![]() | #241 | |
BHPian Join Date: Dec 2012 Location: New Delhi
Thanked: 140 Times
| ![]() Quote:
![]() | #242 | |
BHPian ![]() | ![]() Quote:
I was about to update the thread. Even after 2 weeks with slightly higher pressure of around 35 psi in LH rear tire, I didn't find much difference in the shape out nor the reduction in vibrations. Will wait for one more week and then see if I can increase the pressure to a 37 psi and check for few more weeks. Meanwhile, any other suggestions (other than tire change) are welcome. Thanks in advance! Regards, Maverick79. | |
![]() | #243 |
Senior - BHPian ![]() | ![]() Using the tyre size calculator I found that the possible upsizes in 13" and 14" with less than 2% error are: 165/55/R13 175/50/R13 195/45/R13 195/45/R14 Which of these sizes are easily available in India. I'm looking for a V-Pattern like the Maxxis MA-Z1 preferably in 13"? |
![]() | #244 | |
Increased the pressure to 40 psi 10 days before. Vibrations are more pronounced even at low speeds (~20 kmph)now. ![]() Will wait for couple of weeks more with this level. Ride will be idle for next 10 days though. Will adjust the wheel carefully to avoid flattening the same spot again. Any other suggestions are welcome! Thanks in advance. Maverick79. | |
![]() | #245 |
Distinguished - BHPian ![]() ![]() Join Date: Oct 2009 Location: Namma Bengaluru
Thanked: 7,660 Times
| ![]() Need help for a friend to choose the right tyre: Car: Maruti 800, 5 Speed Model Year:2002 Tyres:Currently running on Apollo 145/70 R12 (Tube Type). Looking for suggestions/answers for below questions: 1. Would Tubeless tyres be better - currently the car is running tube type tyres on steel rims. The rims aren't rusted and in good condition so is it good to go for tubeless tyres ? *One dealer seemed to think otherwise and was suggesting continuing with tube type tyres 2. Will upsizing to 145/80 R12 be good (for better GC) ? 3. Recommended Brand (no specific constraint on budget) Currently considering Apollo, Bridgestone, Michelin, any others ? |
![]() | #246 | |
Distinguished - BHPian ![]() ![]() | ![]() Quote:
1. 145/80R12 Merits: 1. Increased GC 2. A bit better ride quality 3. Michelins available in this size. Demerits: 1. May scrape wheel well. Specially on full load and/or the shocks are bad. 2. Wrong speedo reading. This is a wrong size. Period. It so wrong that if you install a size larger rim, 145/70R13 tires, it will still be smaller. Shopkeepers recommend because they have to sell and stock lesser sizes, people get misguided and purchase seeing increased GC and better ride. 3. Extra wear and tear of driveshafts. I'll never recommend anyone to go for this size. 2. Tubeless vs Tube: If the rims are perfectly fine(no bending anywhere and/or corrosion near valve area), then I see no reason to miss the Tubeless. I am on tubeless on stock rims since past 2.5 years I guess, and am very happy. Get standard MGP valves which are cheaper and of awesome quality. ![]() 3. If I am concerned, and for stock size, I'd choose either Goodyear Ducaros or Ceat Milaze Tubeless. Other available options are MRFs(Tube), Bridgestone S322(tube), Firestone tubeless, JK Ultimas(best avoided) etc. Michelins had an offering in this size earlier but they discontinued due to low demand. Yokos aren't available too. On my car, I have Goodyear Ducaro in stock size and they are excellent if you drive M800 like its meant to be. And there aren't many good options in stock size too. Please go through this link, why I changed to Goodyears: http://www.team-bhp.com/forum/tyre-a...ml#post3802207 4. If you want slightly more grip, then 155/65R12 is the perfect upsize without any major issues(steering becomes a bit heavy and mileage may go down). Bridgestone has a tubeless offering in that size. Additional points: Make sure to match the high and low points of rims and tyres before balancing. Regards, Shashi Last edited by Leoshashi : 29th January 2018 at 17:46. | |
![]() | #247 | |
![]() Now the question, do I need to change both the rear tires? They ran only 18 K. Still lot of life. Regards, Maverick79 | |
![]() | #248 | |
Atleast keep similar tyres on the same axle. | |
![]() | #249 | |
BHPian ![]() Join Date: Mar 2007 Location: Mumbai
Thanked: 466 Times
| ![]() Quote: | |
