Vehicle Details:
Audi Q5 3.0 TDI Quattro
VIN No- WAUZLA8R8BY700227
Vehicle Breakdown History:
April 2016
Vehicle failed to start (Engine Cranked but didnt get fired up) after parking overnight at a farmhouse and we took it to a local workshop (Wheelspin, Coimbatore) which is where we gave it for periodical service.
After initial inspection, workshop person said that there was an issue with the Fuel Pump and asked time for getting a replacement.
June 2016
Days, Weeks and after 2 months of waiting, there is no proper answer from the workshop about the status of the vehicle. We lost patience and took the vehicle to Audi Coimbatore Service.
After inspection, Audi Service said that the entire fuel line and the Fuel pump assembly has to be changed and gave a quote of Rs 6.5 Lakhs for the repair.
At this point, a mutual friend suggested another Coimbatore based workshop who is well versed with imported vehicles. We said to Audi that we are taking the car out as the repair estimate is high.
From July 2016
We brought the vehicle to Jagans Workshop ( he was with Skoda Service previously). After inspection he said there is no need to change the fuel lines (instead he said he will clean it and fix it) and said that he will source a Fuel Pump.
After a month or so, he sourced a used Second hand Fuel pump and tried it, but vehicle failed to start.
He then went ahead and imported a new BOSCH OEM Fuel Pump and tried it. Vehicle didnt fireup with the new pump. Along with a fuel pump, he changed 3 Fuel Injectors and LHS Fuel Rail
Feb 2017
After agonising followups and waiting, wehicle is still with workshop. Still unable to diagnose the issue.
Note: The Vehicle does not throw any error codes and ECM too was working well.
These cars are extremely complex in nature. It's mandatory for their owners to know a good independent workshop (once the car is out of warranty). This point isn't optional - it's compulsory.
You mentioned this happened at a farmhouse. Was the vehicle topped up at a highway fuel pump? Could be adulterated diesel that's the culprit here. You must top up the tank at a trustworthy pump in your city before hitting the highway. These cars anyway have such long tank ranges that, for 9/10 trips, you can come back home without refuelling.
Unfortunately, it does appear that all of these workshops have done a lot of trial & error with the car...but don't have any results to show for it. I can only imagine the torture she's gone through, having been opened up & reassembled like that.
Would suggest asking around and taking her to someone who really understands these cars. If not, flatbed it to Bangalore where you'll get a lot of technical expertise.
It's impossible to not diagnose why a car won't start, over 10 months. That too, for a car that was running perfectly fine just a short while before refusing to start.
There is some information missing here. How did the workshops arrive at a diagnosis of fuel pump failure? What else was checked? Was quality of diesel in the tank tested for contaminants? What about other factors like the electricals, engine internals?
Wondering: Do Audi fuel pumps have some kind of coding to link it with the VIN of the car, and any other fuel pump won't work? I'd guess it would throw an ECM error too, in that case.
Hope the fuel was completely drained and refilled? Like GTO mentioned, hope it is not a fuel quality issue.
What kind of diagnostic software and hardware is the garage using? Is it the right one for the make and not a generic or mobile based stuff. These cars are very difficult to diagnose without proper access to the scanning software.
Trial and error method am sure the garage also would have done, first would be to check if the fuel is getting pumped from tank and filters are aok. Then move on to rail and take a reading of pressure, then to injectors. That is pretty much one can do. Next would be to rule out any other electrical or sensor based issue (but then again that would show as an error).
How old is the vehicle and how much has it done?
Few stuff gathered from web search
http://www.vwaudiforum.co.uk/forum/s...759#post936759 http://www.vwaudiforum.co.uk/forum/s...604#post974604
So it can be a coolant sensor, the engine immobilizer, crank position sensor and lot more including fuel pump and rails. Check one by one and see if it helps.
Have you tried out a garage by the name KR Auto Care in Coimbatore. When I was looking for a used BMW 530d, a seller was claiming that KR Auto Care does a good job in servicing premium cars and his 530d was regularly serviced there. I don't have any personal experience though.
Originally Posted by ece2k2
(Post 4151114)
Have you tried out a garage by the name KR Auto Care in Coimbatore. When I was looking for a used BMW 530d, a seller was claiming that KR Auto Care does a good job in servicing premium cars and his 530d was regularly serviced there. I don't have any personal experience though. |
I would recommend the same. KR specializes in BMW's but I guess they might be able to help with VAG too.
Also do check out CAI at Lakshmi Mills. No personal experience with them, but I've seen them working on a lot of off beat imports, and my friends mercs (w140 & 220) are maintained there.
Sorry for the delay in responding.
Originally Posted by GTO
(Post 4151043)
Y |
Thanks GTO for the reply. Vehicle was fuelled up in a reputed fuel pump only which we regularly use. We faltered badly on choosing the independent workshop for servicing the vehicle. Could you please suggest a independent Workshops in Bangalore where we could take her. We have tried with 3 workshops in Coimbatore but no one seems to diagnose the issue.
Originally Posted by SS-Traveller
(Post 4151075)
It's impossible to not diagnose why a car won't start, over 10 months. That too, for a car that was running perfectly fine just a short while before refusing to start. |
Hi SS-Traveller,
After the Independent workshop whom we left the car after break down didn't give any proper insights, we took the car to Audi Service and they were the one who said Fuel Pump had seized due to fuel contamination. They didn't test the Diesel in the tank for fuel contaminants. Audi Service only said contaminants is the reason for fuel pump seizure and gave the quote to change fuel lines and faulty fuel pump.
Originally Posted by Jaggu
(Post 4151085)
Hope the fuel was completely drained and refilled? Like GTO mentioned, hope it is not a fuel quality issue. |
Hi Jaggu,
Thanks for the reply. Vehicle was 2011 Manufactured, We bought the vehicle at 65K at the odo as Pre-owned. Vehicle broke down @75k at the ODO.
In-dependant workshop uses a Hardware based diagnostic tool ( i dont have the details now). In all the trial diagnosis we checked Crank Sensor, Fuel pump ( imported a new one) and changes LH side Rail. We did not check at Engine Immobiliser. Engine and Electrical are in perfect shape.
(Post 4151114)
Originally Posted by JayD
(Post 4152642)
I would recommend the same. KR specializes in BMW's but I guess they might be able to help with VAG too. |
Thanks. I will check with KR Auto care.
Originally Posted by Ecstasy_Drive
(Post 4154381)
Could you please suggest a independent Workshops in Bangalore where we could take her. We have tried with 3 workshops in Coimbatore but no one seems to diagnose the issue. |
You could try SK Karzone (
http://www.team-bhp.com/forum/bangal...bangalore.html). Have heard good things about them, and they treat Team-BHP members with special care.
...Audi Service and they were the one who said Fuel Pump had seized due to fuel contamination. They didn't test the Diesel in the tank for fuel contaminants. Audi Service only said contaminants is the reason for fuel pump seizure and gave the quote...
Hmm... so that's the missing link. Hope you have the old fuel pump with you, to check if it has seized or not. Maybe there's nothing wrong with it, or maybe it's repairable.
Just wanted to Enquire if you had tried out on a German Cars Specialised Garage named Candour Auto Tech, Trivandrum Kerala. If not, I would recommend to try your luck there. maybe they could help you out fire up the machine.
To my knowledge they recently solved and fired up a W140 S600 V12 which travelled pan India on a Flat Bed, which even the Mercedes Dealerships couldn't resolve.
And many other dealership dropped out Cars including BMWs Audis etc.
(Post 4151043)
Would suggest asking around and taking her to someone who really understands these cars. If not, flatbed it to Bangalore where you'll get a lot of technical expertise. |
+1. Looking for an independent, quality Audi workshop at Bengaluru. Any suggestions welcome
Hey Guys,
A friend of mine has an Audi Q5 which is posing some issues. Just wanted to post about it here so that we can get your valuable insights/views. I didn't know if this is the relevant thread to post this so plz excuse me if this isn't the correct thread.
Car: Audi Q5
Year: 2013
Odo: 1.05L km done
The issue started when the car hit a pothole a few months back after which it started jerking a little while shifting from 2nd to 3rd gear and downshifting to gear while/after breaking. While shifting in manual, the jerking wasn't really noticeable but can't say it wasn't there. Except for the botched pickup, it drove normally at cruising speeds and didn't show any error on the MID or Instrument Cluster.
We took the car to the Audi Okhla workshop and their diagnosis was that the transmission and mechatronics have failed and they advised we should replace multiple clutches and the mechatronic unit at a cost of 6L !
We felt that they simply want to do a replacement without even finding the problem and were hoping to get it repaired rather than replacing it. My friend wasn't really looking to spend such a big amount on the car either.
He then showed it to a renowned FNG who advised him to keep driving it until any faults show up in the system/display so that it will be easier for them to diagnose the problem. They were reluctant to open the transmission. Even though they have the relevant experience according to me, they're saying that the car can't be bought back to 100% once the transmission is dismantled (which I somewhat agree with).
The instrument cluster showed a gearbox fault light recently which disappeared when I started the car the next day. The MID also at times advises me to 'Change driving style to avoid overheating' when I press the accelerator hard.
I was hoping I could get your inputs on this. What should he do according to you guys ? If possible, Please advise any FNG in Delhi/NCR who would be confident enough to dismantle and repair the transmission. He hopes to enjoy driving the car for another 2 years and would hate to sell it.
Originally Posted by 10nitin
(Post 5168018)
The instrument cluster showed a gearbox fault light recently which disappeared when I started the car the next day. The MID also at times advises me to 'Change driving style to avoid overheating' when I press the accelerator hard. |
The FNG probably doesn't want to take the responsibility of opening up an expensive gearbox, and understandably so. But also that's atleast a couple of faults now showing up which the Audi workshop should be able to pick up on their scanner. Ask them to show you a written diagnosis of the faults and the parts that need to be changed.
