Old 25th January 2018, 16:07   #91
Thanked: 24 Times
Default Re: Renault Duster : Wheel & Tyre Upgrade
Originally Posted by hiran77 View Post
Hello Neil can you please share your overall experience with these set of tyres?
Originally Posted by Oreen View Post
Was thinking of going for 15" wheels and 235/75 R15 tyres like the first generation Scorpio had.
I am in the same dilemma.
Was wandering if anyone finally got the 15" tyres on their duster or anymore info on the subject ?
ralto is offline
Old 2nd February 2018, 10:32   #92
hiran77's Avatar
Thanked: 66 Times
Was wandering if anyone finally got the 15" tires on their duster or anymore info on the subject ?
Have replaced mine with Yokohama Geolanders. Added cushion effect is brilliant.....slight compromise in high speed handling and braking which i can live with. I was expecting slight drop in performance in ghat sections owing to the one inch lift and added rubber. surprisingly it performs better than stock!
Bad roads are even more welcome now! braking on loose gravel or bad roads is way better.....amazing grip the tires have!. Would recommend every AWD to shift to this setup. only concern is front wheels (only the left wheel) rub inside the wheel well on full turn. don't know why its happening only on one side. I any ways hardly use a full turn...by practice i do not like straining the power steering pump unless its absolutely necessary.
sharing a Pic for everybody's reference
Renault Duster : Wheel & Tyre Upgrade-img_20171019_184928_042.jpg
Last edited by Aditya : 2nd February 2018 at 13:02. Reason: Back to back posts merged
hiran77 is offline   (1) Thanks
Old 23rd February 2018, 21:18   #93
couswheels's Avatar
Thanked: 163 Times
Have changed Raje's Tires from Apollo to Good Year Efficient Grip SUV. Refer to the ownership thread for further details.
http://www.team-bhp.com/forum/test-d...0ps-rxl-4.html
couswheels is offline
Old 14th July 2018, 13:57   #94
PetaWatt's Avatar
Thanked: 220 Times
Missed this thread earlier. I replaced the steel wheel of my 2017 Duster RXL Petrol with MOMO NEXT Matt Anthracite Polished 16 inch alloys. Here are few pics (were taken after the upgrade in Oct 2017):
Renault Duster : Wheel & Tyre Upgrade-frontright.jpg
Renault Duster : Wheel & Tyre Upgrade-left.jpg
Renault Duster : Wheel & Tyre Upgrade-rearleft.jpg
PetaWatt is offline   (1) Thanks
Old 15th July 2018, 17:54   #95
T-Rex's Avatar
Thanked: 24 Times
Attachment 1723187
Hi Hiran77, can you also share the alloys and tyre size specs. Is the alloy wider than the stock phase 1 & 2 alloy, if so, then that could be a cause of rubbing. It looks much brawny and suits the Duster’s otherwise masculine body style
T-Rex is offline   (1) Thanks
Old 3rd September 2018, 15:16   #96
hiran77's Avatar
Thanked: 66 Times
I will have to check the alloy.....do not remember. the rubbing is mostly due to larger dia and increase in width/profile.
have run about 12000 kms and i noticed the rubbing noise has gone obviously due to tyre wear. it was very negligible in the beginning too......also the grip in rain is brilliant compared to stock. haven't tried off-roading but this does give better traction than stock in any condition. Would recommend this setup to all AWD owners
Old 24th September 2018, 07:55   #97
Thanked: 136 Times
Attachment 1723187
Hi Hiran, Can you please share the tyre specs? Thanks
Touringlawyer is offline
Old 27th September 2018, 16:56   #98
bdman's Avatar
Thanked: 91 Times
.. Hi. .thanks for the info about tyre size upgrade.. Can you please share some details on which part of the tire was rubbing against the body? Tread? or side wall?
bdman is offline
Old 21st November 2018, 22:10   #99
Thanked: 255 Times
Hi guys, am posting on behalf of my nephew who bought a CVT Duster. His question is:
"for duster CVT in place of MRF Wanderer which one will be better tyre?
what are the pros and cons of Michelin LTX force and Primacy and which one to choose?
I don't need a budget solution, just need quiet, all-terrain tyres"
Oreen is offline
Old 7th January 2019, 12:28   #100
Tgo
Tgo's Avatar
Thanked: 2,313 Times
Originally Posted by jmktm View Post
Hi, was able to buy Yokohama G055 SUVs ( 215/65/16) for Rs.7550/- each. Free balancing and alignment also thrown
in.
Any upgrade since then? I am currently on the same G055 SUV tires which are nearing the end. They gave me a comfortable running of 40,000 KM. Tires have become stiff and the wear indicators are about to indicate replacement in the next 5,000 Km or so.
Tgo is offline
Old 7th January 2019, 14:03   #101
Sheel's Avatar
Thanked: 9,467 Times
Stick with Michelin, they make the best tires.
You can experiment with
# Continental Cross Contact AT's,
# Yokohama Geolander G015
but, the Michelin LTX Force is what I would recommend as they would give the best of both worlds.
Sheel is offline   (1) Thanks
Old 19th January 2019, 11:59   #102
Thanked: 18 Times
My Duster has driven around 43K kms and needs tire replacements.
My driving is on tarmac for 99% of the time, although in Bangalore that tarmac is pretty rough at times with potholes, bumps, badly designed speedbreakers and gravel/mud in a few locations. I would like a smooth cushioned ride that does not compromise (perhaps a little is fine) handling. A noisy ride would be unwelcome so that does rule out AT tires I would imagine.
Apart from the two mentioned above (with links) and the Michelin LTX are there any more tires to consider?
How does one go about choosing a tire replacement?
Kartik Kumar is offline
Old 19th January 2019, 15:53   #103
Sheel's Avatar
Check Michelin and Yokohama, there are road biased SUV tires with them.
Originally Posted by Tgo View Post
Wanted to try Continental this time with their on-road tyres.
Originally Posted by C300 View Post
I don't think Continental offers stock size on road for Duster.
It does, have a look
https://www.continental-tyres.in/car...rosscontact-at
Sheel is offline
Old 19th January 2019, 16:42   #104
Thanked: 822 Times
Thanks. Thats AT. Wonder they offer highway tires in stock size for duster. Most of my driving is on highway so AT will be overkill.
C300 is online now
Old 25th February 2019, 14:58   #105
Thanked: 822 Times
Went with Michelin primacy SUV last week in stock size. Total damage was 37k. Had to wait for few days as the tires were not in stock with the dealer. Primacy SUV is rated 102H and manufactured in Sep-18. Road noise has dropped significantly. Ride is smoother given the new set of tires. Will share detailed review post 10k KMs.
C300 is online now
