-   -   Brakelight Does not Go off (https://www.team-bhp.com/forum/technical-stuff/20287-brakelight-does-not-go-off.html)
pcnworld 8th January 2007 03:37
hi
tonight i noticed that the brakelight on my car did not go off at all...eventually i removed one of the fuses...
what could be the cause of this? Is it a problem with the fuses...or the brake switch...?
Pankaj401 8th January 2007 09:47
brake light switch or the relay.
S@~+#0$# 8th January 2007 10:24
Yes, I think it is the relay too.
DRC 8th January 2007 11:55
There is not any relay... Just check the switch or switch mounting.
Switch is clung to a hole on a frame, which is likely to come out of its place. When it comes out, it remains on.
Pankaj401 8th January 2007 12:10
Correct. There is no relay for the stop light.
pcnworld 9th January 2007 18:19
Thanks...there was a small plastic piece which was connecting the brake pedal and the brake switch...it had been broken....fixed another one with glue...thanks again for ur help
