Old 25th April 2022, 15:58   #2986
amalji's Avatar
Thanked: 3,261 Times
Re: Toyota Innova Crysta : Official Review
Originally Posted by sreejinair View Post
Did any one of you do oil and/or oil filter change after the first 1000 kms? My first 1000 kms service/check up is due and was wondering if I should change it. Yes toyota has engine brake-in period as per its user manual and no the service schedule doesnt mention changing oil at 1000 kms.
I normally stick to Toyota schedules strictly which means I did not change the oil at 1000 kms and instead waited till 10,000 kms.
One exception I have to the above rule is using Toyota Synthetic Oil instead of the regular mineral oil. All other replacements, I stick to the user manual recommendations strictly.
PS: Some of the replacement intervals also have a timeline attached to it and not just the kms. For example, the brake fluid replacement is 40,000 kms / 2 years whichever comes earlier. The Toyota software will miss the replacement in a regular service if the time has breached, but kms hasn't. So be mindful about that and ask the service advisor explicitly if they miss it out during the estimate. Happened to me during 60,000 kms service. The estimate missed the brake fluid replacement even though it has been more than 2 years since the last replacement. I had to educate the service advisor to get it replaced.
amalji is offline   (1) Thanks
Old 25th April 2022, 16:27   #2987
sreejinair's Avatar
Thanked: 409 Times
Where did you find the toyota synthetic oil? Attaching the file they have at the service center.
Toyota Innova Crysta : Official Review-20220425_161733.jpg
sreejinair is offline
Old 25th April 2022, 16:44   #2988
cs_rajesh's Avatar
Thanked: 331 Times
I had the same reply from Nandi Toyota dealer in Whitefield Bangalore, that it is not recommended by Toyota to change oil but one can also do the change on own accord. I insisted change of engine oil (after 1500 Km) and paid for the change and I am happy that I did it.
cs_rajesh is offline   (2) Thanks
Old 25th April 2022, 17:11   #2989
PrideRed's Avatar
Thanked: 10,218 Times
For BS4, Toyota has option of Mineral or Synthetic, where as BS6, there is no option. BS6 oil supposedly is synthetic, however I am no expert. The price is higher than BS4 mineral, almost double.
PrideRed is offline
Old 25th April 2022, 17:23   #2990
sreejinair's Avatar
Thanked: 409 Times
The photo I posted above is for the BS6 version and its not synthetic oil.
Old 25th April 2022, 17:42   #2991
PrideRed's Avatar
Yes, that's the only option available with Toyota for BS6. I am not sure if this is Mineral or synthetic or a blend, recall someone telling this is synthetic. The price though indicates this might not be mineral oil, which used to cost around RS 300/L.
PrideRed is offline
Old 25th April 2022, 18:18   #2992
Thanked: 20,612 Times
That would be synthetic with low ash content to suit the DPF. If earlier oils are used then it's a farewell for the DPF. Also it's not correct to judge oils by their price. Synthetic oil is not always expensive in today's market. What matters is the viscosity range and the grade. Higher the viscosity band , more expensive will be the oil. For 5W30, the cost would be on the lower side. Not the same for 0W40 or 5W40 which would be expensive.
audioholic is offline
Old 25th April 2022, 20:45   #2993
PrideRed's Avatar
For same grade, i believe synthetic will cost more than mineral oil? Like 5W30 synthetic will be expensive than 5W30 mineral. Toyota for quite sometime now has been using 5W30 as I know, may be 5W40 long ago.
PrideRed is offline
Old 26th April 2022, 07:19   #2994
Thanked: 29 Times
Originally Posted by smasher View Post
I have tein edfc active installed in my Crysta 2.8z. This is how it works.
May I know if there is any change in height compared to stock suspension. Thanks
kevintomin is offline
Old 27th April 2022, 01:13   #2995
Thanked: 183 Times
Lovely picture. Reminds me of the numerous journeys in our former car, a 2006 Tata Safari.
I think the unladen ground clearance is lower than 180mm in the Crysta. Did you face any issues with this during mild off-roading?
dearchichi is offline
Old 27th April 2022, 09:58   #2996
Has never been an issue so far. In fact I have the side steps installed and it has never scraped that as well. But I do not fly over humps and potholes and its a smooth crawl especially if the car is fully loaded in the interest of the third row passengers. Guess that works.
audioholic is offline   (2) Thanks
Old 27th April 2022, 15:54   #2997
Thanked: 84 Times
Since last few services of my 2017 Crysta 2.4 V, the service centre has been using BS6 engine oil which is costs over INR 4500. Earlier the oil change used to cost INR 2800. I was told by the service centre that all Crysta's be it BS4 or BS6 will be using the new expensive oil as per Toyota's directive. I found that counterintuitive but let them go ahead. Today I was going through the service cost calculator on Toyota's website and found that on selecting non BS6 crysta, the oil change was for INR 2800 while for BS6 crysta it was INR 3900. Wanted to check with other BS4 Crysta owners if they too are using the expensive oil or continuing with the original recommended oil. I hope the service centre has not been scamming me because I explicitly asked during my last service why are they not using the oil they used to. Also I hope the engine oil grade is same for the two and it hasn't caused any adverse affects as it may have been done atleast twice if not more.
Tourer is offline
Old 27th April 2022, 16:49   #2998
Thanked: 188 Times
Mine is 2019 Crysta 2.4 G.
Last oil change was done 9-October-2021 (during 20k service).
Engine oil expense was 2214+tax (approx 2613).
kavu75 is offline   (1) Thanks
Old 29th April 2022, 20:19   #2999
5252rpm's Avatar
Thanked: 529 Times
Will both of side of Crysta's 2nd row tumble (variant without captain seats)? Noticed that my office cabbies are only flipping the right side of the 2nd row seats to get passengers out from 3rd row and they says that other side is fixed. This is highly dangerous for a RHD country and I don't think Toyota will do it. Any inputs will be helpful. Been noting this for a while.
5252rpm is offline   (1) Thanks
Old 29th April 2022, 21:26   #3000
Thanked: 188 Times
We can tumble both the sides. It's 60:40 split with slide and one touch tumble.
kavu75 is offline   (2) Thanks
