OH NO!!!!!! ITS ANOTHER SUSPENSION CHANGE FOR OUR JIMNY: ARB Old Man EMU 5 door Suspension Installed on our Jimny We would be tops in the India book of Jimny Records (if something like this exists) for the largest number of suspension : THREE - changed on the same Jimny
As they say the world is really round, and what should have been the suspension installed to start with has finally been installed Oldman EMU it is
Background : Installed the first suspension way back in September 2023 Tough Dog 40mm kit. Unfortunately turned out to be a kit meant for the 3 door with some quality issues. Got taken off in 11 months and because the OME 5 door was still not available and since I was in a hurry and tired of waiting for the OME 5 Door kit made the mistake of choosing another Australian brand Dobinsons in December 2024. This one lasted the least possible time days, one rear shock failed the replacement failed too these were day zero failures had enough and returned it to the company. As I had directly imported lost a lot of money in this fiasco (GST + Customs + Air Freight which totaled up to lot). Learning - never self import.
Our Learning from the earlier 2 suspension kits : Deal with large companies with high level of QC controls and processes well set along with them sourcing from the reputed vendors (Shocks). Dobinsons was a shocker as the product was not just bad quality (how can 2 shocks fail one after the other and these were valving and shim failures pretty bad news for a suspension companies customers. Also they have admitted in writing that they will have to change the design for the Jimny the IMS is simply not designed for the Jimny/ Tough Dog was not just 3 door compatible but also build to a cost. These are made by Gabriel in China. Later found out that Dobinsons which I thought was made in Tiawan turned out to be made in China as well. Comparatively Tough Dog felt the poorest in parts quality. Both these companies released their 5 doors without much testing as is evident by the launch of the XL and their almost immediate launch of their suspension kits for the XL. Testing in any product is vital and more so for a suspension. And always buy with a warranty from an official supplier.
Oldman EMU Quality : It is not without reason that the Toyota 4 Runner comes with OEM suspension from Arb (OME). Speaks volumes of the quality that Toyota has trusted especially in light of the fact thats not only is the company Japanese (thus very quality conscious) but makes its own suspension for its own various vehicle models. Taking every component in your hands - the quality feels and looks top notch.
Why Oldman EMU : This suspension has been developed and engineered to suit the car jointly with Suzuki Australia, and has been a long time in testing and development since January 2024 and finally released for the market in December 2024. Extensive testing would have been done in the meantime.
Oldman EMU : reasons for being a perfect choice for our Jimny:- OME has done their homework and extensive testing in launching this kit.
- Softest spring rates compared to the other brands available in the market translating into sublime ride quality (One think that has to be said the OEM suspension ride quality is good but lacks body control).
- Shock promote a large amount of travel perfect for off roading. 160 mm of extended travel in the front and 190 mm in the rear. Compared to OEM - 135 mm in the front and 145 mm in the rear. Enough articulation on demand.
- Spring rates : Spring rates of 21Nm in the front and 22 Nm in the rear comparably OEM is 22 Nm in the front and 22 Nm in the rear. This translates to a similar soft ride as the OEM but with better body control in comparison.
- Perfect diameter that can be accommodated in the Jimny for improved handling and superb performance.
- Shocks made by Monroe for ARB in Mexico. Springs by ARB in Australia.
- The minute you handle the parts you can make out the quality that is miles ahead of all the others. Have handled 3 kits total till now - the difference is palpable.
All components installed:
WHAT HAVE I INSTALLED: Parts in the OME 40mm Lift Kit installed for the 5 Door Jimny:
3145 : Coil spring front
3322 : Coil spring rear
63154 : Nitrocharger plus shock front
63155 : Nitrocharger plus shock rear
FK96 : Jimny pan hard and bump stop
FK99 Jimny brake extension & shock mount
FK 122 : Cross member kit
This kit comes with a 3 year warranty.
Castor Correction: Hardrace Front Castor Correction Radius Arms: Not a big fan of castor correction bushes and wanted a fill it forget solution so installed HardRace. The castor correction is done by the arms themselves and not the bushes. The castor bushes when replaced will be from Maruti - same size so no waiting for imports to happen for the bushes to arrive.
Extended brake hose pipes - Already installed both front and rear. But does come with a kit for extending the rear hose pipe
Some OME kit components worth mentioning in the install: OME Panhard relocation bracket : OME is the only brand that gives the Panhard relocation bracket as part of the suspension lift kit. Directly results in a very controlled lateral sway. The instructions for the install even comes with torquing figures something not seen in any lift kit.
The cross member: is not a flimsy bracket but a full cross member again solidly built and finished. Something I always wanted instead of the bracket. Hundreds of times better than the bracket in every aspect including structural integerity.
Am seriously impressed with the attention to detail : right from instructions to torquing figures to bigger rear bolts, all nuts bolts and washers supplied they have it all covered.
Nuts Bolts and Washers - attention to great detail evident :
Instructions with minute details:
The Installation: Pretty straightforward - especially for someone who had done this multiple times over
The Rear Shock & Coil:
Hardrace Castor Correction Front Radius Arms & OME Cross Member:
The Front Shock & Coil:
Rear View:
Before Lift:
After Lift:
THE RIDE AND THE VERDICT :
On Road : PLUSH as plush as the Jimny can ever ride. Glides over pot holes and the annoying thud from the rear is gone. The thud elimination is something not seen with the other lift kits. The body movement is beautifully controlled. Sticks to the tar and cornering on high speeds is stable.
Off Road :It equally handles brilliantly off road. The articulation for a 40mm kit is top notch and the body control is something to be experienced.
No wonder its the largest selling suspension for the Jimny and mostly out of stock with waiting times in months even in Australia.
The 215s riding on AR wheels with 7J width and -6 offset have also made a big difference on grip and stability.
The lift kit has made the Jimny look taller and bigger - it does not seem to be squatting anymore....
Special word of thanks to Vijay - 94480 68681 of Swastik Fabs for all his help in getting the kit delivered in lightning speed.
