Originally Posted by veyron999 My troubles with the car so far:
1) There're quite a few squeaks and rattles which makes me super unhappy.
There's one from the driver side door, one from the front left door, one from somewhere behind the dashboard, near the footwell, which I am just not able to identify which keeps coming, sometimes even while idling (it's more like a squeak). Another one caused by the speaker grill on the left side of the dashboard. The speedo console every now and then buzzes as well.
I am really not sure if I have super sensitive ears, or if this is common across a lot of JCs. I have come across some posts on this, but not too many.
Anyone who has faced this/solved this noisy cabin thing, please help.
2) The lights on the sun blinds do not seem to work on my car. Am I missing something here? Tried everything possible (day/night time, ambient lights on/off, headlights on/off).
3) The HID bi-xenons are weak, sadly. The throw doesn't go too far on completely unlit roads. On dimly lit roads, the focus/intensity is lacking. Is there any quick, cheap, non-intrusive upgrade possible? New bulbs maybe?
4) The parcel tray does not stay tethered to the tail gate. Once you open the tail gate, the parcel tray falls off, and I have to tether it back again. Seems like it is too heavy for the small protrusions on the inside of the tail gate.
5) Transmission noise I mentioned above.
6) The tyres will surely not work off the road. I had one tyre burst when I accidentally curbed the wheel against a divider. My bad here for sure, but it was surprising how easily the sidewall ripped. Another tyre has a crack for some reason.
Replacement tyres are expensive, and there's little to no choice. Has anyone upgraded to 235/55 or a more common size?
So far I am not able to focus on the good bits because of these issues. Hope they can be resolved soon. Any help/inputs are deeply appreciated. |
Let me try to help you out with some of these issues, based on my experiences. I am one of the oldest JC owners here on TBHP and my ownership thread is here:
https://www.team-bhp.com/forum/test-...2-limited.html
If you go through my thread, you will find solutions to some of the problems you are facing.
But let me quickly tell you some of the solutions for some of these issues:
1) For the squeaky and rattly doors, two things to be done - Get the Talbros Silicone spray (you can find it on Amazon) and spray it liberally on all the door seals and beadings. This lubricates the strips and prevents them sticking to body and reduces the creaky sounds. Also on the Door locks, you have to grease the locks well and on the latch (which is on the body), apply a few rounds of duct tape to reduce play. This prevents the doors from rattling
(I have explained and shown pictures of both the above on my thread)
Also, you can also spray the Talbros spray in all areas like the dashboard to prevent squeaks. Spray it especially in the sides where the dashboard meets the A-pillars (on the inside)- this area is a big culprit.
2) I don't think the sun blind lights are functional as they don't operate even on mine. Maybe in higher versions they work, but they are non operational even in my Limited Variant.
3) You are lucky to have the HID BiXenon, as they are better than the Limited version halogen projectors, which were absolutely pathetic, with half the light that you have. In my case I upgraded my Halogen projectors with 42W HID 4200K Retrofit kits, which has 3x the light of the original Halogen bulbs. But in your case that will not be possible as you have OE HID lights. In your case, I would recommend two things. Get 4200K HID bulbs of the same type (as OE) and swap them out. This will improve visibility as the stock bulbs are 5700K and visibility with these Bluer lights is lesser, especially in bad weather.
Also, second thing which you can get done is to have your foglights aimed higher (there is an adjustment screw at the bottom, the details are also on my thread). The foglight bulbs are 55W and actually have a lot of light, but there light is wasted as they are aimed too low in front of the car. If you have it adjusted it a bit, it will greatly improve your low beam visibility by filling in the area close to the car.
4) This should not happen - in my car the parcel shelf strings are firmly tethered to the bootlid and never fall off. Probably they are not fixed properly in your case. Push them in a bit with force and they should click in place. Once locked, they don't come off easy!
5) Transmission noise - Mine is a manual variant so haven't faced this. But in AT, I have heard about others also experiencing this and this could be normal. Also as yours is a 4x4, it maybe the 4x4 transmission which makes some noise, which is common as it diverts torque a bit when its senses even the slightest wheelspin.
6) On tyres, my recommendation will be to swap to Falken Wildpeak tyres in stock 225/60 R17 size as they are very good for Onroad and Offroad use (50/50). The sooner you do this swap, the better will be the exchange value of your current tyres. For now, avoid upsizing to 235/55 R17 as the ride will become harder and uncomfortable.
If your usage is mainly city and good roads, you can also go for Yokohama Earth1 in stock size. These are softer and less noisy than the above option, but less suitable for bad roads.
Hope you are able to resolve some of the issues you are facing and enjoy the car much more!
