Originally Posted by ashwinprakas Can't they be pushed back in?
With motorcycles we just push them back in one at a time, I understand that there would be more resistance considering the size of the hardware at hand, but should I consider opting for special tools? If so please advice. |
No they cannot be pushed in without tools. Use a C clamp to push it in. But this is mandatory if you replace the pads. Be careful about the rubber boots around the piston.
The setup was way wonkier than I'd expected it to be, guess I was using the jack upside down as well.
Would anyone recommend a good brand to buy jack stands from as I'm in the process of sourcing all the tools and I see a couple of manufacturers selling them on Amazon namely;
You get what you pay for is all I will say. Considering your life depends on these things holding your car up whilst your are working underneath it's well worth the money.
Also, you will need a 2 or 3 tonne floor hydraulic jack, sometimes called a "crocodile jack" in India to lift the car. Make sure you place the jack stands at the correct positions on the chassis. Refer to the manual. It is generally where you place the scissor jack when changing a flat tyre.
Would need to source a rubber mallet as well, I doubt my makeshift one would survive a car.
Please buy the tools required. Don't skimp. Firstly this is a critical part of the car you are attempting to service. Secondly, using the correct tools makes it far easier to do the job correctly.
A friend who is a service technician at MGP(in another district) did mention that the systems on our cars are self bleeding and would automatically remove air bubbles trapped in the lines, for the time being I thought that might be the case with new brake systems as once I while swapping my motorcycles brake line I could not get pressure no matter what I did so I closed everything up and called it a night, next day morning after bleeding a few drops I got compression just like that, which was so strange that at the moment I even considered religion.
Sorry, that's a load of tosh he's spouting. All hydraulic brake and clutch (clutch not applicable to the M800) systems need to be bled. First at the master cylinder and then progressing to the calipers and slave cylinders.
That would be a few hours of my life wasted, as I seem to be getting solid information from this thread rather than the half-bottomed logic he usually gives me for messing up things.
I reckon you'd be spending more time on this than an experienced mechanic no matter his working style.
There is always a learning curve.
But after brake pad and fluid replacement if I'm unable to resolve the issue then I might go back, which I doubt is unlikely, as I'm also considering replacing the adjuster cylinder as the car is going to turn 10 soon and other than the cylinders being replaced once I do not recall anything else being replaced. Do recommend if anything else needs to be replaced.
Replace the parts only as needed after evaluating their condition. Take an experience tech's advice if needed.
I have taken note of the suggested tools and consumables, though I'm still uncertain whether I'd need clamps to push the pistons in on the front caliper, I was under the assumption that this could be done by hand, like on a motorcycle.
As mentioned above you would need a C clamp. The caliper push back tool I bought was specifically for cars with rear disc brakes and parking brakes where the piston has to be turned either clockwise or anti clockwise to push it back into the caliper cylinder.
With the motor running I did try to engage the hand brake to see if it made a difference in brake pedal travel but it did not, isn't that strange? As I expected there to be a change in the brake pedal travel as my understanding from the video Jeroen shared is that the hand brake pulley engages the brake shows from below which should in fact result in less travel for the brake cylinder, right?
Wrong, the hand brake activates the slave cylinders via a separate mechanism. It is also called an 'E' brake in some countries because it can be used if your car experiences a hydraulic system failure.
I did move the car a bit in reverse and brake hard and that made no difference, will try again tomorrow in open space and report if there's any difference.
This is applicable only to some cars, not all.
Originally Posted by ashwinprakas The question was with regard to the front brake caliper's pistons since I was under the assumption that you were referring to those, now after going back I guess you were referring to the brake liners, in which case I believe the procedure is to remove all springs and take out the brake liners, reset the auto adjuster and then put everything back in place. Please do correct me if I've got anything wrong. |
Install the rear liners, put on the drum, turn the star wheel clockwise/anticlockwise till it engages the drum, then back off about 2 revolutions of the star wheel till the drum turns freely. Do the same for the other rear wheel.
listening to the whole issue he is confident that rather than target the rear drum adjuster I should go ahead and bleed the system of air, and recommended the following pattern;
1. RLH
2. FRH
3. RRH
4. FLH
Do share your thoughts on the same.
As mentioned in an earlier post, I suspect you have air trapped in the system OR have a faulty master cylinder. While there are several opinions about the right sequence to bleed your brakes, the procedure I follow on
RHD vehicles is start from the wheel furthest away from the master cylinder which in our case will be:
1) Rear left
2) Rear right
3) Front left
4) Front right
You can choose to do a 2 person brake bleeding procedure, a gravity bleed or one with a pressure canister. I'd suggest doing # 1 with the help of a friend. There are plenty of YT videos on how to bleed your brakes. Always make sure you keep the reservoir topped up. It should never run below Min level marked on the body. Use freshly opened container of the correct brake fluid. Maruti takes DOT 3 or DOT 4. Check the manual.
