Old 4th November 2024, 20:04   #3826
humyum's Avatar
Thanked: 5,618 Times
Re: Toyota Innova Crysta : Official Review
Originally Posted by Innysta View Post
Key updates from 40k km service done @Harsha, Pallavaram:[list=1][*]ECU software updated (please check the image below) - It's unfortunate
This is interesting, did they tell you what did they upgrade it for? Anyone else having any idea on the upgrade? Mine is a 2022 October 2.4 Diesel AT Crysta.
humyum is offline
Old 4th November 2024, 23:11   #3827
Thanked: 47 Times
Here you go. Gloss Mech service sounds to be bit costly, not worth of the money - probably could have done by myself. They just sprayed liquid grease in door joints.
AFAIK, The T-Gloss Mech is a name given to the particular job which involves the ECU update. They don't do anything else apart from it. Check with your SA and he will say the same.
Jack Sparrow is offline
Old 6th November 2024, 12:42   #3828
Thanked: 85 Times
Originally Posted by swarnava.ch View Post
Do you know what is this ECU update meant for ? Any specific complaints that you had based on which they updated ECU or any specific improvements or changes that this update brings ?
As per SA, It's more for engine performance which in-turn efficiency.
No. T-Gloss is the name for car-detailing. In my case, it's for the lubes in door hinges. Check the website for more details.
Innysta is offline
Old 6th November 2024, 13:09   #3829
humyum's Avatar
Which year model is your car? Its a Diesel Auto/Manual?
humyum is offline
Old 6th November 2024, 20:11   #3830
me@fiat's Avatar
Thanked: 143 Times
Hello Guys,
Just want to check if one can swap the Crysta Gx variant headlights and cabin lights with Z variant headlights and Cabin lights?
Do we need any modification in wiring or simply just plug and play?
me@fiat is offline
Old 6th November 2024, 21:42   #3831
Thanked: 529 Times
Originally Posted by me@fiat View Post
Hello Guys,
Cabin lights would be relatively easy except for the ambient light. Unfortunately, headlight swap would be very difficult. Z and V come with Auto Levelling and that would require level sensors .
blogslogger is offline   (2) Thanks
Old 6th November 2024, 22:55   #3832
me@fiat's Avatar
Thanked: 143 Times
Thanks buddy.
So at the max auto leaving wouldn't work. but we should be able to plug and play rest all. correct? I see quite a few videos on you tube which claims fitting the OEM Z variant headlamps on Gx.
while for cabin lights - infact making the ambient light work was the main aim.
has anyone tried it?
me@fiat is offline
Old 6th November 2024, 23:08   #3833
Thanked: 529 Times
Thanks buddy.
If getting a projector setup is the aim, there are far better options. You can contact FE retrofit for projector setup retrofit which offer far better lighting performance.
blogslogger is offline   (1) Thanks
Old 6th November 2024, 23:17   #3834
me@fiat's Avatar
Thanked: 143 Times
I have a nice projector setup in the Fog lamp and even have upgraded upper and lower lamps with LED. but just love the looks of OEM Z headlights. + in OEM low beam comes with the projectors hence inclined towards it.
me@fiat is offline
Old 8th November 2024, 18:27   #3835
rakesh_r's Avatar
Thanked: 3,278 Times
As per this gentleman, AT GB costs 9 lacs , time stamp 4:27.
On a different note, it is always better to get the AT oil changed.
rakesh_r is offline   (2) Thanks
Old 12th November 2024, 11:58   #3836
Thanked: 74 Times
Quick question - I have a cracked windshield on my 2022 G AT Diesel. Anyone replaced the windshield? anything I should take care of while the ASC replaces it? what does it cost and how much time?
slylenser is offline
Old 12th November 2024, 12:56   #3837
PrideRed's Avatar
Thanked: 10,216 Times
I had replaced couple of years ago, costed about 18-20K back then. I had claimed insurance and was charged 2K . Installation takes about 2 days as the glue has to dry before delivering. Most likely you have to get a new fast tag and RTO registration sticker if you have one.
PrideRed is offline   (1) Thanks
Old 12th November 2024, 13:02   #3838
varun560061's Avatar
Thanked: 176 Times
Headlamps are direct fit and your manual alignment coupler can fit the Z variant HL's. But suggest you to stick to G version HL's or get better projectors installed as mentioned by few here. Low beam illumination is pathetic in Z variant HL's.
Cabin lamp is not plug and play, needs wiring modification.
varun560061 is offline
Old 19th November 2024, 20:08   #3839
Thanked: 85 Times
GX 2021, Manual Diesel
Innysta is offline
Old 20th November 2024, 11:13   #3840
humyum's Avatar
Do you feel any change after the update?
humyum is offline
