Re: Do I need to change the head gasket? My Alto LX has run 57,000 Kms and there was severe heating issue with cooling getting vanished very frequently. I used to top up and run the car very cautiously. Later I found that coolant was getting mixed with oil and the oil lid had a creamy coffee coloured residue from inside. This is a sure shot indication of head gasket failure. I also noticed that the coolant reserve container was getting bubbles with hissing sound, which is again indication of head gasket failure.
You can also get many symptoms if the head gasket has failed. You will get bubbles in coolant tank, bubbles in coolant reservoir, oil film in coolant, discoloured engine oil, vanishing coolant, etc.
Try to get the defect rectified as soon as possible to avoid facing of head and also prevent further damage. If the problem is not attended well within time, the pick up would drop to such an extend that the car may not even move and you will have to tow the car to the service garage.
I went to Navnit Motors, Thane service centre and they gave me a very heavy estimate indicating requirement of radiator replacement, electrical coil replacement, water pump replacement along with head gasket replacement, qil change, oil filter change and coolant change. Head repair work was also advised to be done.
I took the car to a road side mechanic and he did the job charging me Rs 2000 for his labour for replacement of head gasket (Rs 300), facing head on lathe machine (Rs 1500), oil change (Rs 800), oil filter change (Rs 100), coolant change (Rs 200) and inlet packing (Rs 40). Everything was done for within Rs 5,000.
Now the car is running fine. It is well known fact that Maruti authorised service stations are more interested to service new cars where they make 60% profit on selling engine oil and have very less work to do. If you go to them for any bigger repairs, they will quote such a hefty amount that you will run away from there, which is their aim. |
