Team-BHP - Manual Wheel Aligner Vs 3D/Computerized/Laser Wheel Alignment
-   Tyre & Alloy wheel Section (https://www.team-bhp.com/forum/tyre-alloy-wheel-section/)
-   -   Manual Wheel Aligner Vs 3D/Computerized/Laser Wheel Alignment (https://www.team-bhp.com/forum/tyre-alloy-wheel-section/261113-manual-wheel-aligner-vs-3d-computerized-laser-wheel-alignment-4.html)
Originally Posted by HTC (Post 5506487)
Went for a test ride after that. I said the rear suspension is unsettling and hard on going over speed breakers. He said that the rear tyres are old and hand causing this behavior. One tyre is 2017 make and other is 2014 make. Will get both changed to MRF wandarer AT and see if that solves the issue. Total cost 1100/-
It sounds like rear wheel alignment is off.
But without numbers it's difficult to pinpoint the 'culprit'.
Without re-doing rear alignment adjustment again, replacing with new softer tyres may not help much if there is a differrence.
Rear wheel alignment was also carried out.
As you mentioned, will get the balancing done when I get new tyres and see if problem persists.
