Team-BHP - getz odometer bulb replacement
-   -   getz odometer bulb replacement (https://www.team-bhp.com/forum/technical-stuff/59804-getz-odometer-bulb-replacement.html)
The tiny bulb for the digital odometer of the Getz has gone off. The bulbs in the speedo and fuel indicator etc. are fine. Hyundai tells me the entire assembly has to be replaced, costing 5000 - odd rupees.:Shockked:
I can live without a light in the odo, but am curious if anyone has tried to replace this bulb or knows the procedure?
The digital tacho is probably an LCD display, and the backlight is usually an integrated LED/OEL/Fluorescent, and cant be replaced seperately
Is it not under warranty. If yes I think it would be replaced free of cost
warranty over unfortunately.
Yes, the light for the ODO is integrated into the LCD. You will have to get the whole LCD changed.
No worries, you can find a similar bulb from any electronics shop. As it is, if the warranty has expired you can post-mortem the odo and easily de-solder the old bulb and solder it up with a new one.
The LCD screen and the illumination system are never integral with each other, be it an audio player, digital watch or odo.
It should work.
integrated or not, what Hyundai want is that i change the entire instrument panel, speedo, fuel indicator, odo, etc. Hence the cost!Anyone has ever opened up their panel?
Filcord, The entire instrument panel, speedo, fuel indicator, odo, etc. comes as a single unit and hence they are saying the same.
Got my console replaced recently under waranty as the temperature gauge was not working perfectly & the entire console (Single unit) was changed.
As ilangop said, try opening the console & see what what kind of illumination is there for LCD. if it is a small led bulb, take the console to a good electronics shop who can desolder the old bulb & solder a new one.
You should certainly get it opened and checked, if there was a bulb, there should be a way to replace it.
Hyundai dealers are mostly interested in changing the entire thing, what would happen when someone engine needs repairs, some day they'll start saying REPLACE the engine.
I've done a few post-mortem of odo console of my santro, and think its very fixable for lights, I've Blue LED's in them.
check http://www.team-bhp.com/forum/modifi...ml#post1293504
Thanks, BTW the blue LEDs are cute!
filcord don't waste your time opening it just to check. I have opened the cluster of my getz to pop in those famcy blue lights, only to find the backlighting LED's soldered onto the main board. If you want to still save on cost I suggest you take out the cluster and show it to some guy who does computer motherboard repairs. Maybe if you can source the LED's he'll do the job for you.
The getz cluster has 8 LED bulbs inside,the Odometer is also powered by them,the stock bulbs cost Rs.15/- without the holder,once you open it make sure you dont loose the bulb holder cap,incase you want to change the light colour just put a giliten paper over the bulb done!!! :)
Ramie
