Re: After-market accessories causing electrical problems in my Vitara Brezza When you install accessories please follow the guidelines:
a) NEVER splice or cut the OEM wiring loom
b) ALWAYS use a the appropriate sized wires based on the expected maximum load. Add a 20-50% margin and size the wires to be on the safe side.
c) ALWAYS use a fuse when tapping directly to the battery terminal for power. This is done only when necessary for e.g. when installing aftermarket accessories that draw more power than the OEM wiring loom can handle OR if the wiring loom does not have a provision for the add on accessory. Common accessories are ICE amplifiers, horns, headlamp bulbs. Some require a relay (commonly called a 'cut out') if you use the one of the wires in the factory loom as a signal wire. Again horns and headlamps bulbs or fog lights are good examples.
D) DO NOT treat wiring connections as a child's job. Wires are supposed to be connected using spade/ring/butt or other connectors that form a positive connection to the other part of the circuit or load. Yes, there are things called 'butt connectors'. I am not kidding you. Butt Connectors Loose connections cause additional power drain and can cause sparks which lead to a fire. The higher the current draw the more essential it becomes to use connectors and not simply join 2 wires. I prefer to use a crimping tool for the job. You get two types, the ratcheting and non ratcheting. The former are the best but more expensive. They deal with two types of connectors insulated and non-insulated.
OEM looms wire gauge (and alternator/battery) are selected based on the expected load of running OEM accessories only. After market accessories add to those loads so it is best you have an auxiliary loom to handle it.
