I learnt driving barefoot (though nobody told me I had to, it just came out of observing drivers around me). The only drivers I saw driving with footware on were the BEST drivers.
In a heavy vehicle, the angle of the pedals to the floor is much smaller than in a typical car. And so in a heavy vehicle you are actually stepping on the pedal and depressing it downward. In a car, you would be depressing the pedal more to the front side than down. Because of the steeper angle between the pedal and the floor, when you rest your foot against the pedal there is a high chance of your feet slipping out of your footware, made worse by sweat. It also introduced some pain in my ankles, as I was forced to operate all three pedals continuously in stop and go traffic on inclines and declines. (This is all my personal opinion, which could be true!) Also the quick response of the pedals in the modern cars makes it necessary that you get accustomed to driving barefoot as well as with footware.
A few years back I found it a problem to drive barefoot, as I had to drive to work everyday and I was using shoes with laces. So I decided to learn driving with my footware on. And in a few days I got used to it too.
A word or two of caution:
1. When you are driving with your footware on, you may need to adjust your driving position slightly, as the leg travel will reduce (though it's very small, it can be a big irritant at times).
2. I have found that when driving with footware on, sometimes the footware either slips from the pedal or sticks to the pedal a bit too much and I can't deliberately slip my leg up or down the pedal. This is a big irritant in stop and go traffic, especially on inclines.
3. Preferably use tight-fitting shoes. Avoid using chappals or sandals that are a size too big, as they will introduce further slippage from the pedals. Without your feet in them, the footware on the pedals is pretty much useless, as you can see.
4. A big problem of driving barefoot is the footware generally does not fit well into the space between the seat and the pedals. The footware manages to interfere with a free travel of your feet within the available space. Else the footware gets so stacked up that when you need it, you have to use your hands to pull it out and wear.
5. If you are in the habit of using different footware for different occasions, for e.g. Kolhapuri chappals for some casual occasions, formal shoes for office, sports shoes for a visit to the club or thick-soled shoes for some trekking etc., I suggest you consciously pay attention to the pedal actions and movements when driving. Each footware will have its own thickness, slipping tendency, grip with the pedals. |
