Team-BHP > Under the Hood > Technical Stuff
View Poll Results: Are you happy with your OEM Headlights?
Yes 109 26.33%
No 305 73.67%
Voters: 414. You may not vote on this poll
Old 10th October 2018, 16:42   #91
hiren.mistry's Avatar
Thanked: 602 Times
Default Re: Are you happy with your OEM Headlights?
My Punto had decent set of headlights, despite that I had installed a set of 100/90 bulbs along with relays. It was an amazing setup, no problems with visibility. After this, it's difficult for me to drive any car with stock headlights.
hiren.mistry is offline   Reply With Quote
Old 10th October 2018, 17:00   #92
Kosfactor's Avatar
Thanked: 539 Times
Originally Posted by adg_andy View Post
Not happy with mu Duster'16 headlights. Swapped the bulbs with Osram NB (H1 & H7). The low beam is somewhat better, but still not happy with the high beam (H1). Also, off topic, my RHS beam focuses a little bit lower than the LHS. Is it normal?
Yes it is, for India this is standard on all cars to prevent glare.
Regarding night breaker bulbs, they have better reach and more intensity, however the spread of light is usually not as good as stock bulbs resulting in poor kerb side illumination.
Dusters headlights are a bit weak for highways, especially considering it being an amazing highway cruiser.
You may need to go with halogen aux lights and wiring them up to the high beam .
Kosfactor is online now   (1) Thanks Reply With Quote
Old 10th October 2018, 17:35   #93
SCORPION's Avatar
Thanked: 1,245 Times
How is this achieved? I mean, let's say you buy a pair of nightbreakers, or individual bulbs. Is there a marking on the bulb to tell you which bulb goes which side? I have tried to figure out but could never find any marking so I just fit them at random. Or is it a reflector thing and not the bulb?
SCORPION is offline   Reply With Quote
Old 10th October 2018, 17:43   #94
Kosfactor's Avatar
Thanked: 539 Times
It's in the headlamp assembly itself, so you can swap the bulbs without worry.
The headlamp assembly is designed this way. For left hand traffic, the right headlamp with be slightly dipped. The left headlamp on the other hand let's you see the kerb clearly in the night.
Originally Posted by alpha1 View Post
This is desirable since we don't want to flash the headlights on to the oncoming driver's eye ... or do we want to? (Asking this because I once overheard a guy telling the accessories walla that he wants a headlight focused so that should aim at oncoming SUVs driver.)
There are some highway warriors who angle the right side AUX lamp slightly up for this purpose, but in reality trucks and bus drivers have ways to deal with it. They told me that they slightly move over towards the center of the road if flashed on with high beams.
Objectively they should light up their way forward better than blinding the opposite side.
Last edited by Zappo : 10th October 2018 at 18:45. Reason: Please do not make so many back to back posts. Respond to everyone at one go, use the multiquote button. Posts merged.
Old 10th October 2018, 17:54   #95
alpha1's Avatar
Thanked: 1,248 Times
Old 10th October 2018, 21:22   #96
Thanked: 3,947 Times
I voted yes, but it is actually a tie.
My Storme and Kwid 1.0 have powerful headlamps while my Celerio is average and Ciaz could do with better throw.
My ex Dicor had the worst throw. Ex Chevrolet Beat and Sumo Gold were powerful.
PrasannaDhana is offline   Reply With Quote
Old 10th October 2018, 22:09   #97
rapid_fire's Avatar
I missed the poll i think. I am really disappointed with the original halogen projectors in my skoda rapid. I always drive in dipped mode, and use high beams only when itís absolutely necessary and its not hurting anyone else. I found these low beams are pathetic in highways, especially if it is poorly lit.
I believe the adequacy of the light depends on the speed at which you are driving. Most of the OEM set ups are adequate for a normally lit road when driven around 50-60 kmph. But if you are driving at around 90-100, then you need lights with better throw.
rapid_fire is offline   Reply With Quote
Old 11th October 2018, 09:04   #98
Thanked: 121 Times
Originally Posted by McLaren Roxx View Post
Voted No for Hexa
Although it comes with a twin Projector + High beam setup, light output is below par, especially for a vehicle of its size.
Many owners are converting their setup to LED which provides slightly better output. But in my opinion, Tata should have provided this as stock.
Upgrading to a higher wattage 90/100 setup, especially for the projectors is not an option due to its small size and resultant heat generation.
Voted no for the Hexa as well.
As ever, any changes to the lighting set-ups, have already burned through wads of cash trying to figure out the best configurations.
Currently, I run:
1. 55W HIDs for the projectors (RSR kit)
2. Stock Osram halogens for the reflectors
3. Like a veritable idiot, 35W LEDs for the fogs (all these do is push out a lot of glare. Tried to set up the fogs with HID, but that cause canbus errors, even with error cancelling resistor set-ups from Morimoto
The projector design for the Hexa is abysmal. Doesn't reach out more than 6 odd meters even on dark roads, and without the high-beam on, it is impossible to see beyond.
Not sure how to address the reflectors, because without them, night driving on the highway is next to impossible.
thedragonreborn is offline   (1) Thanks Reply With Quote
Old 11th October 2018, 11:46   #99
RGK
RGK's Avatar
Thanked: 266 Times
Absolutely true.
I have upgraded my OEM bulbs (60/55W) to 100/90W after the warranty period in my Figo. Now it is better.
As far as I have seen, Tata Ace has one of the best OEM headlights (with TVS-Lucas reflector) today.
RGK is offline   (1) Thanks Reply With Quote
Old 11th October 2018, 13:18   #100
purohitanuj's Avatar
Thanked: 298 Times
Voted yes for my Scorpio S10
I just love the OEM setup with fog lamps. The best part is corner lights which really helps in hills.
However, note that almost all incoming traffic (including trucks) ask me to switch to low beam while I am already on low beam. Single dipper makes them realize that I am already on lower beam. Initially I thought that my beams were not aligned but were declared fine during a service.
purohitanuj is offline   Reply With Quote
Old 11th October 2018, 15:56   #101
varoon9999's Avatar
Thanked: 65 Times
I've voted "NO". Though I am not fond of driving late at night. I've always felt both my rides have poor throw, specially when they are used without OEM fog lamps.
Laura- Projector set up with halogens provide abysmal throw.
Punto- Slightly better than Laura's spread but not that satisfactory.
varoon9999 is offline   Reply With Quote
Old 11th October 2018, 16:10   #102
Voted no.
I am not happy with the stock OEM set-up on my Grand i10. Not changing the set-up for now as the car is just 6 months old and ASS guys said changing would void warranty. I have driven a friend's VW Polo (900+ kms) on one of the trips a while back and liked the set-up better compared to my car.
deveshshukla53 is offline   Reply With Quote
Old 11th October 2018, 17:18   #103
bhp_maniac's Avatar
Thanked: 136 Times
Voted NO
Celerio - Had the best OEM headlights among the cars my family has owned
Swift - OEM headlights were terrible to begin with, however got a little better after changing bulbs to Philips Xtreme vision.
Rapid - I felt the halogen projectors are inadequate, high beams are just OK.
Xeta - Just OK
On a side note, I used to drive a friend's Santro 2004 few years back and I can vouch for its headlights. They were the best OEM headlights I've ever experienced
bhp_maniac is offline   Reply With Quote
Old 11th October 2018, 23:32   #104
Thanked: 506 Times
I have voted YES for my Ford Aspire. However the actual feeling is neutral. Neither I have any complain nor I am happy about the OEM setup.
I have done only one modification. I have asked the service center people to raise the beam for better spread of low beam and more travel for the high beam.
Performance is adequate for most of the situation when compare to other cars at similar price or segment. However the OEM setup struggles when there is rain or I am driving opposite of heavy truck/bus traffic in single lane highways. Life becomes hellish when facing the combination of both.
I want a 100/90w setup mod, but the issue of warranty violation is holding me back.
NaXal is online now   Reply With Quote
Old 12th October 2018, 22:25   #105
amitjha086's Avatar
Thanked: 172 Times
I feel the headlights on my Dzire are quite inadequate. It gets worse when its raining. I drive little in night, yet, would like to upgrade them someday.
amitjha086 is offline   Reply With Quote
DIY Guide : How to get the sparkle back in your old (dull) headlights! Punzabi DIY - Do it yourself 50 7th October 2017 10:31
Twilight driving - When exactly do you switch on your headlights RajaTaurus Street Experiences 112 5th March 2012 18:11
Ride on but with your headlights on during daytime in Kerala! jkdas Ride Safe 58 10th June 2010 16:34
Turn your headlights off and only use the horn! Rtech Street Experiences 37 13th April 2006 16:04
Copyright ©2000 - 2019, Team-BHP.com
