Old 7th December 2017, 14:23   #196
Maverick79's Avatar
Thanked: 527 Times
Default Re: Tata Manza - List Of Problems
Originally Posted by Sir Lancelot View Post
Calling all Manza owners: Does anyone have a problem of water leaking into the boot when it rains? I noticed about 1cm deep water in the spare wheel well after a recent rainy day, I know it was dry the day before because I pumped up the spare tyre then. The boot floor carpet was also wet, but not sure if that was just siphoned up, or if the leak came from above. If anyone has solved this issue, what was the source of the leak? Is it the boot seals? Or is it underbody spray from driving on a wet road, seeping in though a hole somewhere.
I owned one for 40 K kms from 2011 Feb to 2012 March.
Yes. Water used to some how peep into the boot.
When checked with my S.A in TASS Bhosri, he pointed out the cut on the rubber cap / washer to accommodate the extra wiring for rear sensors made by the accessories guy.
Hence, I felt that could be the only reason. Changed the rubber cap/ washer and the issue got solved.
regards,
Maverick79.
Maverick79 is offline   (1) Thanks Reply With Quote
Old 7th December 2017, 14:39   #197
Thanked: 72 Times
Thanks Maverick79. May I ask if you recall where exactly in the boot this rubber cap/washer was located? Was it something extra you had fitted? My car is 100% virgin, as it came out the factory...
Sir Lancelot is offline   Reply With Quote
Old 9th December 2017, 11:22   #198
Maverick79's Avatar
Thanked: 527 Times
Sure Sir Lancelot,
Mine was also a virgin from factory initially. However, as I graduated from M 800 to Manza.. a car with a very big boot, I felt a need for reverse parking sensors.
Hence, the accessories guy routed his wiring from tail lamp cluster wiring from bumper into the boot via the rubber boot. As it was not able to house all the wiring together, he cut 2 mm of the rubber boot to accommodate all the cluster of wiring's.
Apologies for not able to trace the exact photograph as it's close to 5 years now.
Its exactly behind the tail lamp. If you remove the carpet and side insulation, you will be able to see it.
It may be not the exact case in your ride. So pls check the boot beading's and drain plugs carefully. They could be the culprit. Especially in the spare wheel well.
Hope this helps you some how or the other.
regards,
Maverick79
Old 12th December 2017, 10:59   #199
Thanked: 72 Times
Sure Sir Lancelot,
regards,
Maverick79
Thanks for the pic and description Maverick. I have decided to do a warranty claim on this leak, and booked my Manza in at the local Tata service centre to have the leak traced and plugged.
I have another issue which is cropping up with my Manza now:
My Safire90 petrol is brand new with only 600km on the odo by now. I have noticed a power loss issue which is becoming more and more frequent. Basically, what happens is in the middle of driving the car suddenly loses power, as if it has gone into "limp mode". No warning lights on the dash light up. It happens in any gear, 1st to 5th, and both with the AC on and off. At first it thought I must be in the wrong gear, changed down, and power was back. But I knew that I wasn't in the wrong gear anyway, so some experimenting when it occurs has shown me that if I totally lift off the throttle pedal and then immediately re-apply the throttle, the power is back normally. This leads me to believe that the problem is related to the throttle position sensor? I will have this looked at by the service centre as well. Does anyone else have this issue on a Safire90 engine? Also, does anyone know if this engine uses a throttle cable or a "drive by wire" throttle? If it's the latter my guess is it's an electronic rather than a mechanical issue....
Old 12th December 2017, 16:31   #200
bikertillidie's Avatar
Thanked: 737 Times
The Manza employs a drive by wire system. There have been cases where issues were reported concerning the sensor attached to the A pedal.
bikertillidie is offline   Reply With Quote
Old 13th December 2017, 22:41   #201
Thanked: 72 Times
OK, well I will have the accelerator pedal issue seen to under warranty. Incidentally, after some rain today I traced my boot leak. The water was leaking in through the rear right light cluster's electric wire feed. Where this wire passes through the boot metal body, it is supposed to be sealed by a rubber grommet. It was not fitted correctly, I pushed it in place, and the leak problem is now solved..
Sir Lancelot is offline   (2) Thanks Reply With Quote
Tata Indica - List of problems Ferrari1976 Technical Stuff 1202 25th June 2017 01:46
A story of 3 workhorses: 2 Santro's and a Manza, Edit: Santro sold, Manza at 100k+ amit1234singla Long-Term Ownership Reviews 115 10th August 2014 21:53
Tata Manza - Technical Specifications & Feature List Stratos Technical Stuff 2 24th June 2011 19:58
Tata Manza Aura+ 6k kms done - slowly emerging problems 5kmiles Test-Drives & Initial Ownership Reports 29 25th September 2010 18:41
