Old 8th January 2022, 15:45   #286
RavenAvi's Avatar
Thanked: 47,321 Times
Re: Tata Altroz 1.2L Turbo-Petrol Review
Originally Posted by PrasannaDhana View Post
I am not getting it. Isnt it the same eco mode button? What am I missing?
From the official brochure.pdf:-
i-Turbo:
Normal 1.2 NA:
Which one does it resemble?
RavenAvi is offline   (4) Thanks
Old 9th January 2022, 08:53   #287
tanbeamer's Avatar
Thanked: 628 Times
A DCT with the Nexon tune of the 1.2 turbo-petrol in the Altroz is all that I want for a perfect hatchback. The car already has sorted dynamics, just needs the right amount of power to be a proper alternative to something like the N line DCT
tanbeamer is offline
Old 12th January 2022, 15:35   #288
Thanked: 428 Times
Any idea at what RPM does the turbo kick in? (Couldn't find it in owners manual). Felt driving in city traffic a little tricky (lower pickup than expected) than my prior NA engine and had certainly felt the pickup to be better on the test drive vehicle(must confess In driving only in city drive mode and haven't yet engaged sports mode- as the vehicle is still in its running-in period).
Not sure if this is just the turbo lag that I should get used to- or am I overreacting and should allow the engine to run some more and familiarise myself with the driving dynamics more (present ODO 200kms)? Does changing the spark plug(as had been tried with NA petrol) help, considering it's the same 1.2L revotron engine? Did enquire about ECU updates- there are none for iTurbo.
A follow-up post to my prior one. While experimenting with features of the new vehicle, found out that both pick-up (from stationary state) and fuel efficiency get a big boost (latter climbing up from 9kmpl to 14kmpl in MID, on the same route, at the same time of the day with nearly equivalent traffic). While a bit of it is expected as usual with AC turned off with any vehicle, I found the difference rather exaggerated- even the turbo kicking-in in mid-range (2500RPM onwards) is much more pronounced. Also, below 2000RPM, one can easily and comfortably move around in city traffic, with lightest of the pedal taps with light foot- the engine suddenly becomes much, much more responsive. Is this something experienced by fellow iturbo users, or is there something abnormal with my AC module? Planning to have the latter checked when the vehicle goes for first service soon.
Nikhil Beke is online now
Old 13th January 2022, 18:47   #289
Thanked: 126 Times
I think you should give it some time. You haven't done a lot of kms yet, so give it a while for the engine to bed in.
What I've observed is - at least as per the MID - keeping it between 1000 and 2500 rpm helps keep the kmpl between 15 and 17. This was in city mode. In Sport mode, it reduces by quite a bit (but you're also egged on to drive more aggressively). City mode has ample and more torque to even do runs on the ring road and some highway runs.
SavoyWalrus is online now   (1) Thanks
Old 21st January 2022, 13:50   #290
Venkatesh's Avatar
Thanked: 41,966 Times
Tata Motors to introduce the automatic variant of the Altroz soon.
Shailesh Chandra, MD, Tata Motors Passenger Vehicles Ltd., and Tata Passenger Electric Mobility Ltd., said, “From a product perspective, there are certain options that are missing from our portfolio. The Altroz hatchback doesn't have an automatic transmission, so we have to fill this open gap.”
Tata Altroz automatic is expected to use a 7-speed DCT unit
Source
Venkatesh is offline
Old 22nd January 2022, 20:43   #291
Thanked: 428 Times
Wanted to buy a tyre inflator for my Altroz iturbo and went through this amazing thread https://https://www.team-bhp.com/for...foot-pump.html
Any thoughts if I buy a new one from Amazon or just use one that comes with Tyre puncture mobility kit provided by Tata? The thread mentions it's a very slow process to fill air with the OEM one.
There's also a mention of mismatch between the wattage required by the inflator (e.g. 150W, Bergman Typhoon digital) and the same that's safely permissible on 12V socket (especially with Maruti Suzuki vehicles-120W) with some senior members warning blowing up of the fuse.
Are Altroz 12V sockets compatible with an inflator with 150W wattage? Couldn't find this information in user manual of the car.
Also, any suggestions for a good brand/model? An inflator that offers AC/DC power option would be interesting. Don't think Mi inflator(although appears very portable) would help in emergency- as in with a flat tyre.
Old 25th January 2022, 12:06   #292
Thanked: 126 Times
Powerdrift pitted the iTurbo against the i20 Turbo and surprisingly beat it the second time around. And that too with an impressive time of 11.8 to 100kmph, on a damp track. It gets off the line much quicker than the i20, but the Hyundai eventually catches up.
SavoyWalrus is online now   (4) Thanks
Old 25th January 2022, 14:39   #293
yesyeswe's Avatar
Thanked: 2,069 Times
https://www.Youtube.com/watch?v=ZyQH...ist=WL&index=6
And not to forget the fact that Altroz has 10 bhp less power and 32 Nm of less torque!
Moreover it costs significantly less and is GNCAP 5 star rated as well.
Altroz i turbo is a great buy
yesyeswe is offline   (2) Thanks
Old 25th January 2022, 14:53   #294
Thanked: 126 Times
I think a remap to get a little more low-end torque and clearing one or two weak spots during acceleration would make it perfect. And maybe a different end can to make it sound a little more aggressive
Old 5th February 2022, 13:51   #295
Thanked: 428 Times
In my short experience with my cousin's Altroz turbo what I had noticed was city mode was useless in city conditions, the car really feels slow and laggy. I always used the sports mode in city conditions, don't worry, it won't hurt the engine, keeps the revvs low and be gentle with the throttle, that's all.
This advice was a godsend! After having completed the running-in period of the car, am driving the car exclusively in sports mode since last couple of days. It makes life in stop-and-go traffic so much easy! Gentle throttle taps followed by coasting is all that's required! One gets to enjoy the torque, even at low revvs- something that's sorely missed in so-called city mode(Started imagining what it would feel like in Altroz EV)Surprisingly, the fuel efficiency doesn't seem to have suffered a lot(at least by ICE/connectnext figures- shows a difference of at the most 0.5-1kmpl at the most between city and Sport modes, driven at <2K RPMs)- would run it for a week or so and then would calculate the realistic figures.
Really enjoying the spurt in performance! It should be the default mode while starting the car!The so-called city mode is best reserved for the highways.
Nikhil Beke is online now   (1) Thanks
Old 10th February 2022, 18:12   #296
Thanked: 64,827 Times
Speculated to be the Altroz DCT, spied again!
Expected fuel mileage is around 16-17kmpl
Link
Old 16th February 2022, 13:35   #297
Thanked: 126 Times
Did a 850km trip from Bangalore to Pondicherry and back over the weekend. The car performed well, which included me and two passengers and luggage. On the highway, though, I had to keep it in Sports mode at all times. City mode just doesn't work well for overtaking and keeping pace at highway speeds.
Pushed the car a bit (it's run just 1200 km), body roll was a bit evident when cornering at high speeds; I think it desperately needs those Cobra lowering springs. It returned a decent 15kmpl even after some hard driving.
One issue (or a non-issue, maybe?) are some squeaks that come from the driver-side suspension. It goes away after 20-25 minutes of driving. Will ask the service advisor about it when it goes for its first service this week.
Last edited by libranof1987 : 16th February 2022 at 16:24. Reason: Removed reference to illegal speeds
Old 22nd February 2022, 10:17   #298
Venkatesh's Avatar
Tata Altroz now comes with a new colour option called Opel Blue, spied at dealership.
Walkaround
Source
Venkatesh is offline   (3) Thanks
Old 28th February 2022, 11:02   #299
Venkatesh's Avatar
Tata Motors teases Altroz Automatic, launch soon.
Venkatesh is offline   (6) Thanks
Old 28th February 2022, 11:08   #300
Thanked: 169 Times
On one hand, India’s best selling carmaker switches from a CVT to AMT and here’s Tata who is launching a proper Autobox/DCT for Altroz. Kudos to them!
Oomph11 is offline
