Team-BHP > Road Safety
Old 15th July 2018, 11:18   #121
Thanked: 34,274 Times
Originally Posted by Lobogris View Post
I don't believe airbag deployment is contingent upon hitting a sensor directly. The sensors measure sudden deaccelaration and deploy airbags regardless of whether they receive a direct hit.
Finally, airbags fail in about 5% of crashes worldwide..
Some system, especially in India, appear to be relying on essentially switches rather than deceleration sensors.
The failure rate of airbags is according to most studies well below 9%
Jeroen
Jeroen is offline   (2) Thanks
Old 15th July 2018, 12:19   #122
Thanked: 2,394 Times
Default Re: Frontal Crash - Airbags didn't deploy. Why?
Jeroen
Even I suspect that as well. However, hopefully more expensive vehicles should have deceleration sensors. I wonder if switches for airbags are still produced today as that is a very outdated technology.
Lobogris is offline
Old 15th July 2018, 19:56   #123
Jeroen
Oops, my mistake. Failure rate is well below 1%.
Jeroen
Jeroen is offline   (1) Thanks
Old 27th July 2018, 13:25   #124
Thanked: 1,277 Times
Analysing the pictures from another thread, let's see where approximately the airbag sensors are located (red circles), and where the bulk of the impact happened (green boxes) (photographs downloaded from FB and suitably edited).
We can't expect airbags to deploy in this situation, nor is it the car or manufacturer's fault. If a service centre guy said, “It’s because you did not collide properly”, there's possibly a modicum of truth in it!
Maybe manufacturers need to relocate their airbag sensors for airbags to deploy more easily - but then there would be so many airbag deployments in mild shunts, that we'll need another section, not a thread, to report all those cases!
I am quite shocked. Why can't the manufacturer add enough sensors to cover such impacts. Could there be a sinister angle behind the reason they don't?
arvindb4 is offline   (1) Thanks
Old 27th July 2018, 14:29   #125
SS-Traveller's Avatar
Thanked: 23,519 Times
Difficult to answer that with conviction, but economics does have a role to play.
SS-Traveller is offline
