Re: Puzzle Parking System Quote:
Originally Posted by sumeethaldankar In case of such systems installed in the society, does one has to leave his or her car key with society driver(s)? Can anyone who has implemented such a parking in their society comment? People like me are not keen to hand over keys to any valet etc. Modern societies due to dearth of parking capacity seem to be having such features. |
There are two types of stack parking systems - independent & dependent.
If you have an independent stack system, the lower stack/s go into an underground pit allowing the cars on the higher rung to be removed without moving other vehicles.
In a dependent stack system, the lower cars need to be removed to have the upper level vehicle taken out.
If in your society you have an independent system - then no need to give keys to the watchman.
However, if you have a dependent system then yes - either you will have to go move the car each time the upper stack vehicle needs to be moved; or give the keys to the valet / watchman to move around.
Another alternative for you is to swap your vehicle and park it in the higher level so you can keep the keys with you, whereas the neighbor who now has the lower stack gets the advantage of being able to drive in and out without waiting for your car to be moved out first.
Most modern societies have puzzle or stack parking as you rightly said. Puzzle parking is a more independent version where the whole process is automated. Drive your car into the bay, get out, and the bay is moved by the machine as needed. Hubtown at Breach Candy / Mahalaxmi Mandir has a puzzle parking system implemented.
