Re: WABCO India demos Automated Manual Transmission for Trucks & Buses Quote:
Originally Posted by DWind I am not going to contest your data but could it be possible that there is a drop in mileage because drivers were less aggressive / lethargic while using manual transmission when compared to AMT where they had to just concentrate on steering the vehicle during overtake and not worry about the powerband? |
The data for AMTs over long routes (Intercity buses and trucks on GQ/NH routes) shows that the mileage figures are nearly the same owing to the use of overdrive gear for more than 60% of trip distance. Personally, I have not travelled for too long a distance in AMT equipped vehicles(entire trip), but I can assure you that the system is designed to ensure there is no engine lugging, which requires shifting at marginally higher RPMs than our drivers who look to shift up earlier. Quote:
Originally Posted by Ashley2 Although none of the system can match best drivers fuel performance, AMT has proven to enhance fleet fuel performance between 5% to 7%.This is because of the reason no matter who drives the gear utilization and gear changing frequency is same for the said terrain and is derived form the software which is further finetuned for fuel performance yet without compromising performance. When you have a fleet of 300+ vehicles and is driven by atleast 600 odd drivers, driving pattern is going to be different. Some are best, many are better and few may be worst. Now wit AMT in place the nominal curve becomes narrower and gives very less spread. This translates to huge cumulative savings and is recurring.
That's the underlining selling point here. VRL is the first company to understand this logic when Ashokleyland launched Leymatic for 12M.
Also now GoI is mandating AMT or AT fir city buses produced post April 2015 when purchased under JNnurm. |
As replied to DWind, the mileage over longer routes is identical/superior to manual transmission based on how much of the distance is travelled in top gear and how severely the acc pedal is depressed in order to achieve cruising speed.
The AMT system uses the following major inputs to decide shifting patterns:
1) Engine RPM
2) Vehicle Speed
3) Boost pressure sensor (engine load measurement)
4) Acc pedal position (potentiometric reading)
The system has no 'eyes' as such and depends on live data to instantaneously decide when to shift up/down. As a result, on crowded single lane/NH corridors, gear shifting according to traffic ahead is more intelligent when a driver is in charge.
Eg: A driver looking to overtake 3 slow moving trucks will drop the gear from 6th to 4th and rev till the red band based on his knowledge of how much power is required. The AMT computer may shift into a gear lower than 4th if the speed is low enough but catch only the end portion of the power band and subsequently shift to 4th resulting in a larger amount of fuel consumed.
As is the case with any new technology, there is a learning curve, and the hope is that more and more drivers learn how to effectively use AMT and match and even exceed their manual transmission mileage figures!
EDIT: TRUE! Having AMT is our crowded cities would be the best thing for bus drivers since...well, Sachin Tendulkar since I can't think of anything else
