Re: My Maruti Ciaz Automatic Hi revintup,
First of all, heartiest congratulations on the purchase. Hope you are enjoying the stress free ride the fully automatic torque converter offers!
I own a 2012 Dzire which has the same gearbox as your Ciaz has albeit with 1197 cc engine.
It has a very strange behaving AC. When moving at crawling speed (when no accelerator input is needed) in stop go traffic (say in a traffic jam) or while reversing, the AC cuts off whenever I release the brake pedal.
When crawling forward, when I release the brake, the AC compressor gets cut off and remains like that for a while before switching on again. If I brake again and release it, the compressor gets cut off again.
Same thing happens while reversing. When I release the brake, the AC compressor gets cut off and remains like that till I press the brake again.
I also get a feeling that even while moving at decent speed (at 50 or 60 kmph), if I brake, the AC compressor gets cut off.
I wanted to know if you too are facing the same situation.
To know about it, you will need someone to stand outside the vehicle (with bonnet open) and have him take a look at the compressor. You need to sit inside and reverse the vehicle. The compressor should cut off and stop working till the time you press the brake again. Same thing should happen when moving forward.
Your input regarding it will be highly appreciated. |
