Old 21st February 2020, 14:24   #3721
fastturtle10's Avatar
Thanked: 58 Times
Default Re: Mahindra Thar : Test Drive & Review
I was initially reluctant to post this as I am not as knowledgeable about the Thar as I am for other cars so apologies in advance for any mistakes
My father's friend recently bought a Mahindra Thar 4x4 and since he knew my father for being the Jeep/That enthusiastic he is, we got the beast for 1-2 weeks. Prior to receiving this gorgeous beast, I was not really a fan of both the Jeep and the Thar and thought it would be of no fun to drive, however my father took me for a small off-roading trip and my opinion took an immediate U-turn. We went to a mountain located in Kerala's Idduki district called Ilaveezhapoonchira (trying to pronounce this was harder than the actual off-roading ). The beast conquered most of the mountain with ease in 4H but when I shifted it to 4L, I truly understood why it was dubbed "legendary". For my first true off-roading experience, it was absolutely nothing short of a blast.
My father's friend had modified the car a lot as it now had larger wheels suited for off-roading (apologies for not knowing any of the specifications), small LED lights, Iron Man suspension kit, a reverse camera (grateful for this as I'm a bit spoiled ) among others.
Not being as knowledgeable about the Thar as other members of this forum, could someone tell me what the N is in the 4WD gear selector?
Attached below is a picture I took of the beast after having conquered the mountain with a name that's mouthful.
Mahindra Thar : Test Drive & Review-img_20200208_175109.jpg
fastturtle10 is online now   (2) Thanks
Old 21st February 2020, 16:10   #3722
jeeva's Avatar
Thanked: 651 Times
Originally Posted by KkVaidya View Post
While spraying Lithium grease between the leaf springs today, I noticed a circular dish jutting out on the left spring assembly. I could not push it back as the springs are under load when vehicle is on ground. I showed it to a leaf spring repairing shop and he said that it has no function and we always remove it while repairing
I did not take his word and tried searching over internet but could not find the right answer. Does anyone know why this dish is installed between the leafs?
These PU inserts prevent the squeaking sound from the leaf set when they grind each other : prevents direct metal to metal contact.
jeeva is offline   (2) Thanks
Old 22nd February 2020, 09:02   #3723
Thanked: 287 Times
N=Neutral, no drive to either the front or the rear wheels!
crdi is offline   (1) Thanks
Old 22nd February 2020, 10:02   #3724
Thanked: 58 Times
Thanks for the response but could you also tell me a scenario where you would have to shift it to Neutral?
Old 22nd February 2020, 11:09   #3725
Kosfactor's Avatar
Thanked: 1,259 Times
The Jeeps being military recon vehicles apart from many other purposes it's used for, Jeep can be towed flat , as in with all 4 wheels on the ground behind a military truck if needed without anyone being inside the Jeep. So the transfer case needs to disengage the gearbox and stuff like that to prevent excessive wear, an alternative method is to disconnect the drive shafts with by crawling underneath it.
Another reason is Jeeps were used as a tractor , with accessories to plough the field as well as operate pneumatic drilling equipment , farm equipment etc , so the transfer case had to be isolated in this case as well when the PTO is running.
Kosfactor is offline   (4) Thanks
Old 9th March 2020, 06:23   #3726
SandyX's Avatar
Thanked: 723 Times
Does anyone here have Thar DI/M2DICR Service manual, preferably M2DICR? It'd be really helpful for a project. Thanks.
SandyX is online now
Old 9th March 2020, 10:21   #3727
KkVaidya's Avatar
Thanked: 375 Times
I wanted to have the workshop manual for my CRDe but Mahindra says that it is a confidential document to be given only to dealers!! I even escalated to customer care but nothing happens
You will be lucky if someone has it
KkVaidya is offline   (1) Thanks
Old 9th March 2020, 10:49   #3728
KA09_BIKER_GPER's Avatar
Thanked: 69 Times
The N(Neutral) position in a Transfer Case disengages the drive to both front and rear differentials via the propeller shafts. In case there an issue with the gearbox or the differentials and the vehicle needs to be towed, it would be wise to tow it with the transmission completely disengaged. It can also be used to release the stress built up in the drive train due to transmission rewinding.
KA09_BIKER_GPER is offline   (2) Thanks
Old 16th March 2020, 00:27   #3729
Rugged's Avatar
Thanked: 58 Times
hello Sandy,
Please pardon my ignorance , is it the same as Owners manual ?
If yes here it is !
File Type: pdf THAR m2DiCR_LCCR BS4_OM_DITAMAP_01072016.pdf (10.40 MB, 39 views)
Rugged is offline
Old 16th March 2020, 06:26   #3730
SandyX's Avatar
Thanked: 723 Times
Originally Posted by Rugged View Post
hello Sandy,
If yes here it is !
Thank you for the reply. Sadly no, it's the elusive Service/Workshop manual I'm after. Mahindra seems to believe it deserves to be heavily guarded.
Copyright 2000 - 2020, Team-BHP.com
