Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | 32,631 views |
27th September 2021, 18:55 | #46 | |||
BHPian Join Date: Jun 2019 Location: Kolkata
Thanked: 2,717 Times
| Re: Tips on maintaining the Hyundai Creta for cheap Quote:
Thank you for the kind words and hope that you jump on the DIY bandwagon soon | |||
(1) Thanks |
The following BHPian Thanks Chhanda Das for this useful post: | shancz |
27th September 2021, 20:23 | #47 | ||
Senior - BHPian Join Date: Oct 2020 Location: Ranchi
Thanked: 5,322 Times
- I am usually away from my hometown(i.e. location of the car) so wasn't sure about getting something which wouldn't be used that often but since servicing is an annual thing anyway, like you said worth the investment. Not to forget the fun factor. I will spare my experiences with various incidents at the SC/FNGs, they won't just derail the thread but will also qualify as horror stories in automotive terms Quote:
Impurities became a concern only after reading a thread here but that was on a rarely used car and after many years without a coolant change, had some orangish spots which was rust from somewhere in the system. The SCs check that as well. But like you said not a concern on my car. I am going to stick with the coolant change at 20k/2yrs, as prescribed since my car lacks a temperature gauge and its the normal/green coolant so won't risk it. One thing I have decided is to move from a time-based schedule(courtesy SCs/FNGs) to a kms based schedule. The car runs slightly more than 5000kms/yr. Main concern is the degradation of engine oil but since I am using a fully synthetic 0w20 as per the manual, I am assuming the degradation by time shouldn't be as much as mineral oils. Do you see any issues with this approach ? Also about the foam vs paper filter debate I just want to add what my Suzuki Access125's maintenance manual states : Air filters to be cleaned every 3000kms and in case of paper type they're to be replaced every 12000kms while foam types no replacement is mentioned. | ||
(1) Thanks |
The following BHPian Thanks shancz for this useful post: | Chhanda Das |
27th September 2021, 22:41 | #48 | ||||||
BANNED Join Date: Aug 2013 Location: Pune
Thanked: 2,939 Times
Infractions: 0/1 (7) | Re: Tips on maintaining the Hyundai Creta for cheap Quote:
(2) Thanks |
The following 2 BHPians Thank asit.kulkarni93 for this useful post: | anshuman1117, Varun_HexaGuy |
28th September 2021, 06:31 | #49 | ||||
| Quote:
I am very sorry to hear about your Lexus Quote:
I hope that I was able to explain my stance Quote:
My car is definitely well maintained but I am not sure as to whether it is better maintained than many of our fellow Bhpians. This is because most Bhpians are fairly knowledgeable and maintain their vehicles very well Last edited by Gannu_1 : 28th September 2021 at 09:55. Reason: Merging back to back posts. | ||||
(2) Thanks |
The following 2 BHPians Thank Chhanda Das for this useful post: | Lalvaz, shancz |
28th September 2021, 14:38 | #50 | ||||
https://www.team-bhp.com/forum/diy-d...-use-cars.html (DIY: Water purification system for use in cars) I found my TDS meter (image below) to very helpful while performing the above DIY :- Quote:
Sadly, I do not have a two or four post lift. We never even had an option of installing one since my late husband had a transferable job and government quarters do not allow such installations. Now, I live in an apartment but I cannot even dream of getting permission from the RWA (Residents' Welfare Association) for installing such a lift. However, I do have a pair of jack stands somewhere lying around in my home. Both of them are rated at 2 tonnes each since my car weighs substantially less than 2 tonnes. I also have a hydraulic trolley jack rated at 2 tonnes. I absolutely hate those hydraulic bottle jacks and hence never bought them. Thankfully, I have never had to use either the jack stands or the trolley jack for my Creta since it has adequate ground clearance for my son to crawl under it. For reference, my son is almost 6 feet tall and weighs almost a 100 kilograms | ||||
(1) Thanks |
28th September 2021, 17:35 | #51 | |
So unless you are using a long-life synthetic engine oil specifically designed for ethanol blends in petrol, it is better to replace the engine oil and the engine oil filter every year without waiting for the distance limit. Moreover, such synthetic engine oils for ethanol blends are slightly more expensive than regular synthetic oils. But then if you replace the engine oil every year you would not be able to reap most of the benefits of synthetic engine oils in the first place and hence it is better to use semi-synthetic or mineral-based engine oils of the recommended grade. I hope that I was able to explain the issue satisfactorily | |
(1) Thanks |
28th September 2021, 17:53 | #52 |
Yes absolutely clear and I got the point. I had no idea about how ethanol would come into the picture. So annual service it is and would use the recommended parts/oils which are cheaper than market as well. Thanks a lot |
(1) Thanks |
28th September 2021, 20:05 | #53 |
Senior - BHPian Join Date: Sep 2014 Location: Chennai
Thanked: 9,159 Times
| Re: Tips on maintaining the Hyundai Creta for cheap Ma’am- while you’re taking precautions, what Asit Kulkarni said is correct. The change intervals are calculated using extensive tests in full fledged labs, not dipping a tester into fluid and getting approximate readings. A safety margin is then built in. Please follow those intervals rigidly. You can save labour cost by doing it yourself and also save material cost by buying any other brand of lube or filter that suits your pocket and meets the defined standards. Trying to delay it based on basic tests just won’t work without compromising the life of critical engine components. |
(5) Thanks |
The following 5 BHPians Thank hserus for this useful post: | anshuman1117, Bibendum90949, Blooming Flower, Chhanda Das, hareshjethwani |
28th September 2021, 21:01 | #54 | |||
BHPian Join Date: Apr 2017 Location: Pune
Thanked: 1,135 Times
Due to my job requirements, I myself have done the wheel alignment many times along with the operators on umpteen number of cars with EPS using a Hunter-make sophisticated alignment machine which only a handful of wheel alignment shops own in India. However, the basic principle remains invariable whichever be the system. I knew merely by turning the inner tie rod clockwise and counterclockwise one can adjust the toe in-out settings of a wheel. And before we do this, it's absolutely recommended to fix/lock the steering wheel using a jig in a position so that the front wheels are just straight. Most of the time, for any FWD car, wheel alignment is restricted to toe adjustment only while caster, cambers etc. cannot be tweaked usually. In this whole process, I find very little scope for SAS calibration to get tampered with. After all, I am yet to spot any stand-alone wheel-alignment centre (in all parts of India I travelled so far) having a sophisticated OBD scanner not only to diagnose problems but also to re-calibrate essential sensors! That too within Rs. 300- 400 as you mentioned in point no. 15 in your opening post! I am really curious how they get access to such a confidential dataset of calibration values from a car manufacturer! BTW, how often do you get an alignment and balancing job done on your Creta? Is it fixed with a certain interval or do you decide by some subjective judgments? Quote:
(1) Thanks |
The following BHPian Thanks Blooming Flower for this useful post: | Chhanda Das |
29th September 2021, 08:12 | #55 | ||||
And touchwood, I have never had to make up facts. Here is some evidence of the first generation Creta receiving a 5 star NCAP crash test rating :- 1) https://www.carwale.com/news/hyundai...in-crash-test/ 2) https://www.zigwheels.com/news-featu...-c-ncap/20707/ 3) And before you say that the build quality is different, I would say that there is no evidence to prove your claim for the first-generation Creta. I have searched a lot including in the service manuals, body-in-white diagrams, etc but could not find a difference in build quality across countries for the first generation Creta. You may also say that the 1st generation Creta scored 4 stars in the Latin NCAP test but I would say that they didn't test for side impacts which the C-NCAP (evidence above) did. Similar build quality can also be proven by the very similar scores in each of the respective tested parameters between the Latin NCAP and the C-NCAP tests for the 1st generation Creta also known as ix25 and Cantus in other countries. Quote:
I did not say that it was a compulsion to use diesels since personal choice and/or legal burdens take precedence over financial benefits. Quote:
and EVs). I can also guarantee that not all owners' groups are the same and we have fans, haters and fence-sitters in approximately equal measure. However, I would request you to kindly refrain from hurling personal insinuations Quote:
Since you mentioned "suspension, master-slave cylinders, steering components", these are not something that need regular servicing unless someone is an abusive driver or drives regularly on very bad roads. For most car owners who keep their cars for a long time, such parts need replacement only once or twice during the lifetime of the car. And these are not some special cars that can only be fitted with Hyundai original parts. As long as the original specifications and quality are maintained/exceeded, any aftermarket part can be used. And many of my neighbours do use aftermarket parts in their Hyundais. One of them has even got a Bilstein suspension on his i20. You have reiterated my thoughts exactly. Not only are the replacement schedules given factoring in the average climatic conditions, but they are also given factoring in an annual cleaning and average city traffic condition as well. Hence, it is obvious that I can extend the replacement schedule by a little bit with a monthly cleaning of the air filters since my car is mostly used on highways and the filters do not get as dirty as those of a similar car used primarily in the city | ||||
(3) Thanks |
The following 3 BHPians Thank Chhanda Das for this useful post: | Artyom, Bibendum90949, shancz |
29th September 2021, 09:14 | #56 | |
Senior - BHPian Join Date: Mar 2020 Location: Blr/Kochi/Wynd
Thanked: 6,901 Times
https://www.team-bhp.com/forum/india...if-so-how.html (Are Indian Hyundais different from developed market Hyundais? If so, how?) It's a well known fact that most Indian manufacturers cut corners on safety when they make Indian versions. None of them are saints. Hyundai India are the masters at this game. Without any document or research, I can safely say Hyundai do water down their Indian versions. The first gen Creta may be an exception. The latest fiasco is Creta's sibling Seltos scoring a poor 2.xx rating in the GNCAP. It's anybody's guess the rating the new Creta would end up with. Last edited by Bibendum90949 : 29th September 2021 at 09:38. | |
(1) Thanks |
The following BHPian Thanks Bibendum90949 for this useful post: | Chhanda Das |
29th September 2021, 10:38 | #57 | |
Speaking of the brake fluid, Hyundai too does not specify a replacement schedule and recommends to inspect, top-up and replace if, as and when necessary exactly as I recommended in the original post/thread. Even the coolant is supposed to last for a decade (proof below). Here is a snapshot of a portion of the normal service schedule for the 1st generation petrol 1.6 Creta :- Hence, I believe that my recommendations are well within the ambit of the recommended service intervals. Essentially, I have recommended what you and our fellow Bhpian asit.kulkarni93 have suggested about the replacement of air filters and the fluids. I am guessing that the confusion arose due to the fact that I did not share the recommended normal service schedule of my car earlier and I sincerely apologize for that. I hope that I was able to explain myself properly Last edited by Chhanda Das : 29th September 2021 at 10:49. | |
(1) Thanks |
29th September 2021, 19:01 | #58 | ||||||
I am sure that you already know that a wheel imbalance or misalignment will invariably manifest itself on the treads of the tyres. The recommended wheel alignment interval is 10k kms but we usually decide on its requirement based on our regular monitoring of the tyre tread depths which is done with the help of a cheap analog tread depth gauge that is accurate up to two places of decimal in millimetres. Quote:
I hope that was able to clarify the different aspects Last edited by Chhanda Das : 29th September 2021 at 19:07. | ||||||
() Thanks |
29th September 2021, 21:47 | #59 | |||||||
And before signing off, may I know Hyundai has which automotive only college in Kolkata? Last edited by Blooming Flower : 29th September 2021 at 21:52. | |||||||
(3) Thanks |
The following 3 BHPians Thank Blooming Flower for this useful post: | anshuman1117, Bibendum90949, Chhanda Das |
30th September 2021, 07:06 | #60 | |
However, this wasn't always the case. If I remember correctly, the earlier CEO had issued a statement that Hyundai would never provide poorer built products in India or something along those lines. He was almost instantly shown the door and that is when the downfall started. Sadly, I do not recall whether this happened in 2016, 2017 or 2018 but it definitely happened in one of those years The first-generation Creta was not an exception. Similar build quality used to be the norm till the aforementioned fiasco with their CEO happened Also, if I remember correctly, didn't the Indian Seltos score 3 stars (barely) in the crash tests ? Last edited by Chhanda Das : 30th September 2021 at 07:08. | |
(1) Thanks |
