hello sir
i am software engineer and developed Automatic vehicle tracking system using GPS technology, to integrate it with your Autocop XS security system i require the wiring diagram /or manual of autocop XS since it is not available with us , it will help us in installation with autocop XS unit in proper way.
regard
subhash vatyani
Here is the wiring Diagram & Remote Control Operations for Autocop XS 6000/6050.
Originally Posted by drkumarmp
(Post 2665247)
Here is the wiring Diagram & Remote Control Operations for Autocop XS 6000/6050. |
Is there any information about how to enter programing mode
mentioned under "Condition" for Sr. No. 13. How do I initiate key learning / key matching? Thanks.
Originally Posted by Ayson
(Post 3126413)
mentioned under "Condition" for Sr. No. 13. How do I initiate key learning / key matching? Thanks. |
If you have an autocop remote that has a green led then you can follow this procedure for key matching -
Unlock the Driver Door
Ignition on
Driver door is open
5 times press door switch slowly - system will make a beep
2 times press remote's lock button ( the one to be paired) - beep again
Done
Originally Posted by k2max6
(Post 3126458)
Ignition on
Driver door is open
Done |
Sorry, i didn't mention any details. I have a Ford Ikon Flair, which comes with a 3 button remote: Lock, Unlock and *. I don't think my system has any way to beep like you mentioned.
It's a very basic system, ie.: lock, unlock, and alarm goes off if any door is opened when locked. No motion sensor, impact sensor, power window control, proximity sensor, etc....
Anyway, I will try what you mentioned, but a doubt, by 'ignition on' do you mean engine started or just the last position of the key? Thanks.
(Post 3126476)
Anyway, I will try what you mentioned, but a doubt, by 'ignition on' do you mean engine started or just the last position of the key? Thanks. |
Last position of the key.
This should work as long as you have an autocop remote that has a green led. Won't work for red ones.
(Post 3127197)
This should work as long as you have an autocop remote that has a green led. Won't work for red ones. |
Mine's red. :D You wouldn't happen to know the procedure for that one would you?
There is a set of switches on the Autocop XS PCB for controlling different functions like alarm, horns, etc. The legend for these switches is is placed/stuck on the inside of the small cover placed above the switch. In my unit, the legend somehow got soiled. And I need it to switch off the alarm and rev horn off. If somebody would be kind enough to post a image or just the data, I would be grateful..
