Hello everyone! Glad to share another modification post for my Ford EcoSport.
Actually, I completed this upgrade more than a year ago, but I hadn’t really found time to write down a post and share it here before moving on to Sync 5.
Yes, You are hearing right! I’m now working with the Sync 5 system currently, which is based on Android Automotive OS. It’s debuting in some Lincoln models starting in 2024, and appears in the Expedition and Explorer lineups from 2024-25. I’ll give you all a quick glimpse of that towards the end of this post.
Following my Sync 3 software modifications and the previous upgrade of Sync 4 on an 8-inch screen from existing Sync 3, this latest Sync 4 upgrade to the 13.2-inch screen wasn’t straightforward, for several reasons.
1. It’s a 13.2-inch screen, so mounting the display securely while maintaining an elegant look is challenging, especially with the restriction of not making any single changes to the existing dashboard.
2. Push start switch relocation as the screen hides it somewhat.
3. AC control unit change to accommodated the new audio control panel.
4. As usual, I’ve also carried out my own software customizations, such as enabling the built-in maps for India, B&O audio settings, ADAS features, and blind spot monitoring.
Not to forget: I’ve also carried out conversions from Fly Audio to various Sync versions in the past, so I can confirm that this upgrade is absolutely possible for facelift EcoSport models originally equipped with Fly Audio systems. I have done the upgrade to some fellow owners in owners groups.
For this upgrade mainly we need below parts
1. Sync4 12 inch variant Nav unit.
2. 13.2 inch display from Lincoln/focus/Kuga
3. Audio control panel
4. Newer AC control Unit to support on screen AC control
5. Newer USB Hub
6. display connector, and other connectors for integration.
7. and Panels and mounts for clean look.
8. and support OBD tools for configuring the module such as forscan.
Currently ford has improved its security, so flashing and converting the Navi region from one region to another is not possible for public users.
Below are the pictures of the part for your reference. 1. 13.2 inch Screen
2. Sync 4 module
4. USB hub
5. Telematics unit And the final output of this installation is below
On top of these modifications, I’ve also integrated wireless charging. As far as I know, this is the only EcoSport in the world equipped with so many features carried over from other Ford platforms.
I’m still working on adding the latest and greatest features from the 2024–2025 lineups, including the new Sync 5 system, Mobileye EyeQ4-based Level 2 ADAS, and a proper 360-degree parking visualization system.
I’ve uploaded a detailed video on my YouTube channel, which you can find at this link. You’ll also find all my other modification videos there as well.
Having already added the following features on the technology front, I can confidently say that the EcoSport Facelift with its timeless design continues to make a remarkable presence throughout its lifetime. And most importantly, all upgrades are fully OEM with not a single aftermarket part involved.
1. Level2 ADAS
2. 12 channel parking sensors.
3. Flank Guard.
4. Sync4 13.2 infotainment system with built in india maps and wireless AA,ACP.
5. Full Digital instrument cluster (Latest 2024).
6. Bang & Olufsen Audio system 10speakers.
7. Wireless charger.
8. Remote Start.
9. Blindspot system and Lane change assist.
10. Rear cross traffic Alert.
11. Fast Wireless charger.
12. Fully integrated sharkfin antenna.
13. Telematic unit to re-enable fordpass and hotspot modem.
14. Rear Disc Brake.
15. ST line steering wheel.
16. Drive modes.
17. Global window open and close and one touch all door power window.
18. ST illuminated Sill plates.
19 . Dual Type-C charging ports
Last but not the least
20. The Strom Variant Imported Grill and kid plate and bumper.
So, considering all the upgrades and features, my car can now technically compete with vehicles in the ₹20 lakh segment currently on the market. With that in mind, I have no plans to replace it for at least another 10 years, and I’ll keep exploring new possibilities and upgrades wherever I can.
Here are some ongoing projects I’m currently working on—I've already sourced all the required parts.
1. Full LED Headlight with Adaptive drive beam Assisted by Latest ADAS system.
2. Full 360 degree parking system.
3. Sync5 infotainment system with maps on instrument cluster.
Thank you for taking the time to read my post. If you have any questions or need any clarifications, I’m always happy to help and share more details.
