![]() | #11416 | |
BHPian ![]() Join Date: Jul 2021 Location: Gurgaon
Thanked: 757 Times
| ![]() Quote:
Keep in mind liquid waxes generally last longer than spray waxes, although an SiO2 spray wax will last longer than a carnauba based liquid wax like 845. 845 is a good liquid wax but doesn’t last more than 25-30 days, and also has minimal filling ability (read hide swirls and add temporary gloss). 845 is very easy to apply unlike their 476 double coat paste wax which is a royal pain to buff if you let it flash. Out of the ones mentioned, I’d recommend megs hybrid ceramic liquid wax as it will last the longest and has decent filling ability (turtle waxes also fill defects very well which you’ve been using until now) Cheers. Last edited by AJ56 : 4th January 2022 at 01:36. | |
![]() | #11417 |
Senior - BHPian ![]() | ![]()
I have used this product and even recommended some of my friends to use this. Can you please share the place where you are getting this rate? I picked up the same one for close to Rs. 8000 (inc. of GST). The one problem with this is the plastic gun. An easy fix is to get the attachment replaced with a brass fitting. Any local fitter should be able to do it. |
![]() | #11418 |
BHPian Join Date: Aug 2015 Location: Delhi
Thanked: 244 Times
| ![]() I have a Karcher K1 high pressure washer. Can anyone recommend me a decent foam nozzle to connect it with ? |
![]() | #11419 | |
Thanked: 757 Times
| ![]() Quote:
Main thing you want to ensure is you have a quick connect to Karcher adapter like this: https://www.amazon.in/JPT-Foam-Lance...%2C330&sr=8-13 This allows you to use almost any foam cannon as most come with a quick connect type fitting, finding a Karcher specific fitting is difficult and ends up limiting your options. Cheers. | |
![]() | #11420 | |
Thanked: 244 Times
| ![]() Quote:
![]() | #11421 | |
Thanked: 757 Times
| ![]() Quote:
For 2k I’d suggest look at JTP foam cannons on Amazon, avoid the super cheap 1200-1500 buck ones as they tend to fail within 1-2 weeks and there’s no warranty on them. JTP is an Indian brand but better quality than the Chinese ones. | |
![]() | #11422 |
BHPian ![]() Join Date: Jan 2017 Location: -
Thanked: 965 Times
| ![]() Is there any kind of polish/wax which provides protection from UV? Need it for hard top. Already have carnauba wax but I suppose that's not apt for the material. |
![]() | #11423 |
BHPian ![]() Join Date: Jul 2007 Location: Chandigarh
Thanked: 63 Times
| ![]() Hello Bhpians, I just received my Rupes LHR 15 Mark III DA Polisher with Basic Kit for DIY on my personal cars. It contains 1 DA polisher, 2 - 250 ml polish compounds (coarse and fine), 2 polishing pads and 2 Micro Fibre towels. Did a lot of research and finally bought Rupes basis on reviews and availability, the other brand considered was Flex. Will try it out next week and will post the results. For the benefit of Team-Bhp members, who are looking for DA polishers and related products, below is the details of authorised Rupes distributor in India,you may reach out to Mr Viswanath Rao from RIO, Kozhikode. Ph: 9895020320. Viswanath was very welcoming and prompt in clearing a lot of product and technical queries. |
![]() | #11424 |
Newbie ![]() Join Date: Dec 2021 Location: Noida
| ![]() Hi People, So, i have bought a new car recently and with that bought some sort of car maintaining stuff: carnauba wax, shampoo, polish, etc. However, i'm still in dilemma - how often one should wash a car with shampoo, apply wax/polish? I heard over doing of shampooing and waxing can be baleful. I'm seeing people sharing their thoughts on maintaining/detailing a car over here. Hence, would like to see some thoughts on this as well. |
![]() | #11425 | ||
Thanked: 757 Times
| ![]() Quote:
You want to apply the wax every month or whenever a drop in water repellency is noticed. You cannot harm the finish in any way by frequent application, plenty of people use a wax after each wash, provided you have the time. Polish is something that contains abrasives and is used to remove minor defects in the paint, this is best done with a machine, and only done when there is a need for paint correction. | ||
![]() | #11426 | |
Senior - BHPian ![]() Join Date: Oct 2018 Location: bangalore
Thanked: 6,763 Times
| ![]() Quote:
Cars as long as they are made with metal do not like much water on them. Whatever pH balance the shampoo makers claim, it will still dull the paint and rust the metal if the vehicle is water washed too often. Wax: Wax the vehicle once a year or twice a year by hand depends on how much you use it. Wash : Depends on how muddy it is and stuck on dirt that needs shampoo. Preferably once a month or less, sometimes you can get away with just washing the undercarriage that is muddy. Clean : You can use a waterless wash to keep the vehicle clean once a week. It's cheap and easy to use, keeps paint as well as plastic bits nice and shiny. | |
![]() | #11427 |
BHPian ![]() Join Date: Feb 2010 Location: Gurgaon
Thanked: 524 Times
| ![]() What's an easy way to remove these stickers from windshield? I have tried Rubbing alcohol and wd 40 but it's gum seems quite strong. What else to use? |
![]() | #11428 |
You can use 3M GPAC (General Purpose Adhesive cleaner) or Sonax Adhesive remover. For glass, you can also you a blade / metal piece to remove the residue. |
![]() | #11429 |
Senior - BHPian ![]() | ![]() |
![]() | #11430 | |
Thanked: 757 Times
| ![]() Quote:
Low effort but higher skill option: use a fine razor blade that is used for shaving, you need to know what you’re doing as its easy to nick your glass, but with practice you’ll learn that using at a a low 15-20 degree angle to the glass surface will result in a near perfect cut and perfectly safe sticker removal. Take care not to cut yourself. Cheers. | |
