Team-BHP > BHP India > Team-BHP Reviews > Test-Drives & Initial Ownership Reports
Old 1st April 2018, 18:03   #601
dkaile's Avatar
Thanked: 4,615 Times
Default Re: Skoda Superb - A tryst with destiny
6th year anniversary Servicing; 28342kms; 27-03-2018
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_1.jpg
So it's been 6 wonderful years with my Superb and it was high time I got that oil change servicing done. I was skipping it due to lack of kms traveled but knew very well that a yearly oil change should be adhered too even if the kms traveled are minimal. Anyways, I had already procured all the required parts earlier as discussed in my earlier posts - http://www.team-bhp.com/forum/test-d...ml#post3867829
Castrol Edge Titanium 5W40 5L Engine Oil complying with VW 502 00 / 505 00 and API SN grade, was further procured. The MRP was 3446+1047 = 4493/- but I got the oil at net 3000/- bucks with vat bill. 4.6L is to be used in the oil change (with filter replacement) and the rest will be kept as spare for top-up.
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_2.jpg
I first thought to do the servicing at home as I had all the tools necessary but then opted to take it to a friend's Castrol Pit Stop for ease of use. The first job was to remove the solid under-body protection plate. It requires removal of 6 x 13mm nuts and 8 x T25 Torx scews.
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_3.jpg
The plate was then given a well deserved wash and wipe
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_4.jpg
The oil sump was revealed below
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_5.jpg
The oil drain plug is on it's back side
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_6.jpg
Proper tools are necessary to remove the various parts and the most important ones are the T40 Torx, T25 Torx (also used for the removal of the air filter housing), 13mm socket and a long 16mm Spark Plug Socket with rubber holder inside to catch the spark plug head.
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_7.jpg
The oil drain plug requires a T40 torx to open it up
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_8.jpg
The oil filter was opened up with a proper oil filter opening tool and the oil drain washer was replaced with a new one to avoid any leaks. Here are the old parts
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_9.jpg
A view of some of the tools used
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_10.jpg
4.6 liters of oil was replaced
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_11.jpg
The spark plugs were removed (refer to previous videos I had posted for the procedure) and it was having a perfect color signifying good fuel efficiency. Here it is before cleaning
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_12.jpg
And here after cleaning
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_13.jpg
The tip was NOT touched and the gap was found to be perfect at 8mm
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_14.jpg
The Air filter and the Cabin filter were also removed and inspected. As they were not particularly dirty and soiled, I just cleaned them with soft air pressure and refitted them. Refer to my previous posts for their removal and replacement procedure. The car was given a nice wash
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_15.jpg
And a nice shampoo rinse
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_16.jpg
Final drying at my friend's Castrol Pit Stop
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_17.jpg
The engine bay was cleaned
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_18.jpg
Here it is gleaming like new even after 6 years. That's VAG build quality for you.
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_19.jpg
After a nice coat of Waxpol Silky Touch polish
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_21.jpg
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_22.jpg
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_23.jpg
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_24.jpg
The oil level was checked again after 24 hours
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_25.jpg
The AC gas used in the car is R134a and capacity used is 525grams. I found that the AC cooling had slightly deteriorated after the preceding winter and as the gas had not leaked even after weeks, it was deduced by a AC expert that the quantity had deteriorated after 6 years in service and just a top-up is necessary
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_26.jpg
So it was topped up to the original specs and voila the cooling was back to it's brilliant best
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_27.jpg
Some parting shots from yesterday
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_28.jpg
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_29.jpg
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_30.jpg
And finally, as good as new...
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-28342km-27032018_20.jpg
Cheers...
dkaile is online now   (15) Thanks Reply With Quote
Old 6th April 2018, 20:57   #602
dkaile's Avatar
6th year anniversary Servicing cont...; 28580kms; 06-04-2018
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-cont-28580km-06042018_1.jpg
In continuation to my previous week's service, I somehow did not feel comfortable NOT replacing the Air and HVAC filters. So went ahead today and replaced them at home.
After removing the AC filter and comparing it with the new one, I was slightly shocked! No need to tell you, which is which...lolz. So it was a good thing, I went ahead.
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-cont-28580km-06042018_2.jpg
Then the engine bay was opened up once again
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-cont-28580km-06042018_3.jpg
And Air filter housing's screws were opened up once again
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-cont-28580km-06042018_4.jpg
8 x T25 torx screws in total were neatly lined up
Name:  Skoda Superb 6th year Service cont 28580km 06042018_5.jpg
And the housing was raised to reveal the old air filter
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-cont-28580km-06042018_6.jpg
The old filter was removed and the air filter housing's intake was carefully cleaned
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-cont-28580km-06042018_7.jpg
Again a comparison of the old and the new filters. And no need to tell which is which...
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-cont-28580km-06042018_8.jpg
The new air filter was carefully lodged in place, taking care as to not crush the filter's top rubber beading and place it carefully in it's groove. And then the air filter housing was closed and it's screws re-tightened.
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-cont-28580km-06042018_9.jpg
The Fuel filter was also checked. It still has a minimum life left of 10-15k kms as per the replacement schedule.
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-cont-28580km-06042018_10.jpg
Original Skoda Summer Wash fluid was topped up to the windshield washer reservoir.
Skoda Superb - A tryst with destiny-skoda-superb-6th-year-service-cont-28580km-06042018_11.jpg
LED DRL's installed 06-04-2018
Now I was wanting to replace the normal bulbs in the Daytime Running Lights (DRLs) with the LED ones for cosmetic reasons. But I had had a bad experience a few years back when the bulbs that I got from AliExpress did not function properly and gave Canbus Error on the MID. So I found about these new ones, again on AliExpress, in which the seller assured me that the LEDs are CANBUS compliant and will function perfectly in my Skoda and all VAG cars. This is the link - https://www.aliexpress.com/item/For-...311.0.0.58VLzY . These came quite quickly.
Here they are. The bulb has 6 x 5W LED chips and is 'supposedly' made of aviation grade aluminum alloy.
Skoda Superb - A tryst with destiny-skoda-superb-led-drls-installed-06042018_1.jpg
Here is how the stock DRLs look (BEFORE replacement picture)
Skoda Superb - A tryst with destiny-skoda-superb-led-drls-installed-06042018_2.jpg
A closer view of the stock bulbs
Skoda Superb - A tryst with destiny-skoda-superb-led-drls-installed-06042018_3.jpg
Both the plastic covers on the lower grills were removed to access the Fog/DRL light housing. These are just slide out covers and require no tools.
Skoda Superb - A tryst with destiny-skoda-superb-led-drls-installed-06042018_4.jpg
Then just a push of the hand in the slot and the DRL/Fog light housing slides out, without any tools again.
Skoda Superb - A tryst with destiny-skoda-superb-led-drls-installed-06042018_5.jpg
Finally the housing is pushed out and the cover slot of the DRL bulb is turned anticlockwise to get the bulb out
Skoda Superb - A tryst with destiny-skoda-superb-led-drls-installed-06042018_6.jpg
The stock and LED replacement compared. The stock bulb is a 12V P21W
Name:  Skoda Superb LED DRLs installed 06042018_7.jpg
The locking indents are in a straight line in these ones
Skoda Superb - A tryst with destiny-skoda-superb-led-drls-installed-06042018_8.jpg
Finally the lights were switched ON. NO ERRORs on the MID and the bulbs function perfectly as promised. AFTER replacement picture...
Skoda Superb - A tryst with destiny-skoda-superb-led-drls-installed-06042018_9.jpg
A closer look at the LEDs. Looks much better and are also brighter than stock. And all for 900 bucks.
Skoda Superb - A tryst with destiny-skoda-superb-led-drls-installed-06042018_10.jpg
A day well spent. Cheers for now...
dkaile is online now   (18) Thanks Reply With Quote
Old 3rd May 2018, 10:33   #603
dkaile's Avatar
07-04-2018 - Service Parts Received
As I had used up the service parts in the recent service, I decided to call up Skoda Customer Care and ask for a new set. They directed me towards Aryaveer Motors, Moti Nagar, Delhi instead of Nawab Motors, Noida, this time around. Seems like even Nawab Motors is on the way out, pathetic Skoda Service!
So got these parts from them which I will keep as reserve for the next service, a year or so down the line. As non of the parts have a expiry date, purchasing them before hand just gives me peace of mind.
Skoda Superb - A tryst with destiny-skoda-superb-service-parts-aryaveer-motors-07042018_1.jpg
This was the bill of Rs. 4760/-
Skoda Superb - A tryst with destiny-skoda-superb-service-parts-aryaveer-motors-07042018_2.jpg
As I already had a fuel filter and now I have 2. So planning to change the exisiting one too, soon. Got a pick set from AliExpress for 270 bucks - https://www.aliexpress.com/item/4Pcs...311.0.0.2Z5dcv
Skoda Superb - A tryst with destiny-skoda-superb-pick-set-fuel-filter-replacement-28042018.jpg
which will come in handy while replacing the fuel filter as per this video -
26-04-2018 - Front Left Window Mechanism Replacement
Now the front passenger window mechanism had been troubling me since the last 2 years (refer to my earlier post dated 20-03-2016 - http://www.team-bhp.com/forum/test-d...ml#post4166442 ), and the wire which I had got repaired, broke again. So this time around I thought of repairing it for good and replacing the entire mechanism. Now there was confusion to what the part# of the window mechanism actually was. I tried inquiring from AryaVeer Skoda and two part#s surfaced 3T0837461A (the incorrect one) and 3T0837401B (the correct one). They quoted me 9k for the part and Total expense of about 15k including labour. As I had already opened up that window earlier, I decided to search for the part in the Delhi Market. So off I went to the Kailash Colony Market in South Delhi and to my friendly neighborhood denter Fakruddin (9899960106) and his brother Nasruddin/Zameer (9910138455) and opened up the front door again -
Skoda Superb - A tryst with destiny-skoda-superb-flhs-window-repair-26042018_1.jpg
Got hold of the correct part#
Skoda Superb - A tryst with destiny-skoda-superb-flhs-window-repair-26042018_2.jpg
Searched with Mahajan Automobile, Lajpat Nagar (011-29817215) and got the wrong part in the first go because I had earlier asked him the incorrect part# as detailed above. Then on the second go after giving him the correct part#, he arranged for the correct part in a few hours, and all for just 3.5k (and I doubt he charged me a premium of at least 1k in that too...lolz)
Skoda Superb - A tryst with destiny-skoda-superb-flhs-window-repair-26042018_3.jpg
With the brand new mechanism in hand the rest of the job was a piece of cake and took 10 minutes to fit it back
Skoda Superb - A tryst with destiny-skoda-superb-flhs-window-repair-26042018_4.jpg
And now the window works as new. Total expense was 3.5k + 1.5k labour.
Tried my hand at touching up small nicks and scratches on the car with a matching nail polish
Skoda Superb - A tryst with destiny-skoda-superb-nail-polish-touching-29042018_1.jpg
And even though the shade looks a little different in these photos, the nicks are now almost invisible from a distance
Skoda Superb - A tryst with destiny-skoda-superb-nail-polish-touching-29042018_2.jpg
On the return journey, basked in the glory of the new 10kms single pillar elevated highway made by the current government between Rajnagar Extension in Ghaziabad and UP Gate (Delhi border). This thing saved me 30 minutes of the bumper to bumper journey earlier, not to mention about the fuel savings in the process. This is supposedly the longest 'Single Pillar Elevated Road' in the country, as on date. Well done.
Skoda Superb - A tryst with destiny-new-elevated-highway-rajnagar-extension-up-gate-28042018.jpg
Cheers for now...
dkaile is online now   (7) Thanks Reply With Quote
Old 3rd May 2018, 11:16   #604
Thanked: 2,726 Times
This is the right way to maintain a German in India. Though it requires some amount of time and contacts, the benefits are more than worth the investment. With such practices, you can continue to enjoy the Superb, superbly, for many more years.
I love the way you document the minute details of part replacements and fitment, I am sure it helps a lot of owners in maintaining their cars.
So, how much has your Fortuner clocked now? Any plans of replacement/upgrade?
n.devdath is offline   (1) Thanks Reply With Quote
Old 3rd May 2018, 11:43   #605
dkaile's Avatar
Thanks for the kind words.
My Fortuner is driven mostly by my brother and it is still around 40-45K. I like the comfort levels offered by the Superb much more. Though he sends it over to me for the maintenance part. Lolz. That too is a bulletproof car and requires minimal maintenance except perhaps a annual service. Anyways it too has not done any substantial miles to warrant anything bigger. No plans to upgrade because investing north of 40+L is just not worth it for me and you don't get resale even if your vehicles are low mileage ones. So, in my books, it's better to keep them running like new and enjoy the benefits. BTW, I just froze on the way back from Delhi after topping up the AC gas on the Superb. These are just the small things they need to keep giving you the pleasure of a true luxury car that they are.
Cheers...
dkaile is online now   Reply With Quote
Old 31st May 2018, 13:19   #606
dkaile's Avatar
LED Parking Light Bulbs installed 13-05-2018
After changing the DRL's to LED I decided to do the same for the Parking Light bulbs to match with it's white light.
So the first thing after opening the bonnet was the removal of the rubber boot covering the side of each headlight to reveal the bulbs inside
Skoda Superb - A tryst with destiny-skoda-superb-led-parking-lights-installed-13052018_1.jpg
The Parking Light bulb socket was just pulled out from it's position to reveal the bulb inside. It's a 12V W5W bulb
Skoda Superb - A tryst with destiny-skoda-superb-led-parking-lights-installed-13052018_2.jpg
This is the yellowish light it produces
Skoda Superb - A tryst with destiny-skoda-superb-led-parking-lights-installed-13052018_3.jpg
A LED bulb for this W5W socket was sourced at my local shop for just 30/- bucks a piece and this is how both the bulbs look
Skoda Superb - A tryst with destiny-skoda-superb-led-parking-lights-installed-13052018_4.jpg
Replaced the bulb in the socket with the LED bulb
Skoda Superb - A tryst with destiny-skoda-superb-led-parking-lights-installed-13052018_5.jpg
This is how it lights up in white light which is much brighter than stock
Skoda Superb - A tryst with destiny-skoda-superb-led-parking-lights-installed-13052018_6.jpg
Before
Skoda Superb - A tryst with destiny-skoda-superb-led-parking-lights-installed-13052018_7.jpg
and After
Skoda Superb - A tryst with destiny-skoda-superb-led-parking-lights-installed-13052018_8.jpg
A comparison with both the bulbs in respective sockets
Skoda Superb - A tryst with destiny-skoda-superb-led-parking-lights-installed-13052018_9.jpg
Before
Skoda Superb - A tryst with destiny-skoda-superb-led-parking-lights-installed-13052018_10.jpg
and After
Skoda Superb - A tryst with destiny-skoda-superb-led-parking-lights-installed-13052018_11.jpg
The MID threw a bulb error on first startup but then the error disappeared mysteriously subsequently and the bulbs are also working just fine. 60 bucks well spent.
Also got a fully waterproof Polco branded Dupont Tyvek car cover from Amazon for Rs. 3399/- https://www.amazon.in/gp/product/B00...?ie=UTF8&psc=1 for the car which looks Superb as well as functions as expected
Skoda Superb - A tryst with destiny-skoda-superb-polco-3m-car-cover-installed-16052018.jpg
Cheers...
dkaile is online now   (5) Thanks Reply With Quote
Old 5th June 2018, 16:47   #607
dkaile's Avatar
The rubber tether on the fuel cap of the Superb had broken off with age. Searched locally but couldn't source one. Looked at AliExpress and found a listing with the entire fuel cap with the rubber tether for around 400 bucks landed - https://www.aliexpress.com/item/for-...2ad54c4dq6dmnB .
Though my fuel cap was absolutely OK, so I got this one and just replaced the rubber tether and kept the fuel cap as spare. Absolutely OE quality -
Skoda Superb - A tryst with destiny-skoda-superb-fuel-filler-cap-new-02062018.jpg
Cheers...
dkaile is online now   (2) Thanks Reply With Quote
Old 21st June 2018, 15:45   #608
dkaile's Avatar
Nearly 30k kms and on a recent 400kms trip to Corbett
Name:  Skoda Superb 18062018Corbett Trip_1.jpg
Cheers...
dkaile is online now   (3) Thanks Reply With Quote
Old 17th April 2019, 17:41   #609
Any recent updates? Have you sold the car?
This is one of the best long term ownership thread about the Superb. Totally enjoyed reading it. Kindly update if possible.
StarryFurry is online now   (1) Thanks Reply With Quote
Old 12th June 2019, 12:04   #610
dkaile's Avatar
7th Year Update - 12-06-2019 - 30802 kms
7th year happily chugs on with the Superb with zero issues.
Still as good as new
Even the interiors are spotless and the 6MT is still the BEST in the business
Snapped some photos on a recent trip to Moradabad. The car kept us chilled in the 47.5 degree heat.
Someone nicked one of the Skoda logo stickers from one of the alloy wheels.
Got a full set from AliExpress for 150 bucks
And the alloy is back to original
Also the Parking Light LED Bulbs I had got earlier were giving Canbus Error. So procured a new pair from AliExpress which were Canbus compliant for 100 bucks
Beautiful White Parking Lights now and without any error
The DRL's had already been converted to LED's with Canbus complaint bulbs as detailed in my previous posts
Now these perfectly match the White light of the stock HID bulbs
Cheers for now...
dkaile is online now   (10) Thanks Reply With Quote
Replacing a Superb - BMW GT, Mercedes C220 or 3rd-gen Skoda Superb? Epic Luxury, Imports & Niche 52 24th December 2016 22:41
Skoda unveils updated Superb and Superb Combi in Europe Abhinav667 The International Automotive Scene 59 15th January 2014 21:17
Destiny or fate or a coincidence? wanderernomad Travelogues 57 6th September 2008 00:44
Copyright 2000 - 2019, Team-BHP.com
