Honda Civic 2009 - 85000 km update
Our Civic had gone for its annual service on May 1st 2023 @ Engineering Exponent, Hoodi. The following things were done-
- Engine oil change (Motul 5W-30 ECO TEC PLUS)
- Air filter(Denso Cool Gear)
- Oil filter (Bosch)
- Radiator flush(Wurth concentrate) as the prev owner had used green coolant instead of blue
- Brake bleeding(Textar DOT4)
- Clutch system bleeding(Textar DOT4)
- Serpentine belt replacement(Fenner)
- iVTEC solenoid gasket replacement
Our car had a pretty bad oil spill a month prior to this, after everything we narrowed it down to the VTEC solenoid gasket going bad. This gasket was not available readily in Bangalore or via Boodmo, so we had to buy it off of eBay. It costed lesser, and was a genuine Honda OEM part (15826-RNA-A01).
After all this was done, belt was replaced, and while we were getting ready to leave, there was a strong vibration coming from the engine bay at higher rpms(4000). We decided to tell the guys at EE to check it out, and as it turns out the belt tensioner spring had become weak, so we had to replace that. Came home, placed the order on eBay for a Continental belt tensioner for the Civic, and now we had to wait for the second visit.
VISIT 2
We had decided to change the belt tensioner along with the VTEC gasket for the second time(The quality of Honda spares has gone down, the new gasket had developed a tear and had to be replaced as well.)
This time, they also used some Anabond around the gasket so that it acts as a failsafe when the gasket goes bad.
To get to the belt tensioner, the alternator had to be removed, and that gives us some space to get to the one bolt that holds it in place.
The original belt tensioner seems to have been made in Czechoslovakia, which was interesting to find.
During this visit, we had also decided to replace one of the torn steering rack boots. Since Honda suppliers on Boodmo are very hard to deal with, and they have a waiting period for over 3 months, I decided to try something different. I ordered the steering boot kit for the Maruti Kizashi, as it seemed to be the same size. Fortunately, that gamble worked, and the boot seems to fit perfectly.
https://boodmo.com/catalog/part-boot-7254132/
We also noticed the CV joint outer boot was cut on our Civic, so currently hunting for parts to fix that. Will update this thread as soon as that is also fixed.
Ultimately, the car feels really good to drive now, and is smooth as butter. We will be keeping this car until its EOL, which is a no brainer at this point. The Civic brings a smile to my face every time I drive it!
Thanks for reading!
