last 15 min actual driving distance?
3) How do we come to know that there is an upgrade to the touchscreen unit software?
4) Does it have only 1 USB drive port?
5) Do rear wiper has washer?
6) Is the washer liquid = water? If not, where can i get it to topup?
7) I dont hear auto door lock sound once i start driving. Won't it auto lock after 5km/hr speed?
Wheels is offline
Old 25th December 2021, 06:51   #2795
sridhu's Avatar
Thanked: 2,756 Times
Most of these questions are answered in the manual.
That bit of pontification aside, let me see if I can give you some answers inline.
For whoever is filling up. IMO, not a very big issue in the southern parts of the country but it is possible for sparking to occur due to static electricity.
From the beginning of this drive
No real way AFAIK. The ASC updates it as it becomes available. You find out when your phone no longer connects on bluetooth.
2. One on the back of the center hand rest.
Yes. Twist the RHS stalk away from you. Also has an icon on the stalk indicating that.
There is a washer fluid.
All ASCs of all manufacturers are famous for charging you about ₹ 120 for 50 ml for adding it.
You can get a full bottle for about 200. I use this
Sonax 371141 Clear View Windscreen Washer
Or add a sachet of shampoo to a full container of water.
I dont know if this feature has been introduced now but in my Vx this is not there. If you want it you can get a Chinese OBD add on to do it. I have it on my Jazz.
sridhu is offline
Old 25th December 2021, 15:15   #2796
Thanked: 43 Times
Q: Do you meant to say LHS?
Q: Can i just use water which i used to do in my old car..
Wheels is offline
Old 25th December 2021, 17:22   #2797
karthi.stark's Avatar
Thanked: 509 Times
If you wish to use water, then I would recommend adding a cap of Lizol or related product for every half-bucket of water you use in place of wiper fluid. That is what we do with our own Innova Crysta all the time and it works as good as the wiper fluid.
karthi.stark is offline
Old 25th December 2021, 18:31   #2798
sridhu's Avatar
Q: Do you meant to say LHS?.
Yep!
Of course! It is your car!
But a mild surfactant helps clean the windshield and keep it clean. Like I said a shampoo satchet willdo just fine
sridhu is offline
Old 1st January 2022, 21:27   #2799
Thanked: 21,259 Times
Regarding NVH of the Crysta:
Over the last few weeks due to lot of travelling, I got to be driven around in four different Innova Crystas and three Innovas. Each of them sounded differently and I couldnt understand this. Of course they had different kms on the odo ranging from 37k Crysta which was the most silent, to a the Innovas around 150k kms and then a Crysta at 175k kms which had a clatter similar to my car at 14k kms. Have any of you observed the same? What could be a reason for this difference? It was definitely not the clatter of a cold engine since I have spent at least 100kms on each car. Even the Innovas I travelled in had different levels of engine noise, different turbo whistle. Of course none of the cars had engine work done which is expected but this engine sound difference really puzzled me.
The 37k kms run Crysta had an engine note of the Etios which was very silent and refined which made me think my car had some issue. But the rest of the Innovas had a similar engine note as mine.
audioholic is offline   (3) Thanks
Old 1st January 2022, 22:06   #2800
CEF_Beasts's Avatar
Any chance the 37k kms run Crysta had aftermarket damping done and/or floor lamination done? Then it’s possible that the NVH was lower compared to the other Crysta’s.
Also were the Crystas BS4 or BS6?
Old 1st January 2022, 22:33   #2801
These were all cabs and am pretty sure its not about damping. The 37k kms Crysta was a BS6 manual and there was another Crysta with 39k kms which was also BS6, but the first one hardly had diesel clatter and was silent while the latter was having higher noise. But yeah floor lamination was present on both cars. The NVH when windows rolled up was same in all cars. But the prominent difference was in the way the engine sounded.
Old 2nd January 2022, 21:07   #2802
SKannan's Avatar
Thanked: 89 Times
One quick question on the roof carrier - I plan to go for TGA roof carrier, but strangely the service advisor was against recommending the same. He said it will lead to rattles and squeaks apart from not so good aesthetics !!!
I tend to travel with 6 adults + luggage frequently. I believed the TGA carrier would be comparatively better choice than after market carriers like the roof hugging slim carriers which look aesthetically good, but not sure about their quality & performance.
Any suggestions please.
SKannan is offline
Old 2nd January 2022, 21:36   #2803
PrideRed's Avatar
Originally Posted by SKannan View Post
One quick question on the roof carrier - I plan to go for TGA roof carrier.
Get a roof box and bars from reputed brand like Thule,Farad. They will be bit more expensive but are aerodynamic, have good after sales support and looks good too.
PrideRed is offline
Old 3rd January 2022, 02:15   #2804
GautamJ's Avatar
Thanked: 869 Times
As mentioned by BHPian CEF_Beasts, I suspect the service schedule. Though not sure, but it seems to be the only thing differentiating factor IMHO.
GautamJ is online now
Old 3rd January 2022, 11:42   #2805
Leoshashi's Avatar
Thanked: 43,623 Times
Guys, for new facelift Crysta, what is the size of Fog lamp it takes? The stock cutout in GX looks a bit small than standard 3 inch fog lamps.
Confused after seeing these pics:
This looks like 3 inch fog but not sure if its OE or the shroud has been cut to accommodate it:
Toyota Innova Crysta : Official Review-2021toyotainnova1068x703.jpg
ZX ones look way too small:
Leoshashi is offline
