Old 13th December 2021, 16:06   #16
vipul_singh's Avatar
Thanked: 826 Times
Re: Tyre upgrade for the 5th-gen Honda City
This is how the 5th Generation City looks on 205 55 R16 Michelin Primacy 4ST:
Should help those wondering how this tyre size would 'sit' with the stock 16" wheels. In my opinion, this size looks perfect on those wheels and in that wheel arch.
Source: close friend upgraded the tyres soon after delivery.
vipul_singh is offline   (15) Thanks
Old 13th December 2021, 17:03   #17
Thanked: 465 Times
Originally Posted by ags82 View Post
V CVT variant has 15 inch alloys. Is it advisable to upgrade to 16 inch and upgrade tyre size to 205/50 or should I stick to 15 inch alloys? What is the right trye upgrade for 15 inch alloys? Does upgrading rim size in V variant void warranty? Request your thoughts here my fellow Team BHPians.
Upgrade to 16 inches is not necessary. You will incur double the cost and loss in exchange. I have the V CVT too , the sidewall height is pretty good and doesnt risk a damage unlike 16" alloys. Upgrading the tyres to a better brand should be just fine.
In case you are interested , my recent upgrade on 15 inch with a better set of tyres from Continental CC6 below is the post.
https://www.team-bhp.com/forum/tyre-...ml#post5209076 (Continental tyres)
Swarup5 is offline   (3) Thanks
Old 10th January 2022, 11:15   #18
Thanked: 39 Times
I’m at the tyre shop as I write this. The person here judged the wheel well and said 205/55 will scrape under full load. Can you please help me confirm if you notice any tyre scrapes with this size under heavy load.
aviator47 is offline
Old 1st February 2022, 15:31   #19
sankdadevil's Avatar
Thanked: 232 Times
Did anybody try the ideal upgrade of 205/50/R16 on Honda 5th Gen ZX CVT? I wish to know if it caused any issues?
Or should the upgrade rather be 205/55/R16 as this is the size that I keep reading on various forums.
Also, is there a mention in any official document/ owner's manual regarding tyre upgrade voiding the warranty?
sankdadevil is offline
Old 14th March 2022, 22:21   #20
Thanked: 516 Times
I swapped the stock tires to Michelin Primacy 4 205/55/R16 and they are perfect IMHO. I haven't driven it with full load, but with 3 fairly heavy big adults and it had no problems at all. It increase the ground clearance by quite a bit and there is still 3 inches or more left in the wheel well so it should be okay. I also love the way it handles, brakes and rides now, not to mention quieter too. I posted pictures in the main Honda city tire change thread, so don't want to repost here.
inwester is offline
Old 30th August 2022, 23:32   #21
manasmadaan's Avatar
Thanked: 325 Times
205/50 R16 is just perfect as the diameter difference is a negligible 0.25%. Second choice would be 195/55 R16 (<2% difference), but again, 205/50 R16 is just the perfect upgrade for the power on tap . Will make the car handle better & improve its stance / aesthetics. The stock car is grossly under-tyred.
Will Michelin 205/50/R16 be good?
manasmadaan is offline
Old 30th August 2022, 23:49   #22
Thanked: 622 Times
By no means should you go for 205/50R16. It is a notoriously injury prone tyre size. Yes - the calculations show that it matches the diameter of the stock 185/55R16 tyres (which in themselves are pretty bad). There’s an entire thread dedicated to BHPians’ woes on the 205/50R17s which used to come as stock size on some variants of the eco sport-
https://www.team-bhp.com/forum/tyre-...-r17-size.html (Ford EcoSport Facelift: Tyre bulging issue (R17 size))
Please go for the 195/55R16s or even the slightly taller 205/55R16s even though it increases the diameter by more than the recommended 3% - many BHPians are running with this setup without any issues.
Another downside of 205/50R16 is that it’s an odd size, which means it is hard to come by outside metros and expensive to replace.
For both 195/55R16 and 205/55R16, the options I would recommend are the Continental UC6, Vredestein Ultrac/ Ultrac Vorti and the Yokohama BluEarth AE51
RubberGuru1113 is offline   (2) Thanks
Old 7th March 2023, 07:13   #23
Thanked: 958 Times
I'm considering buying a Honda City (5th gen) as my next car. The value for money V variant comes with 180/60/15 tyres.
What is the rim width of the V variant, could anyone confirm? Is 5.5J or 6J?
buzzy_boy is offline
Old 9th March 2023, 10:07   #24
Thanked: 622 Times
Hello. The V Variant comes on 6Jx15 rims with a 53 mm offset. For future reference, wheel-size.com has a very accurate list of tyre and wheel specifications of all global car models.
Old 9th March 2023, 11:06   #25
Latheesh's Avatar
Thanked: 9,671 Times
V variant tire size 185x60xR15
Latheesh is offline
Old 9th May 2023, 12:07   #26
Thanked: 12 Times
Originally Posted by Shreyans_Jain View Post
I’ve been running 205/60R15 on my Gen4 City as well as my Gen1 Jazz for over 2L km cumulative. It’s the ideal size for this car. Stance and grip improve drastically and there isn’t any significant drop in performance or fuel economy. Ground clearance also improves. It just works. So, 205/55R16 should be the size of choice for the Gen5 City in my book.
Hi Shreyans, hows's your car and your experience with the bigger tyres? My 5th Honda City came with stock 185/60 R15 tyres and highspeed stability and cornering is quite under confident. I am looking to upgrade to 205/55 R 15 for better stability with a deviation of .66%
What is the real world impact gonna be in terms of mileage and handling performance?
broke_enthu27 is offline
Old 14th May 2023, 15:31   #27
Mine came with 185/55/r16 tyres. However after reading the lot of posts around the OEM slim tyres getting burst, I got them upgraded to 195/55/r16 Conti UC6 the same day I took the delivery.
Spoke to a nearby tyre shop and got a good deal. Upgrade is within the limits and I'm mentally at peace while driving now. The dealer told me to expect much better grip when at higher speeds and sharp turns, is something I'm yet to explore. Routine rides have been at an avg 50-60 kind of speeds thus far.
shubham322000 is offline
Old 5th June 2023, 15:19   #28
LJO
Attachment 2244753
Attachment 2244754
Attachment 2244755
Attachment 2244756
Hey Vipul, nice upgrade.
Can you please share pictures with steering fully turned towards left or right. Wanted to check if the tyre is touching the inner fender while turning fully.
Also, please share if it scrapped the fender when the l car gets fully loaded. Anything you noticed which might be a cause of problem.
LJO is offline
