| Search this Thread |
![]() | #211 | |
BHPian Join Date: Jun 2022 Location: Pondicherry
Thanked: 226 Times
| Re: Maruti S-Presso : Official Review Quote:
Regarding to your queries following are my takings:( before going for additional electrical gadgets , better to keep the warranty in mind.Since booking is for AGS version better go for extended warranty as AMT box cannot be trusted). 1. Regarding the inside mirror , I don't have much idea as I never wanted to change the original setup which is adequate for me( wife too).. 2.Regarding reverse light, adding the second one is better than having only one but I think there is no provision on the other side without cutting wires. No wonder dealership refused to do. 3. Yes .. the Maruti supplied rear view camera ( for 5600/-) is a crap and one can get good ones for even half of that price outside. There are lot of models to chose from( looks like all are made in china including branded). There is a seperate topic available here also. All of them require a special connector to connect to Smartstudio which Accessories shop should be able to provide. 4. Yes .. if you add front wheel cladding , u cannot install front mud flaps. First the wheel cladding blocks the screw holes of mud flaps. Secondly there won't be enough space between the body and the front tyres. ( Requires a special thin mud flap like Kwid). 5. Suzuki Smart Studio has provision for 4 speakers and rear speaker wires are terminated at a connector behind the B Pillar panel ( between the rear door keels and front passenger seat belt). This connector will have 4 wires oneside and 2 wires on the other side. Missing 2 wires are for rear speakers ( need to connect extra wires from this connector to the speaker hole behind rear door panel through the door ). 6 inch speakers can be connected. Only problem is there are no holes on the door panel so holes can be drilled in speaker pattern or speaker cover to be fixed. If subwoofer is to be used, amplifier setup is required .Since you are yet to get the car, try to use as it is for sometime and then add rear speakers and then subwoofer ( if required). But I generally recommend not to do expensive setups for this car which basically a small inexpensive car. For me ( though I have 2 pairs of good extra speakers) front speakers are enough and very crispy ( though I am what one calls " audiophile" but I find as a driver one has limited enjoyment in music inside a car). The current Harman unit with 2 front speakers satisfies my requirements ( may try to add rear speakers as DIY project once warranty is over since I do maintenance of all my vehicles myself). Our Spresso has wheel cladding, door claddings, door visors, rear chrome panel, front chrome fittings, seat cover, rear camera, floor PVC cover, rubber mats and steering cover ( if I had the deciding power I would not have added any one of outside fittings). I believe in keeping things simple. Latter added dashcam( DDPai) as I drive in highways mostly.Though I don't know much about Bangalore , in JC road lot of Accessories shops are there. Also heard that Konark's( Jaynagar) and Glamour( Koramangala) are good too. Wishing happy miles.. Last edited by kvsneela : 31st March 2023 at 19:39. | |
The following 3 BHPians Thank kvsneela for this useful post: | darkfantasy, harbinder_s, manij |
![]() | #212 | |
BHPian | Re: Maruti S-Presso : Official Review Quote:
Also after installation the filter is a bit loose on the top and bottom side although it has a snug fit on the sides, is it normal? | |
![]() | #213 | |
Thanked: 226 Times
I got the AC filter from the dealership service centre itself when I went for second free service( 6 months). There is one MGP distributor in Pondy but he didnot have the stock . Then I tried to order through the Maruti Accessories website but it took the link to the dealer only( there is only one dealer in Pondy).When I enquired with dealer , i was told to take it directly from the service centre as online ordering will be costly (325/-). But in service centre I was charged with RS 164/- + 28%GST which will be around 210/-.. After installation it will be slightly loose only( should not be tight fit).. Hope you have installed in correct direction ( up mark towards top and front side).. | |
The following BHPian Thanks kvsneela for this useful post: | darkfantasy |
![]() | #214 | |
Thanked: 226 Times
After some reasearch regarding the guidelines missing , I could conclude that there is no problem with the Harman system. These guidelines are provided by the camera unit. The OEM camera for Alto, Spresso, Celerio and probably WagonR( 5600/-) does not have that provision. Same time camera supplied for Swift, Dzire, Baleno is different ( 7700/-) and provides guidelines( for same Smart Studio unit). Anyway these guidelines are not dynamic ( don't show the direction as per the front wheel position ). So does not make much difference. After market camera ( with provision)shows guidelines in the same unit. Last edited by kvsneela : 1st April 2023 at 08:18. | |
![]() | #215 | |
BHPian ![]() Join Date: Mar 2009 Location: Bangalore
Thanked: 99 Times
| Re: Maruti S-Presso : Official Review Dear Kvsneela, Thank you very much for the reply! I have taken delivery of the car couple of days ago. Fully aligned with all your feedback, including on the stock speakers. They are decent and LOUD (seems very loud even on low volume settings). But if I get to it, want to check if upgrading brings any more joys. From some youtube channels, I see people have fit active subwoofers like 'Zoook Moto69 MonsterX1' in S-presso without external amplifier and seem happy with it. Quote:
Been trying to check out 'Dolby Atmos' for cars, which seems to have been introduced couple of years ago. The marketing and reviews say that cars are apparently the second best place to hear with Dolby Atmos effect, next only to theaters. Though not been able to find India specific products/availability yet. | |
![]() | #216 |
BHPian ![]() Join Date: Oct 2014 Location: Patnitop (J&K)
Thanked: 688 Times
| Re: Maruti S-Presso : Official Review I am considering getting an s-presso for a daily small town runabout in the Himalayas and I had few questions for the owners. 1. S-presso international variant comes with rear adjustable headrests. Is this a part that can be retrofitted to the Indian model? If so which one. A link (boodmo) etc would help ![]() 2. Has anyone bothered to calculate or knows what the approach / departure and breakover angles are? 3. What is the max tyre upsize that one can go for, with standard suspension without them fouling with fenders at full lock ? Finally 4. Is there a suspension kit available in india that stiffens the suspension a tad bit? Last edited by antihero : 11th April 2023 at 16:50. Reason: Grammar |
The following BHPian Thanks antihero for this useful post: | rjtourer |
