Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more Hello All,
It’s been a while I posted anything here. One of my previous OHC seller a senior citizen used to tell - As age goes up the financials are better, but wish I get more time.
Though money is not more but ok with gods grace part 2 is perfectly right.
Coming straight to point. My 2003 vtec run 81,000km yes you heard it right 81k km - the black vtec very close to my heart needs a Distributor O ring as per SA in whitefield honda. The engine oil leaks pics I will post here to know anyway from experts here as per the area it is falling. I will get the engine Bay Area pics also later. I think honda folks also are best bet to identity if there is any other leaks across or is it from distributor only.
This was my second visit - first visit we thought was oil seals so got hold original honda 3 seals and oil pan packing with my lovely dear friend in Chandigarh Honda. Then they came to know the distributor O Ring is needed and change that will fix oil leaks. So nothing is done so far with 3 oil seals in hand and the oil pan packing. All the diagnoses are done without taking the vehicle on ramp but I believe as they got a type 2 expert to see the oil leaks physically in front of me and just by the looks of it. Should I take a second opinion from other FNG or ask again Honda folks to put this on ramp and do detailed investigation. It’s simple an engine oil leak is very common in all type 2 - and areas are 3 oil seals, oil pan packing, valve packing and distributor O Ring. Only the valve packing is changed now with Original Honda part. Nothing complex here - but considering the time I have for a travel in 2 weeks - so I’m going to believe them unless anyone give me a better suggestion.
But no where I could get hold of this distributor O Ring. Part number photo attached. Even with my friend in Chandigarh is taking time. The point is I need to take the vtec to KL for a renewal. Tbhp always had been my saviour many a times in my need of the hours posts and requirements.
I need to fix this then only can travel the 350km up and return else is a risk with engine oil leak from distributor as per they claim. I need to travel by max 20th June for renewal.
Will there be anyone in this group aware or can help with the part or give me suggestions. I will be grateful for the life in this mission critical time to fix and take my vtec to KL.
Hope someone and god can help me in this grave situation. Will anyone in this forum can give me pointers or have this item in stock. :( |
