Re: Skoda Yeti. 4.5 lakh repair bill! EDIT: Fuel system replaced under warranty
Originally Posted by csr9
Is the issue is sorted?
Hi csr9. Yes the issue was sorted out after the change of IC in the ECM. There is a possibility that an IC is probably the issue but Skoda will not repair but replace the affected part. I assume a new ECU will easily cost a lakh or so. See if you can find a good mechanic to get the ECU repaired if possible.
(1)
The following BHPian Thanks Epic for this useful post:
