Old 13th February 2023, 16:01   #46
Re: Rapid & Vento: Faulty Injectors? Repair instead of replacing
Originally Posted by scorpian View Post
Suggest you try the extra green diesel by indian oil for a few tank fulls. You will get it next to toyota showroom petrol pump on verna highway.
I have found this fuel to work really well and helps with the engine being eager to perform and also engine sound reducing to a great extent.
If it still doesn't help then look at other options. Hemkiran diesels in kolhapur does a wonderful job of overhauling injectors a bit expensive but job is well done. You will have to remove the injectors and send them by bus to kolhapur or else take a break and drive down to kolhapur on a friday and get the job done there. I have got my sx4 diesel injectors and injection pump overhauled from them.
Thanks Scorpian,
Have managed to get hold of genuine VW diesel injector cleaner from a source. Have filled a bottle for a full tank and I'm already feeling a difference.
Will run the car around more than usual and see the difference over time. Hopefully the extra 'clippety clop' in the morning cold start goes away.
MrTsi is offline
Old 17th September 2023, 08:10   #47
Hello members ! My 2016 Volkswagen Vento 1.5 TDI DSG have faulty fuel injectors. 2 injectors are totally Dead and now engine is running on 2 Cylinders.
I have three options to troubleshoot this problem, which one will be best?
1. Repair the current injectors.
2. Replace them with used injectors (from Scap vento/rapid)
3. Replace with brand new injectors.
TDI_Power is offline
Old 24th September 2023, 10:00   #48
Adrian Stephens's Avatar
Thanked: 26 Times
Hi TDI,
I have a 2013 Vento tdi that’s done 1.7 lac kms on the stock original injectors and recently inj 2 went kaput.
1. VW Vento come with continental injectors that cannot be repaired. If anyone promises this they are misguiding you. The Bosch and Delphi brands can be repaired not continental.
2. Used injectors are a hit and miss. You might be able to get away with this if you are 100% sure they have come out of a scrapped car with a running engine and they can be checked and cleaned… again used injectors are a hit and miss.
3. I chose to replace my injectors with brand new ones from the VW vsc primarily because I was sure they were brand new and original AND importantly they come with a 2 year VW backed warranty.
PS: if you buy the new injectors from the market and have a garage install them you will not get the 2 yr warranty.
Also when replacing the injectors with used or new ones make sure they are programmed into the ECU replacing the codes of the discarded injectors with the codes from the new ones.
Let us know how it goes for you.
Cheers.
Adrian Stephens is offline   (3) Thanks
Old 24th September 2023, 10:21   #49
Thanked: 26 Times
Originally Posted by sidsawant328 View Post
Hi All,
Does anyone know any reliable mechanic in Mumbai who can work on VWs for future reference.
Since there are 3 more injectors probably waiting to fail and if that happens I will be looking at a bill of around 75k
Hi Sid,
Injectors are bound to fail at some point. Mine failed at 1.7lac kms and 9 years later.
You can however keep them in good health by getting them cleaned at a reliable place that specialises in cleaning continental injectors.
You can also periodically use a can of the mobil diesel injector cleaner. Empty the contents into your fuel tank and run the engine.
If your a careful diy kind of guy or you find a garage that will do this then you can also use the injector clearer directly into the engine by running the engine with the fuel line feeding from the can filled with the injector cleaner.
There are a few precautions to be taken while doing this so please be sure if or when you attempt this. There are videos available on YouTube that you will need to refer and be sure about before attempting this. Do not choose to do this yourself if you haven’t done DIY stuff like this on your own.
Let us know how this goes for you.
All the best.
Cheers.
Old 25th September 2023, 09:05   #50
Thanked: 202 Times
I have a Skoda Rapid 1.6L TDI, 2014 make.
Same problem with the Continental injectors. Multiple issues with the injectors over the years.
My recommendation would be to get refurbishes injectors from an experienced and reliable FNG.
I tried new injectors but that didn't give any respite as one conked within 6 months and I had to get another one serviced.
Apart from this crazy repeated injector menace I haven't had any other issue with the Rapid and absolutely love driving it.
Aloneatma is offline
Old 25th September 2023, 10:45   #51
Thanked: 2,249 Times
I got my 2011 Vento injectors replaced. My friend who has the same year model got it cleaned. His injectors are also good now and I feel should have tried getting them cleaned before replacing. It might also depend on how bad your injectors are and then its better to replace them.
PreludeSH is offline
Old 12th January 2024, 15:21   #52
Thanked: 30 Times
From where did you get it replaced in BLR and how much did it cost?
maheshsm12 is offline
Old 12th January 2024, 16:37   #53
It was 96K for all 4. Got it done in FNG in Rajarajeshwari nagar. It was sourced from Skoda dealer, Electronic city.
But I heard it costs the same in VW service since the prices have come down there too. The SA informed me this when I was chatting about having got the injectors replaced outside.
PreludeSH is offline   (1) Thanks
Old 19th March 2024, 22:42   #54
SK01's Avatar
Thanked: 49 Times
I have been facing injector failure issues for the 3rd time in an interval of 5000kms on my Volkswagen Vento 1.5 TDI DSG.
The first was when I bought it from my family friend in Pune while coming back to Hyderabad the glow plug, and check engine sign popped up and the vehicle lost power and started to jerk.
Gave it to the FNG, and they have replaced the wire connecting the ECU to injector 1, and also swapped injector 1 to injector 2 and vice versa.
The issue was sorted and my friend drove the vehicle back to Hyderabad. So far all good.
On the 3rd day after the repair, in Hyderabad the issue again cropped up, and this time the scanner showed the cylinder 2 injector which was originally the injector 1 that was swapped at Pune FNG.
Now we replaced the injetcor 2 with a used one purchased from Pune.
Everything was good for 4000 kms until last week at Vijaywada I took the vehicle to an FNG to get the K&N replacement air filter cleaned.
Post the cleanup the issue was raised again but this time without any warning lights in the cluster, no loss of power but the jerks at idling and nothing else.
The scanner showed negative values for injector 2 and again it was replaced with a used one due to unavailability in the small town.
1. Now my question is to have it or sell it.
2. Don't want to have an extremely unreliable vehicle at the garage considering my usage is pretty high with continuous business trips around TS and AP and sometimes to visit my branch in Pune.
3. Does replacing all 4 solve the issue or does the issue keep on repeating?
4. And what are the measures to be taken to prevent further issues on the car?
SK01 is offline
Old 8th June 2024, 16:40   #55
Thanked: 30 Times
Can you please share the FNG details, may need it for my 2014 Vento TDi.
Old 17th June 2024, 10:39   #56
Its called Aiyappa Garage. Please enquire with VW Palace cross service on the cost if they offer at same price now. Also, you can check with Bosch service on Mysuru road.
Old 25th June 2024, 17:03   #57
Thanked: 202 Times
The injectors on the VW Vento/Skoda Rapid are manufactured by Continental. Inherently problematic. Bosch service may not be of much help.
Old 13th January 2025, 13:44   #58
Avikbrio's Avatar
Thanked: 194 Times
So I recently decided to get my Injectors serviced for my 2017 Polo 1.5 TDI with Stage 1 Map which had done 88k kms. The injector sound had gotten louder over the months, the car had gone into limp mode once and at my last service in December 2023, I was told the injectors are not in a good health.
I took the car to Hema Diesels in Yeswanthpur, Bengaluru. They took out the 4 injectors and shared a report which shows all the 4 nozzles delivery line were clogged and fuel intake was much lower than normal. Rest of the values were normal They advised replacing the nozzles but they did not have Continental nozzles in stock. I asked them to fully clean and service them anyways (for which they took 5k). 3 hours later the job was done and the injector was back in the car.
Now the car had completely changed for the worse. Pickup was very low and the car was struggling to move along in 2nd gear from 10 kmph. FE had dropped by half. They suggested to drive the car for another 100 kms for the injectors and ecu to adapt.
My annual service was also due around the corner so I decided to get that done last week. I also asked them to run the injector minimum deviation adaption from VCDS which they did and took about 15 mins. Post service the car felt slightly better but it was still sluggish, as if my car had gone back to stock map. FE had improved marginally but still not what I used to get before injector servicing.
My two remaining options is to get the nozzles replaced (which costs about 6k per nozzle) or get the entire injectors changed (which costs about 25-30k per injector).
Avikbrio is offline
Old 15th January 2025, 11:31   #59
Thanked: 370 Times
Struggling in 2nd, how would one be able to cover 100kms, if at all there was no issue, a highway run, or a few days of driving would be needed. I would not trust a FNG again, if their service has only made matters worse. Find a set of 4 injectors in the used market, or if you want even more peace, buy new ones which will come with warranty as well. Replace the nozzles if you would feel so, but consult another diesel shop before doing as well.
You could have checked the injectors health via VCDS as well. You should not get deviation above 1mg/str. If at all you get, it is on its way out. You may also do this test now, if you have your vehicle. The injectors being CR here, will also have a solenoid in its place, which can go bad, and if it goes bad, then it will allow return line to be open instead of blocked, and hence the system cannot generate enough pressure to inject and overall resulting in less delivery output. This solenoid has a spring, mechanical, and can go bad, over usage, so one may replace the spring if at all it is the culprit, and you can find out this thing in the spray pattern, if the spray pattern is good, nozzle is good, but the volume delivered may be less as some diesel escapes due to the solenoid not closing completely. You need a person who can test the solenoid and nozzle for you as well as the calibration shims for any rust.
A method to do this with the injectors in the car with VCDS is to check reading of injectors, with the MVB having beginning of Injection period. If this value is positive, the solenoid is closing as per ECU expectation. If negative, then closing before the ECU expectations, and hence the solenoids problem. Do let me know the results if at all you perform the test.
Happy Motoring!
Bsilver is offline   (2) Thanks
Old 15th January 2025, 12:41   #60
Avikbrio's Avatar
Thanked: 194 Times
Happy Motoring!
Thanks for the advice! I will check what you mentioned and report back with the findings.
Avikbrio is offline
