re: Engine Failure | Hyundai Creta Diesel AT | EDIT: Hyundai offers discount & resolves matter amicably Quote:
Originally Posted by arjunrudra Hi All,
Just an update. I got a call from the service area manager for KA state. A very nice gentleman called Nikhil had called. The only point of discussion was that cars are mechanical bits and it can fail. Probability was stated.
I have anyways asked for him to talk to his superiors and look at giving us a solid response.
So waiting on them. I wish they come clean and admit its their fault and do the needful. its only fair.
Thanks all for the support.
Hope they give a favorable response to re-instill some comfort and dependence on the Hyundai Brand for me and for others who are unnerved by this situation. |
I have read the complete thread and agree with Hyundai and the members who has identified the cause of the failure as lube failure. The marks on con rod big end, bearing shell and big end bearing journal on the crank point to a lube failure.
The oil is supplied to the big end through the oiling channel (aka the artery hyundai a.s.s mentioned) that runs within the crank shaft. There are oil exit holes on each main bearing journals and big end bearing journals. Oil gets into the crank through one of its its ends pressure fed from the pump.
The failure (as visible clearly a lube failure) is only at one of the journals. This indicates other journals before and after this particular journal was getting oil and the choked artery is not within the crankshaft because if it were other journals would also been starved of oil. If it was indeed within the crank it would be a blocked hole at the most.
If its a blocked journal oiling hole it could be because of two reasons:-
1) Some debris traveling through the oil channel within the crank and finally entering and blocking this particular hole. But chances of only one journal getting blocked is still very low. If it was indeed due to some debris traveling through the channel within the crank other journals will also show signs of oil starvation.
2) The big end bearing spun in its seat blocking the oil supply hole gradually. More likely.
If its 1 the debris causing the block will still be inside the crank unless its been cleaned by now. To find out cover all holes with masking tape except this one and blow compressed air through crankshaft oil feed hole. Put a clean white towel in front of the failed journal's oiling hole to catch any that might fly out.
If its 2 it will be harder to find as the bearing may have spun after the lube failure. But if there is no debris coming out of the hole when blown with compressed air I would diagnose the failure to be caused by a spun bearing.
Apart from lack of lubrication, high load, gunning before warming up, wrong oil etc spun bearings can be caused by other reasons including using a connecting rod with incorrect tolerance or a using a bearing shell with incorrect tolerance during assembly. Spun bearings are rare cases in a stock engine or even a lightly modified one. But so is such an engine failure in a car with a proper service history.
