Sharing stats i mentioned above:
Units generated per day since Nov 10, some initial data is missing while i was setting this up on home assistant.
The 8-12 units generated last week is on fully cloudy/drizzly days.
Highest generation today - 27.2 kWh
Instantaneous generation on a typical day. Generation peaks in the afternoon and goes up and down when there is clouds. I have shading from an apartment diagonally behind my home in this season after 3:30 pm so generation tapers down after that but still continues to generate due to irradiance. I have seen that the instantaneous generation goes way over 6KW when the panels are cool (optimum temperature 24 C) and then the sun shines suddenly, otherwise on hot days, the panels are not super duper efficient but can at least generate consistently unlike shaded days.
Work in Progress - End to end energy dashboard on Home assistant.
Showing only solar generation as of now.
Going a bit overboard with my monitoring but IOT is my hobby so some phase wise Energy consumption i am working on monitoring using CT clamps and esp boards showing instantaneous power consumption through out the day which will also help me see what appliances are consuming how much high level. Once stabilized this data will go into the Home assistant energy dashboards.
I am also trying to figure out pulling data from the DISCOM's netmeter so that i will see what the Netmeter is seeing, the units i am pulling from the grid, the units i am feeding back into the grid - all from my mobile phone. There is not much documentation for the L&T meter they installed, I was assuming the data port it had was a modbus rs485 port only to later realize that it is actually a RS232 port and uses DLMS protocol. L&T is asking me to reach out to the Discom when i ask for a manual with register addresses etc
. i will post here if i end up figuring it out eventually and this will also help me put more reliable data into the dashboard.
End of the day, all this data might not matter to a regular joe but i use this hobby to learn new technologies, open source monitoring stacks etc. In other IOT stuff, I also do stuff like monitoring overhead Tank water levels and make announcements via alexa when the tank is empty or full + send out a notification via telegram messenger, monitor my solar heater temperatures, room temperatures etc. just for fun . Off course i can automate water pumps and geysers using this data but don't plan to put too much automation into the home that can break when i am away or am dead and no one else knows what i have done
. My CCTV camera paired with a motion sensor sends me a pic on telegram every time someone is at my gate or someone rings my doorbell wherever i am in the world. Off course, there are commercial products that do all of this but i like doing my own stuff. All this probably belong to other threads so i will save it for another day i guess. Apologies for going off topic and bragging.
Originally Posted by skumare I am planning to get a 2KWp off-grid system at a farmhouse, glowpower is the inverter that is included in the system. A couple of queries:
a) Will this accept 220v AC input from the grid, if available?
b) Can we tweak the inverter to prioritize the source - (1) (Batteries charged) - Solar/Grid/Battery and (2) (Batteries need to be charged) - Grid/Solar/Battery -in this order?
Is there any specific inverter brand that offers this feature? |
Didn't notice this post earlier. Not an expert but can share what i know if its not too late already.
a) Don't know about the specific brand but most off grid inverters accept AC input and you can configure whether the battery charges from solar panels, or grid or from both depending on availability to stay at full charge. You can also configure whether the load has to run from batteries when solar is unavailable or if it should run from the grid when grid is available and use batteries only for backup.
b) Most inverters have this feature but you should check for your specific model. I know Luminous is popular, i have seen a company called Nexus solar selling innovative products in this area. I heard UTL gamma inverters are good.
If you are not aware, you can also look at hybrid inverters that can operate completely operate offgrid using a combination of solar+battery when grid is unavailable (unlike grid connected inverters that shutdown when grid is not available) and also feedback into the grid if there is excess generation that is not being used by the load and the batteries are full. Most companies like Growatt, goodwe etc have models listed on their websites for hybrid inverters but i was at the RenewX 2021 exhibition last weekend (not very interesting) and most stalls there were claiming hybrid models are not yet available in India and claim the reason is high cost. When i enquired, they mentioned hybrid models are 30% more expensive and that's why they are not available- sounded like a lame reason. What these companies sell are Transformer less models that use power electronics for all the conversion and isolation magic and are lighter in weight and wall mountable.
There are other companies like Nexus solar in India that have launched transformer based hybrid inverters with all the features you are asking for but are heavy, floor mounted and supposedly less efficient than their transformer less peers due to more losses.
Personally, my thought process right now is that i might look at Hybrid a couple of years later when the technology and availability in India matures. One other big thing is LifePo4 batteries are still scarce and expensive in India and they are the future for solar applications compared to our regular very inefficient Lead acid batteries. Sadly, there is no local manufacturing in india yet for most of these products and almost all imports are from china.
Originally Posted by skumare Thanks for the updates and sharing the know-how. My 3KW net metering unit shall be erected on the terrace over this weekend and may go online next week. I am also planning to align my usage (convert to electric cooking plates, a new A/c in Hall etc) rather than expecting the Discom to payback for the surplus units.
I will be in touch regarding a separate 2kw no-subsidy unit (on a east-sloped roof), I think going for mono panels with micro inverters makes sense for this as the generating time is limited. I will connect my Inverter batteries and route all the lights, fans and TV thru this system (which are already separately wired to the inverter). Do you have contacts of any vendors in Hyd who are competent in this area? |
I'd suggest picking up the list of epc vendors from the tsspdcl website and filter down to some companies that seem like reputed/bigger companies and reaching out to a few of them before you finalize the one that sounds good to you.
Alternatively, you can reach out to brands if you know which brand panels you want. eg. Vikram, Loom, Tata, waree etc and ask for their dealers in hyderabad. Try to get the 440W panels for best space utilization.
I feel procuring and mounting the panels is the biggest challenge. Once that is done, for what you are planning to do, you just need a good Solar charge controller and continue with you existing inverter and batteries. There are charge controller that have an input plug socket for your existing inverter and manage all the intelligence of charging from solar vs charging from the grid + discharing from solar vs grid. Off course, never forget proper earthing, Surge protections and lightening arrestor.
i'd say try calling loom solar once, they have a couple of vendors in hyd but i didn't find the vendors response proper when i was researching but you can try again. I can also share my tata vendor details and you can talk to them about their experience with offgrid systems etc.
