Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | ![]() 12,364 views |
![]() | #46 |
BHPian Join Date: Jul 2007 Location: MH12
Thanked: 17 Times
| Re: Ammeters, Voltmeters (and Ign Telltale) @ Vina - Speed control for series motors - neither do I remember any other method ![]() Regarding the heat generated, ceiling fans do not have enclosures which would protect them from water. They do generate heat - try touching one after continuous operation. reason why they dont fail is that the class of insulation is usually A or B which is far higher than the temperature of the fan. Additionally, the ambient temperature is on the lower side. So even with a 50 deg ambient and a temperature rise of 25 deg - total temperature comes to 75 degC which is OK. Regarding conversion efficiencies, 95 % is valid for 3 phase motors/ alternators with significantly higher ratings. These alternators would have an effciency of about 75~80%. It can operate at full load without any problem continuously - as long as we keep the temperature in control. The thumb rule for is that the life of a motor/alternator reduces by 30%(or 50%?) every time you exceed the design temperature limits. I have seen motors reach a temperature of 110 degrees within 30 minutes of their operation at 85% load ( these were rated for 2000KW with and efficiency of 94%). The insulation limit was 120 deg C with a design of 150 deg C. Our alternators normally have 105 deg C insulation limits or in rare cases 120 deg C. The electronics at the aother end are rated for 140 deg C. @ deralte Well, I had given the basis of sizing the alternator with all OEM loads PLUS the float charging. You had said that a duty cycle would be considered for OEM loads. Now applying electrical engineering approach to this, intermittent loads would be considered in the sizing with a fractional multiplier or not at all. Now, when these loads would come on line, only thing which has to give way is charging. So, if I assume that the duty cycle would not be considered for the loads i.e., we are considering all the loads, the alternator would be fit for extended operation at 100% load. Regarding the approach taken for car component engineering, I cannot comment on that. Basic machine design data required for the vendor to design the alternator would be the ambient it is expected to work in, expected output and the duty cycle. This forms the base on which a machine designer does all the work you have pointed out. The basic design data has to be given by the manufacturer as he is designing the complete package. Database engineering is not design engineering, it is selection engineering. @Sutripta. Regarding charging regimes, you are welcome to your opinion. I would not discuss charging regimes in an automotive forum - there are other forums where it would be more appropriate. In case the specific gravity of your battery shows a decline, it means either your battery is going or your alternator does not have the capacity to charge it due to overloading etc. Best option would be to remive the battery and get it charged from the battery vendor/FNG. Recording battery terminal voltage and specific gravity is a standad PM practice recommended by battery manufacturers for industrial applications. Same can be easily followed here. @Aroy The utility generators are not sized for duty cycles and neither are they subject to continuous overloads. Additionally, their cooling regimes are much more complex and efficient (hydrogen cooling etc). Cool you car alternator properly and you would be able to extract more out of it. |
![]() | #47 | |
Senior - BHPian | Re: Ammeters, Voltmeters (and Ign Telltale) Quote:
![]() And then we have Diesel/Gas Generators in the 1-10MW capacity, used for short term/captive power, which are literally larger brothers of the neighborhood gen sets, which require extensive cooling of both the engine and the alternator. | |
![]() | #48 | |||||||
Senior - BHPian ![]() Join Date: Mar 2007 Location: Bangalore
Thanked: 2,920 Times
![]() Quote:
![]() Quote:
![]() Quote:
It is a different story when an existing car is to be manufactured in another country - like VW Polo in India. Then, either the existing vendors supply the parts, or for parts that need to be procured locally (indigenous content!) a ready design drawing is given to a competent new local vendor to manufacture it. Why the scorn? Do you design from first principles always? Good show! That is hardly productive. Last edited by Technocrat : 17th December 2011 at 00:05. | |||||||
![]() | #49 | |||
Senior - BHPian Join Date: Jul 2009 Location: Calcutta
Thanked: 6,233 Times
In any case here's my understanding. Trickle Charge: Current oriented charging method to keep a fully charged battery at 100% SoC. Normally not suitable for charging batteries from low SoC. (Until one has lots and lots of time) Float Charge: Voltage oriented charging method to keep battery at 100% SoC. Can also be used for charging batteries (with a few qualifiers) from low SoC. Equalising Charge: Voltage oriented controlled overcharging method. Used under special circumstances. Would like to know more. Quote:
Regards Sutripta | |||
![]() | #50 | |
Senior - BHPian Join Date: Dec 2010 Location: Ghaziabad/Hyderabad/Mysore
Thanked: 345 Times
I know only in the context on Li-ion and NiMH batteries. Trickle charge: Very slow charging regime when the battery has gone into a deep discharge state. Followed till the terminal voltage crosses a (pre-set) threshold - for Li batteries usually 3.2V to 3.4V. Once the pre-set is reached normal CC-CV (For Li batteries used for cellphones - constant current into the battery till terminal voltage under charger reaches 4.2V, or some other pre-set, constant 4.2V thereafter) regime proceeds. The trickle charging is done to (1) increase the life of the battery (2) in case of Li batteries prevent catastrophic damage (read-> explosion) What you guys are calling float charge is also sometimes called trickle charge, but that is known to be wrong usage in context of Li/NiMH batteries. AFAIK there is no name for that regime - the phone/PC etc. basically runs on the charger (rather than on the battery - battery does act like a massive capacitor) and once the battery charging current falls below a pre-set threshold you see a message "battery full" on the screen. More complicated circuits may shut off the charger once another threshold is breached subsequent to the "battery full threshold" - but that is usually not done. All the pre-sets above are provided by the battery manufacturer. For CE applications batteries are never overcharged as far as I know, especially Li batteries. | |
![]() | #51 |
Thanked: 17 Times
| Re: Ammeters, Voltmeters (and Ign Telltale) @ Sutripta - You made my day!. All three are meant to keep the batteries in charged condition. This is where your float charger steps in and monitors the voltage of the battery. Trickle, float and equalizing basically keep the voltage at the desired level. (Note that I am concentrating only on the lead-acid batteries over here. Ni-cad and other types would be different. And if you mean Tap cell equalizing charge, then its a form of boost charging for battery banks). The DC voltage applied across the terminals is not significantly higher than the rated voltage. The changeover happens when the current drawn by the battery goes higher than a limit - this happens when the battery has been discharged. This is when boost charging is required. This gives voltage at a higher level than the float charging thereby "forcing" current into the battery. I just checked out a couple of wiring diagrams I had for the battery indicator - it seems it would come ON in case of a malfunction in the alternator. Now if you are trying to avoid this, I would still suggest monitoring the battery regularly. In case of a drop in the specific gravity, you could have a look at the alternator. I would have suggested getting the alternator brushes checked but loss of integrity of the enclosure during inspections ( i.e., no cracked packings etc) would lead to more problems. If you get the indicator while driving, it would be time to cut out except the most essential load and try to conserve the battery as long as possible. Some of the old threads do mention problems in alternators post the 70K mark. This might be one of the factors you can consider for preventive maintenance. OT, it seems we are in the same line of business ![]() @Aroy, OT, to run an alternator at overload, you need to have an engine rated for that. Present standards allow 10% overload once in 12 hours for diesel engines. The alternator with its cooling systems would be able to sustain, but the prime mover would not. See, the point of overloading comes into picture when the duty cycle is considered. Now, as all have agreed that the alternator is rated based on sum of all loads, we can leave that out of the picture and consider efficiency of charging. If you read Sutriptas latest post regarding trickle charging, my contention would be clear. @ deralte Regarding loads, you are providing input data in form of "model numbers of electrical loads". The rice statement is appropriate - if you provide a fixed amount of rice to the caterer and more guests turn up, the rice is bound to run out till you get more rice. Same is the case with the alternator. Once you have sized it on the basis of your earliest posts (duty cycle), you would end up in a situation like the caterer!. Regarding the vendors, you have now given the input data to proceed for design - refer above. Regarding the compliments given, no comments. My approach to electrical engineering has been the same way for many years. I do guess you are getting a wee bit personal in your writings - cool down, we are all entitled to our opinions AND our ways of working. Just a request - please go through you earlier posts in a logical manner - you haave first disagreed and and later on agreed to the concepts. Guess we got you convinced on our approach! @ Vina Wait for me Buddy, I need that coffee ![]() Last edited by dashoin : 13th December 2011 at 22:42. |
![]() | #52 | |
Thanked: 345 Times
Waiting. Meanwhile: The first time I interacted with Sutripta dada, I thought the same, later I found everyone interacting with him would think the same ![]() On Alternator running overload- if you are talking about generators I understand. For cars, why can't alternator be overloaded? Engine generates much much more than alternator's capacity. On an earlier comment you made on efficiency - I don't know much about specifics of cars, but I did measure motor-alternator coupling's overall efficiency (power in power out) in college, over a decade ago. That was more than 90% if I remember correctly - at least one of them was clearly above 95% efficient and even the other one had to be at least 90%. I remember because I went into the lab thinking I would be lucky to get 50% (i.e. 70% each) I don't remember the power but I think it was less than 5HP on each rated. We ran it from less than 50% rated to slightly above rated for our experiment. If you have direct experience, I'll go by your numbers. I mean DC-DC converters easily top 95% peak efficiency and 90% in a wide band of power o/p, however I have seen designs done deliberately for 70% peak efficiency, because other considerations (cost etc.) were more important and 70% did the job pretty well. Last edited by vina : 13th December 2011 at 23:17. | |
![]() | #53 | |||||
![]() Quote:
![]() Quote:
a. one has a considerable power margin available from the engine for usage (same as 'enough rice was available') b. current will be drawn depending on - analyze by circuit theory - impedances of the components in a circuit. Current 'supplied' will never be throttled to 0 - there is nothing called 'there will be nothing left' c. there is considerable stretch available - till material failure in the alternator - that higher demand can be met. 'Temperature derating' is the gradually diminishing safety margin till burn-out. *Not* that higher cannot be drawn at higher temperatures - as long as cooling is effective d. there is considerable interplay between current drawn and voltage, till voltage goes to 0; current drawn will 0 *only* when voltage = 0 Quote:
* You seem to be finding it difficult to differentiate between persons and ideas - hence the feeling of affront. Especially if beliefs are questioned * You are most welcome to 'your' approach. Never had the luxury of coarse approximation myself * My emotions are reserved for the few people in this world I love, or love to hate. You are not one of them! As far as "disagreeing & then agreeing" is concerned, your reading seems to be more interpreting rather than reading as it is. You are most welcome to interpret it in any manner if it gives you happiness, as long as you don't express in public anything other than on the technical subject at hand. | |||||
![]() | #54 | |
Thanked: 345 Times
Coming to batteries, my inverter's manual (and sources on the internet) had this to say (summary of all): Bulk charging - initial charging of a significantly discharged battery with a constant current. Usually this is specified by battery manufacturers and is of the order of C/5 (C=AH capacity). Faster charge than manufacturers' recommendation leads to surface charging, but not much of a long term consequence otherwise. Battery terminal voltage usually remains less than 14.4V during this mode (for a typical 12V lead-acid battery). Higher than 14.4V leads to gassing so is usually avoided in regular charges (equalisation, below, is different) Constant Voltage (CV) charging - Happens once the charging terminal voltage reaches 14.4V. The charger doesn't increase the voltage beyond this point, charging current starts to reduce. Float charging - some do not differentiate between this and constant-voltage. Others say that once the CV charging current drops below a battery-specific threshold, the charger reduce the voltage to something like 13.5V - enough to keep battery charged, but less than the CV voltage. Equalisation charging - NOT done except in specialised chargers. Once the CV current becomes too small (about 2% of the 20hr current), the charger becomes a constant-current charger again, and charges till voltage stops rising OR rises to 15.5V (roughly, don't remember the numbers, but I guess they have to be supplied by battery manufacturer). Trickle charging - similar to Bulk charging above, except it is done with very small currents. Takes a lot of time to charge the battery, but there is no risk of surface charging. Most uncomplicated chargers do this. Most important sources for above: SuKam inverter manual Wikipedia articles (http://en.wikipedia.org/wiki/Lead%E2%80%93acid_battery and others) http://www.evdl.org/pages/hartcharge.html a few others which essentially said the same things (terminology used was slightly different sometimes) Last edited by vina : 14th December 2011 at 18:32. | |
The following BHPian Thanks vina for this useful post: | DerAlte |
![]() | #55 | ||||
Talking only of the lead acid cell so far. Quote:
![]() Quote:
So let me ask another question. If other considerations lead to the decision that the driver will be provided with only a telltale which can either be on or off, what exactly would you, the designer, have the two states indicate? (For the time being, forget practical considerations of how to implement that) Regards Sutripta | ||||
![]() | #56 | |
Thanked: 345 Times
Dada I didn't write about equalisation charging (that I read on the internet) because (1) that may not be the only reason (2) really not needed right now - in any case I don't think any automotive chargers are doing it. On the question above - as a designer I have a tough choice. I would really like to tell the user (1) His battery is about to die - as in die from old age (2) His battery has life, but it is about to die - as in die to deep discharge ... Since you (or rather the manufacturers) are giving only pass/fail - some mix of the above criteria with margins in each case will have to be devised and output. The criteria will also include economics - I think in the two I have listed above (2) will take the cake. | |
![]() | #57 | ||
This is similar to traffic lights and other such semaphores that are understood widely without too much training. Traffic lights indicate one of five states, including flashing yellow (everywhere in the world except in TN, where it is flashing red) for 'proceed with caution'. Common battery testers, which basically measure open-circuit voltage, have a similar semaphore marking in color - green: everything OK; yellow: going going; red: gone case. Works well for the common man who understands the color coding better than the absolute voltage of the battery. If one expands on @vina's logic, one could have chemical instrumentation in the battery which could be converted into a semaphore suitably. Current display technology is sophisticated and cheap enough to handle semaphore display. For example, use of multicolor LED. | ||
![]() | #59 |
| Re: Ammeters, Voltmeters (and Ign Telltale) ^^^ You constrained it to 1 of 2 possible 'what to display'. I was trying to remove that limitation, so that there can be better inferences drawn by the person looking at the telltale. The main objective is to help the person draw the right inferences. |
![]() | #60 | |
. Ammeter in the battery circuit to monitor the current flowing to and from of the battery. . Ammeter in the Alternator circuit to know how much it is generating . Voltmeter across the battery for monitoring voltage . Temperature meter (I miss the meter) to know how hot the cooling circuit is . Oil pressure meter to monitor the engine oil pressure I prefer individual analog meters so that I can check what I want without fiddling with selection knobs, so there goes computerized display. If I ever get a 4x4 with a low ratio GB, I would add the following (a la Pajero) . Altimeter . Tilt meter . Air temperature meter At present I have none of these in my Alto K10, and remain blissfully ignorant of what is going on, trusting in God (or MUL) that the car will run perfectly without any divine intervention of any sort, as long as I carry out the maintenance as per the MUL booklet! No meters == Ignorance is Bliss. | |
