![]() | #331 | |
BHPian ![]() Join Date: Feb 2018 Location: Bangalore
Thanked: 132 Times
| ![]() Quote:
The alternative (and one that I follow) is that you rotate all tyres regularly, in which case, you need to upgrade the spare as well. That way, you can continue the trip, maintaining the same speeds as before, and won't be limping to the workshop, followed by waiting for the fix, both of which can be detrimental to the journey. | |
![]() | #332 | |
BHPian Join Date: Dec 2010 Location: Trivandrum
Thanked: 15 Times
| ![]() Quote:
My only worry is whether it will mess with the ABS or car electronics since the diameter is different. The car may think that one tyre on the axle is spinning faster than the other and try to do some corrective action. For cars that come with donut tyres, is the overall diameter also different or do they compensate for the lesser width using a higher profile to keep diameter more or less same? | |
![]() | #333 | ||
BHPian Join Date: Sep 2007 Location: Bangalore
Thanked: 68 Times
| ![]() Quote:
Overall i am satisfied with the tyres and happy with the ride quality they offer. Last edited by Dushie : 24th November 2018 at 10:10. | ||
![]() | #334 | |
Thanked: 15 Times
| ![]() Quote:
![]() | #335 |
BHPian Join Date: Jul 2015 Location: Pollachi
Thanked: 13 Times
| ![]() Hello, Any suggestions for a good tyre dealer in coimbatore? Thanks!! |
![]() | #336 |
BHPian ![]() Join Date: Mar 2014 Location: Bangalore
Thanked: 64 Times
| ![]() I have the same tyres for more than a year now. You can revert to the Honda recommended pressures of 32 psi in the front and 30psi at the back. Higher pressure at the back tends to make the ride bouncy. |
![]() | #337 |
BHPian ![]() Join Date: Aug 2015 Location: Calicut
Thanked: 12 Times
| ![]() Anyone upgraded tyres of 2009 model Honda city to 195/65 R15 on original alloys? Is it touching the body on full load and full shock action? What is the feedback? |
![]() | #338 |
BHPian ![]() | ![]() Guys, I am looking for an upgrade. Currently, I have OE Michelin XM1 175/65 R14 tires. Which will be a perfect upsize? 175/70 R14 - 3% than OEM; GC will increase by 5mm 185/65 R14 - Better grip, no increase in GC. 195/60 R14 - Superior grip, Marginal increase in GC 190/65 R14 - Superior grip, Marginal increase in GC Last edited by keeprevving : 23rd October 2019 at 07:08. |
![]() | #339 | |
Senior - BHPian ![]() Join Date: Apr 2008 Location: Bangalore
Thanked: 1,924 Times
| ![]() Quote:
![]() | #340 |
BHPian Join Date: Sep 2019 Location: Pune
Thanked: 2,431 Times
| ![]() I have never upgraded tyre equipment in so many years of my car ownerships. So this may be a bit of a fundamental question: suppose I upgrade my City tyres from 185/55R16 to say, 195/55R16 keeping the same wheels, would I have to retain the same tyre pressure levels (32F -30R) or would there be a change? |
![]() | #341 | |
BHPian ![]() Join Date: Nov 2019 Location: Kolkata
Thanked: 74 Times
| ![]() Quote:
I wouldn't recommend the 195/65 as the circumference difference gets >4% which is double the recommended change of <2%. The 195/60 hits the sweet spot with the right amout of width and GC improvement. Coming to the tyre, I had narrowed down on the Michelin P3ST ( P4ST didn't launch back then) and the Continental MC5. Both are soft compound silica based and are known for low road noise, better wet and dry grip and a cushioned ride quality. I got a very good deal on the MC5 at the last moment and decided to go for the same and I don't regret making the choice. Pros - 1. Road noise reduced by a huge amount and I now have a lot more silent ride 2. The car avoids scrapping many speed breakers which it would, with the previous tyres 3. The streering feel has improved marginally. 4. The grip has improved immensely and the car now corners very confidently. IMO the original 175 section was way too thin and held the car back. Cons- 1. Michelins are known for their low rolling resistance and henceit takes a bit more effort to gain traction on this one. 2. Ever so slight drop in fuel efficiency ( ~12kmpl to ~11.5kmpl) 3. Michelins look better IMO. Overall I'm very safisfied with the change and would highly recommend the same. With either tyres - Continental MC5 or the Michelin P4ST, you cannot go wrong. ![]() | |
![]() | #342 |
Newbie Join Date: Feb 2014 Location: Chennai
Thanked: 15 Times
| ![]() Friends, My Honda city diesel SV IDTEC has completed 1,75,200 kms. My Bridgestone tyres had done more than 50k kms and it was time to change. Magnum Honda service technician suggested Goodyear triplemax 2 as a better alternative. My car has always been on Bridgestone tyres hence I also wanted to see how different is Goodyear. I have been driving short distances for 3 days, the main thing I noticed was tyre noise and a bumpy ride quality. The tyre noise is not something I am used to and twice I had to stop and check if the tyres are alright. Is this a problem with tyre fitting or Goodyear tyres in general? |
![]() | #343 | |
BHPian Join Date: Aug 2012 Location: Gurgaon
Thanked: 302 Times
| ![]() Quote:
The commuter Goodyear tyres (Erstwhile GT 3 and Triplemax series) are bumpier and noisier than other brands like Bridgestone, Michelim, Yoko etc. However, they are slightly cheaper, longer lasting and comes with unconditional warranty for 2 years and conditional for 5 (Triplemax). | |
![]() | #344 | |
Thanked: 15 Times
| ![]() Quote:
![]() | #345 |
BHPian ![]() Join Date: Dec 2018 Location: Mumbai
Thanked: 419 Times
| ![]() I've upgraded from stock 175/65/R15 to 195/55/R16, MRF ZVTV to Michelin Primacy 4ST and have been using it for 2 months now. Wheels have been upgraded from 15" to 16", Brand: Momo; Model: Raptor They are wider than stock wheels, but I can't recall the specifications. Here are my observations:
