Old 2nd March 2009, 13:24   #1
Restoration of Chevrolet 1951
I am initiating the process of re-restoring the family Chevy.
It was resorted in early 90's but due to some impulsive decisions by the family it was jacked up and standing in the air for 14 years.
In the last 18 years, I presume the car has not been driven more then 500kms.
There is some tinning work and the chrome plating to be done. The upholstry will be done once I can get her to be in shape mechanically.
I am looking for the original badges, wheel caps, working clock, break lights (presently using ambassdor lights) etc.
So far, step by step mechanically she is shaping up. Worked on the fuel tank, wiring harness, alternator, radiator, fuel pump etc. Now what I would need sooner or later is to find some old time mechanic who can get the firing sequence on the 6 cylinder engine.
All suggestions and inputs are appreciated and most welcome.
mandip is offline   (1) Thanks
Old 2nd March 2009, 15:56   #2
Thanked: 293 Times
Originally Posted by mandip View Post
That's a nice car you've got in the family, Mandip. The firing order for your Chevy should be 1-5-3-6-2-4, i.e. cylinder 1, then 5 and so on till the 4th cylinder, which'll fire last before the new cycle begins with no. 1 again. The sequence will move in a clockwise direction, but you may still unclip the distributor cap and ascertain from the movement of the rotor that it is indeed so! Barring a few cars where the first cylinder is counted from the bell-housing (clutch) side, in most cases (of inline engines as yours) the first begins from the radiator side, i.e. the front of the car. There're a few quaint cars that have their radiators near the firewall, some have gearboxes in the front (like in the Citroen TA) and I haven't even started talking about the rear engined horrors. But, you take your first cylinder from the radiator.
Of course, you have to get piston number 1 to TDC (Top Dead Centre) and adjust the distributor accordingly to get the first cylinder HT lead from the distributor, etc. so if you're not clued in on such stuff, you might still need that old time mechanic in your city. I'm too old to travel now.
Prabal is offline   (1) Thanks
Old 2nd March 2009, 16:13   #3
V-16's Avatar
Thanked: 950 Times
Hi Mandeep where in bombay are you placed. maybe i could be of help if you would consider me an old time mechanic of sorts. (now that Prabal has kindly declined to come and has also given the firing sequence for the cylinders) On the other hand i could recommend one of my guys (those who maintain my car) to come and look at the car
V-16 is offline
Old 3rd March 2009, 16:42   #4
Thanks for the offer and Prabal for his valuable inputs which would be very beneficial. I am thrilled to have met you'll here.
I am in Bandra and the car is in Dharwad, North karnataka. We would be bring it to Mumbai soon to start the 2nd phase of the resortation.
Presently just getting the basics prior to having it put on a truck
to Mumbai.
I am travelling and will be in Mumbai around the first week of April.
mandip is offline
Old 22nd March 2009, 19:42   #5
imperial.s.a's Avatar
Thanked: 32 Times
to Mumbai.
Hai mandeep I own The same Model STYLINE DELUXE my mech is mr. Kannan he is an old man and very good at old cars ,if your intrested i will give you his contact 080 22222289 but speak to him only, not anybody else in his garage
imperial.s.a is offline
Old 20th May 2009, 19:51   #6
trammway's Avatar
Thanked: 475 Times
Any one guess how much is this Chevrolet worth for ? I'm following up with the person who said this car is for sale. Hence my visit to check the car returned the output pictures here, I will soon post further information on the developments of this deal.
trammway is offline
Old 20th May 2009, 20:11   #7
Dussey's Avatar
Thanked: 177 Times
Attachment 138043
Attachment 138044
Attachment 138045
Attachment 138046
Attachment 138047
Attachment 138048
Attachment 138049
Attachment 138050
Attachment 138051
Attachment 138052
trammway, Good bodyline. Its got a diesel engine. If it does not have the original 6cyl petrol engine, then the value most definitely comes down. You may perhaps ascertain if the original petrol engine is available with the owner.
Last edited by Dussey : 20th May 2009 at 20:15. Reason: modification in the reply.
Dussey is offline
Old 20th May 2009, 20:15   #8
trammway's Avatar
Thanked: 475 Times
Originally Posted by Dussey View Post
trammway, Good bodyline. Looks like its a diesel as we can see the heater in the dash. If it does not have the original 6cyl petrol engine, then the value most definitely comes down.
You got it right, it is dieselized car and the engine and diesel filter on the firwall shows the motor is changed on this car.
trammway is offline
Old 21st May 2009, 13:48   #9
V-16's Avatar
Thanked: 950 Times
Also one can see the glow plug on the dashboard. Many a times the petrol engine is retrieved from the owner. Find out, he may just have the engine lying around somewhere.
V-16 is offline
Old 21st May 2009, 14:33   #10
siddartha's Avatar
Thanked: 24 Times
that seems like a matador engine, the exact same car is going thru a full fledged restoration job here in bangalore.
siddartha is offline
Old 21st May 2009, 15:56   #11
the mole's Avatar
Thanked: 825 Times
well except for the engine the car looks like she is in good shape, there may be chevy engines lying around in big metro chor bazaars you just have to look.
the mole is offline
Old 22nd May 2009, 23:49   #12
Thanked: 24 Times
Nice car,Thanks for your family for preserving this car upto date. I know one mechanic who I think must have fixed about 100 such cars in last 5 years,and he is also reliable.He is also wellknown among this circle.
piyush shah is offline
Old 25th May 2009, 05:49   #13
harit's Avatar
Thanked: 3,281 Times
Well, some good news, there is an engine for sale in Mumbai. It was bought for a Fleetmaster, turned out to be a 1951 engine. The starter is on the other side. PM me and I will put you in touch.
Value of the car, well I would pay upto 1.5L, some may pay more and some will offer less. So shop around and get the best deal.
Good luck harit
harit is offline
Old 25th May 2009, 09:14   #14
trammway's Avatar
Thanked: 475 Times
Good luck harit
Wow.. thats a great thing to know. I'm still trying to get in touch with the seller. I will IM you after talking to the vendor.
trammway is offline
Old 16th June 2009, 11:41   #15
harit's Avatar
Good luck harit
BTW, the engine for this 1951 Chevy is still available, so far no one has asked.
harit is offline
